#26 |
![]() Join Date: Jan 2007
Re: Headers
I was staring at the drawing, but didn't read the text; now I understand the theory. The heat causes additional wire resistance. Thanks again for the link.
#27 |
Re: Headers
I run hooker Competition Headers on my 85 burb 4x4, and on my '71 C10. I run a mini-starter on both trucks, and have never had a heat soak issue. Hooker is by far the best headers I have ever ran. Gaskets seem to last a LOT longer than I experienced with the cheaper brands. And I like the flat flange on the collectors, as opposed to the ring and flange some companies use.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
