04-14-2012, 05:03 PM | #26 |
Re: project: 3/4 ton dropped
i dont wanna go any more in the back, because its sitting about level right now, thanks for the info anyway!
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
04-15-2012, 12:03 AM | #27 |
so this is what will probibly happen down the road.... i want it a two tone med blue with silver stripe on the side. im gonna put some sort of pinstripe inbetween the 2 colors so you dont see the paint line. Flush rear window(no slider) and full peice side windows. 30% tint. 2in steel cowl induction hood. White side markers and led taillights conversion. tint taillights. Jeep wrangler headlights with HID conversion. Rollpan in rear and chrome bumper in front. original grille and other front end peices. chrome ultra t6 wheels: 20x9 in front and 20x10in back. bucket seats from a newer silverado. grey interior. frame blasted and powdercoated satin black. new bushings everywhere. blazer gas tank located in back. dual 2.5in back with flowmaster super 44's. remove emisions junk from 454. thats all i can think of for now, and it might change a bit down the road.
04-15-2012, 01:43 PM | #28 |
hey instead of flowmaster super 44s check these out
http://www.summitracing.com/parts/SUM-638222/ half the price and sound just as good, it's the second pair in the vid
"As I walk through the valley of rice i fear no honda, for i have torque!" Last edited by Can't kech me; 04-15-2012 at 01:51 PM. |
04-15-2012, 01:45 PM | #29 | |
1979 GMC Sierra Classic Freshly lowered 5 inches |
04-15-2012, 03:29 PM | #30 |
that is awesome
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
04-15-2012, 08:29 PM | #31 | |
04-16-2012, 12:27 PM | #32 |
Looks good! I am doing the same thing with my 75 C20. Quick question about your front clearances. How far is your crossmember and lower control arms from the ground? Do your tires hit the fenderwells? Thanks!!
Posted via Mobile Device |
04-17-2012, 11:32 PM | #33 |
yes the tires hit the inner fenders, but thats no problem, i'm getting 20's soon. the crossmember is 9in off the ground, and the bottom of the a-arm is at 6.5in from the ground.
04-17-2012, 11:34 PM | #34 |
so, i have a quick question, is the 3/4 rearend width the same as a 1/2 ton width? im trying to narrow down my offset possabilities for my wheels.
04-18-2012, 01:10 AM | #35 |
Very nice......doing something simular with my crew cab 1 ton. Looks like you got a bit lower on the front than I did though. My A arms are not quite level on the bottom. Keep up the great work, and staying tuned to progress.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
04-18-2012, 01:22 AM | #36 | |
04-18-2012, 01:37 AM | #37 |
Sounds like you have some good plans for your truck. My 1st truck was a 76 GMC 3/4 Sierra Grande. That was back in high school. Lowering a 3/4 is deffinately differant and unique. Good luck with you build.
04-18-2012, 10:27 AM | #38 |
What shocks are you going with on back?
04-18-2012, 12:38 PM | #39 | |
04-18-2012, 12:43 PM | #40 | |
04-18-2012, 08:56 PM | #41 |
i used Gabriel part #82007
on the rear of my truck after i dropped it got em at autozone |
04-18-2012, 09:23 PM | #42 |
how much of a drop do you have?
04-18-2012, 11:11 PM | #43 |
Well not sure really i have 2 inch drop hangers 2 inch drop shackles and i bought some used drop leaves so probably like six or seven im not sure how much the leaves dropped it
04-19-2012, 04:51 PM | #44 |
i have no idea, just measure it and i can tell u. is it a 10" 14 bolt?
"As I walk through the valley of rice i fear no honda, for i have torque!" |
04-19-2012, 06:43 PM | #45 |
yeas its a 10in 14bolt. i measured from the outerpart of the drum wheere the back of the wheel mounts to. its about 61.5in
04-21-2012, 12:16 AM | #46 |
UPDATE: went to put the c-notches in a few days ago, and found out the one side was wrong. their was no room for the shock. i emailed the company, and they never got back to me, so i just said to heck with it, and i cut it off and made it work. so tonight i got the frame cut and both notches put in. tommarow the bed should be on, and i'll be able to see the actual drop.(i measured from wheelwell down to the ground before lowering.
04-21-2012, 12:19 AM | #47 |
some pics
04-22-2012, 07:39 PM | #48 |
i dont know whyi was so off, but i just checked my measure ments, and i have a 8.5/9in drop. i only have 2in of clearane at the a-arms
04-22-2012, 09:17 PM | #49 |
Update: 8.5/9in drop. i put the box on yesterday. last pic is with my DD
04-22-2012, 09:23 PM | #50 |
now that sunflower is sweet. hahaha jk i love the stance of the truck! whatd you put smaller tires on the rims that came on the truck?
