04-11-2012, 03:16 PM | #26 |
Junior Member
Re: My Coy's came today!
Grinding the rotor will fix your problem, the weird thing is I have one set that needed the rotor ground and the other did not, I bought both sets used. The burb's just bolted on.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-11-2012 at 03:21 PM. Reason: add info |
04-11-2012, 04:28 PM | #27 |
Do you have an early rear housing under it? If you measure from backing plate to backing plate, how wide is it? 55.5" or 57" ?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-11-2012, 06:01 PM | #28 | |
Still Learning
I don't have any at the time but may be something I will consider making again in the future. SPACERS CAPS |
04-11-2012, 06:09 PM | #29 |
Junior Member
I'm fairly certain it's the wider rear axle but I never actually measured it. Another clue is I don't think the wheels would tuck aired out (bags someday) if they stuck out another 3/4"
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
04-11-2012, 07:28 PM | #30 |
Old member
stomper, sorry it took so long to get back to you.
those were the problems I was thinking of. They said they were fixed. I guess not. I went with the Boss 383's wheels. No problems after they grinded the front hub just a little and 1/2" spacers on back for wheel well clearance.. I also put 1/2" spacers on back and bought 10 new lug nuts for it that had a deeped shank.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 04-16-2012 at 04:47 AM. |
04-11-2012, 10:41 PM | #31 |
Junior Member
UPDATE:
FRONT: Ground the edge of the rotor/hub. No problem. Before After REAR: I actually have a little more than an inch inside. ............and also here's where the outside of the lip lands inside the wheel well.
04-11-2012, 11:04 PM | #32 |
Old member
Here are my pictures hub grinded with tires mounted in above pictures above.
My back only rubbed when I would hit holes in the road. Hub grinded and painted. Before spacer. After.
04-16-2012, 12:32 AM | #33 |
Junior Member
Just made my weekend deadline!
Before and After The rear tire bulge is only about 1/2" so the clearance concern I had on the inside rear is fine. The taller rear tires gave it more rake than I care for. I'm going to install 1-1/2" blocks to make it more to my liking. Will still be able to run the 15" rallys. Then I'll probably need bags to bump it back up when I have the rallys on. 255/40 front and 295/40 rear. My favorite shot
04-16-2012, 04:49 AM | #34 |
Old member
Looks sweet!
04-16-2012, 06:05 AM | #35 |
Look great love my coy's
Posted via Mobile Device |
04-16-2012, 07:03 AM | #36 |
They look killer! I just ordered the same size wheels with toyo tires for my project... How does it drive with your new tires?
04-16-2012, 07:08 AM | #37 |
How does it ride.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-16-2012, 07:09 AM | #38 |
Looks really nice man! Great job. I haven't decided 100% but this same wheel is at the top of the list for my GMC.
04-16-2012, 08:22 AM | #39 |
Still Learning
Nice work modifying the rotors. They new wheels look great. Can't wait till I get mine.....one of these days.
04-16-2012, 08:47 AM | #40 |
68 C 10
Looks Killer... I saw 67Anthony"s truck at the super chevy show in Memphis I was highly impressed Sir thats one good looking truck hope to see it again at showfest in tunica.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
04-19-2012, 05:26 PM | #41 |
Junior Member
Don't really know yet. Funny thing happend...
Scroll down to post #23 http://67-72chevytrucks.com/vboard/s...d.php?t=491652
04-23-2012, 03:13 PM | #42 | |
Junior Member
04-24-2012, 12:32 PM | #43 |
got the cad file to have 1/4" thick spacers made so you dont have to grind the hubs. free to anyone who wants a copy. email me at
fatboys6969@gmail.com and I will send it to you. I used 1/4" aluminum on mine. works great !!! |
04-27-2012, 05:34 PM | #44 |
Junior Member
Now with 1-1/2" lowering blocks so I guess it's a 4/7.5 drop.
04-27-2012, 05:55 PM | #45 |
67-72 parts collector,…
Looks great!^^^
04-27-2012, 06:03 PM | #46 |
Nice!!
04-27-2012, 08:42 PM | #47 |
Looks really nice!
04-27-2012, 08:57 PM | #48 |
67cheby
Nice !
04-27-2012, 08:57 PM | #49 |
Yes! looks perfect. I know each truck is different but I bet mine will need blocks too. Glad to here the ride is good with those tires/wheels. I can't wait to get mine going.
What's next for your truck? |
04-27-2012, 11:23 PM | #50 |
Still Learning
The stance and wheels look great!
