Old 04-17-2012, 12:49 AM   #26
1956chevtruck
1956chevtruck's Avatar
Re: smooth firewall
Originally Posted by Dan in Pasadena View Post
1956chevtruck - What's your color? Very, very nice.
Hey Dan, It's the original 57 Chev colors, Indian Turquoise and Bombay Ivory. The day that the cab was outside, in the first picture, it was pouring rain and my buddy and I wet sanded with 600 grit and dish soap for 6 hours. You can see the rock guard on the bottom half of the firewall. I did rock guard all under the cab and inside of all of the fenders and then we sprayed body color over top.
Last edited by 1956chevtruck; 04-17-2012 at 12:55 AM. Reason: To add some more info
1956chevtruck is offline   Reply With Quote
Old 04-17-2012, 06:01 PM   #27
Dan in Pasadena
Dan in Pasadena's Avatar
Re: smooth firewall
Hey, if it was raining hard enough you wouldn't have to use a hose! lol.
Seriously, it looks fantastic. I'm nowhere near final paint but I fantasize. I like red and orange and they look great - heck, that's why so many guys do. BUT, I also like turquoise because it is so era-correct and not a common.
What brand/type rock guard did you use? Rattle can stuff or did you shoot it with a Schutz type gun? Did you paint the cab yourself? Seems liek "6 hours" of color sanding would go through a LOT of paint. I ask if you painted it yourself because I'm wondering if there was a lot of debris, bugs, etc from an at-home spray job? Regardless, it looks truly great. Any detail photo on your radiator cover? I LOVE the color coordinating pinstriping on it. Congrats on a beautiful truck.
Dan in Pasadena is offline   Reply With Quote
Old 04-19-2012, 07:44 PM   #28
1955 Eddie
1955 Eddie's Avatar
Re: smooth firewall
I like it all smoothed out. Here is a pic of my firewall with the 1 piece metal sheet like you mentioned.
1955 Eddie is offline   Reply With Quote
Old 04-19-2012, 08:24 PM   #29
Rude Dude
Rude Dude's Avatar
Re: smooth firewall
Very nice me like!!
Rude Dude is offline   Reply With Quote
Old 04-19-2012, 09:36 PM   #30
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: smooth firewall
Originally Posted by Russell Ashley View Post
Dan, I'm more into function than looks with this truck. Not many people will ever see under the hood of my truck any way. I used self drilling screws and black cable mounting ties to hold that part of the harness up along the ridge. The green looped wire is for an under hood light that I will add eventually.
Looks nice Russell, really like the Tu-tone color combo!
ChuckDriver is offline   Reply With Quote
Old 04-19-2012, 09:40 PM   #31
ChuckDriver
Re: smooth firewall
Originally Posted by Rude Dude View Post
I used elevator bolts to fill a lot of the big holes, I did this to give me studs on inside to run wire retainers and future A/C attachment points, what ever I don't use I can hack the stud screws off.
Elevator bolts! Did the same thing on mine!
Old 04-19-2012, 10:16 PM   #32
papastrk
Re: smooth firewall
Wow!!!!
papastrk is offline   Reply With Quote
Old 04-19-2012, 10:21 PM   #33
Dan in Pasadena
Re: smooth firewall
Whew Eddie, that's beoootiful!
Did you cut out the original or just overlay it with one piece?
By the way, what the hell is an "elevator bolt" and why use that as opposed to any other kind of patch?
Old 04-19-2012, 10:30 PM   #34
Rude Dude
Rude Dude's Avatar
Re: smooth firewall
Here you go Dan look at my build you can see them on the inside
Old 04-19-2012, 10:46 PM   #35
Dan in Pasadena
Re: smooth firewall
Hi Rudy,
So basically the head is just a big flat washer? Are they pricy? Cause it seems like a fender washer would work as well....of course you'd have to use magnets to hold it initially and it would still have a (much smaller) hole in it. Only worth it I suppose if the price difference is a lot. Are these a Home Depot, Lowes item?
Old 04-19-2012, 10:54 PM   #36
Rude Dude
Rude Dude's Avatar
Re: smooth firewall
I seen 1/4 20 threads by 1 1/2 long on egay for 100 for $25 dollars. Fender washer has a center hole you gotta weld up, plus you can hold stud from inside by your self.
Hi Rudy,
Old 04-19-2012, 10:55 PM   #37
1955 Eddie
1955 Eddie's Avatar
Re: smooth firewall
Thanks Dan. I welded the seems from inside the cab and cut the lip off of the firewall. Then welded a 1 piece overlay on top of the original.
Old 04-20-2012, 12:18 AM   #38
Dan in Pasadena
Re: smooth firewall
... plus you can hold stud from inside by your self.
Any reason you want to weld from the inside instead of from the outside? You're gonna cut off the stud, grind and fill the visible side anyway, right?
Eddie, Thanks for the info. That one piece made for a LOT of welding huh? It came out beautful so you must be a pretty damn good welder! Congrats.
Old 04-20-2012, 08:05 AM   #39
Russell Ashley
Russell Ashley's Avatar
Re: smooth firewall
Thanks, Chuck. The light blue color is 57 Chevy Larkspur Blue. Eventually the whole truck will be that color so I painted the firewall while I had the engine and wiring out.
I love your truck, BTW. That dash is perfect. You once said that you might not paint your truck for a long time and that was when I made the decision to skip the new paint for now and get it driving and enjoy it like it is for a while.
Russell Ashley is offline   Reply With Quote
Old 04-20-2012, 09:14 AM   #40
Rude Dude
Rude Dude's Avatar
Re: smooth firewall
Dan, I tack weld on the inside first than full weld on the outside next, just try it on a big hole much easier you'll see. Like i said before the studs give a place for inside ABS firewall cover to be bolted in instead of those pesky clips and you can hang wire clamps to hold wires and studs for A/C mounts.
Old 10-25-2013, 10:46 PM   #41
SCHRUMGMC
SCHRUMGMC's Avatar
Re: smooth firewall
Same thing I was wondering
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 10-26-2013, 03:17 AM   #42
47 Fasttoys
47 Fasttoys's Avatar
Re: smooth firewall
I went the flat fire wall and floor approach, if you don't need the recess this will make it a bit easier when it comes to insulation and carpet. Mine is not done yet but you get the idea.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-28-2013, 08:11 PM   #43
Donaldo
Re: smooth firewall
I am in the process of filling in the firewall holes on my '51.
I still have 4 bolts with nuts on the upper drivers side, 2 hold the windshield wiper bracket and 2 for the dash brace.
Would there be a problem with removing the nuts and washers, 1 at a time, and welding them in ? I don't see any reason to ever remove either piece.
thanks, Don
Donaldo is offline   Reply With Quote
Old 10-31-2013, 06:45 PM   #44
Bernman72
Re: smooth firewall
I just cut new pieces and welded in over old fire wall.
Bernman72 is offline   Reply With Quote
Old 10-31-2013, 07:01 PM   #45
FarmerSid
FarmerSid's Avatar
Re: smooth firewall
thanks, Don
I'm in the same boat. I think I'm going to split each brace and reattach them with flat bar and bolts so they can be removed. The 4 bolts will be welded in from under the dash and smooth on the firewall.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 10-31-2013, 07:15 PM   #46
Donaldo
Re: smooth firewall
Hi, it seems the 4 bolts are threaded rivets, so what I decided to do, since the cab is stripped, I mig welded both braces from the backside, then took the nuts and washers off and welded from the engine side - they aren't going to move. Some grinding and filling and it should be smooth should be....
thanks
Old 10-31-2013, 09:01 PM   #47
fabguy
Elev8r Man
fabguy's Avatar
Re: smooth firewall
Dan I know an elevator guy who has a TON of those in 1/4-20 if you need some. hehehe
This is one BEAUTIFUL firewall. congrats on the truck.
this is the same way I did mine except I had drilled the hood hinge bolt holes 1st.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 11-01-2013, 08:38 AM   #48
L_Brown
L_Brown's Avatar
Re: smooth firewall
I was thinking about one of these.
Here is an article about it.
http://www.customclassictrucks.com/t...t/viewall.html
Larry Brown
North Texas
My 1956 Build - Huff Truck
http://67-72chevytrucks.com/vboard/s...48#post6308448
L_Brown is offline   Reply With Quote
Old 11-01-2013, 03:43 PM   #49
_Ogre
_Ogre's Avatar
Re: smooth firewall
yes you can buy a panel, but why waste the money?
other than welding wire i have $zero dollars in this.
shaving the standing seam is also painless and cheap, cut it out and weld it closed.
save your money for those needed suspension upgrades and go low buck
shop air compressor timer
