Old 05-30-2012, 11:47 PM   #26
Tinkermc
Re: 69 short bed
gotta love that shop clean or dirty
Tinkermc is offline   Reply With Quote
Old 05-31-2012, 12:07 AM   #27
TYoder
Re: 69 short bed
Thanks guys, I appreciate all the positive comments.
1969 C10 425hp Shortbed
My build:
http://67-72chevytrucks.com/vboard/s...=520406&page=3
TYoder is offline   Reply With Quote
Old 05-31-2012, 12:16 AM   #28
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 69 short bed
I struggle to keep my smallish 2 car garage organized much less clean. I've wanted to do this to the floor but I'm not sure I could do it all at once vs doing in 2 parts...just too much stuff to move out at once.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-31-2012, 12:35 AM   #29
TYoder
Re: 69 short bed
You can do it in two parts, that is what I was going to do. I got about 2/3 done and the epoxy started setting up, (its a lot faster if you have someone going behind you spreading the flakes which I did not have). So I mixed up another can to finish it. You can see the transition between the two, not happy with it but life goes on. It should blend in better once it dries fully.
My build:
Old 06-07-2012, 05:56 PM   #30
TYoder
Re: 69 short bed
Well, the frame is back in the shop. Man does it look different, is so glossy it looks wet. Right now it is upside down.....I have some work to do.
My build:
Old 06-09-2012, 10:42 AM   #31
RCbowtie69
RCbowtie69's Avatar
Re: 69 short bed
Looking good,your shop is nice.Hope to see more pictures of your progress soon,keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 06-11-2012, 05:29 PM   #32
TYoder
Re: 69 short bed
Thanks man, my gears are turning. I'm picking up new grade 8 bolts to bolt the front cross memeber back in. Then im drilling out the bolts for the rear coil over's
Has anyone built any kind of trans cross memeber that bolts to the frame but then extends further back parallel to the frame to help strengthen the rest of the frame. I noticed while moving this frame around that is shakes and wobbles like crazy.
My build:
Old 06-13-2012, 11:27 PM   #33
TYoder
Re: 69 short bed
I stripped the axle down today, I had to cut the bolts that bolted the axle to the trailing arms. Its all stripped down, ready for powder coating.
My build:
Old 06-14-2012, 10:54 PM   #34
TYoder
Re: 69 short bed
Today was a big day, I got the rear end to the powder coater and picked up my intake that I had media blasted. Then took the motor to the machine shop. I seriously tweaked my back lifting the motor into my truck, I'm getting to old for this stuff (26 yrs lol). I'm pretty excited to get the motor back.
My build:
Old 06-18-2012, 11:06 PM   #35
TYoder
Re: 69 short bed
Edelbrock Performer rpm with edelbrock 600 carb. This may be a temporary set up, that I will end up using on another project, It just depends.
My build:
Old 06-20-2012, 03:29 PM   #36
TYoder
Re: 69 short bed
The motor is coming along. 350, punched .030 over. 6" rods, hypereutectic pistons, dart pro 1 64cc 180cc intake runner cylinder heads, arp studs, scorpiton 1.5 roller rockers. 10.14 compression. balanced factory crank, decked block. Needless to say im pretty excited.
My build:
Old 06-20-2012, 09:54 PM   #37
Gus350
68 C 10
Gus350's Avatar
Re: 69 short bed
Sounds like a thumper motor for sure I can't wait to see the rear end can't decide Id I want powder coat mine or not. Keep up the good work.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-22-2012, 12:36 AM   #38
TYoder
Re: 69 short bed
Thanks man, It should be pushing right around 400 hp, which is plenty for these trucks. As far as the powder coating its a no brainer for me. To media blast, bake, and shoot the powder it ran me $100. Speaking of that, it should be ready soon.
I have been looking at all the manufactures that specialize in rear end components, and I think I have settled in on moser for the parts.
http://www.moserengineering.com/axle...spline-31.html
http://www.moserengineering.com/othe...evy-truck.html
http://www.moserengineering.com/othe...-stud-kit.html
http://www.moserengineering.com/othe...-gm-truck.html
My build:
Old 06-22-2012, 05:41 PM   #39
Tinkermc
Re: 69 short bed
I love it when a plan comes together
Old 06-24-2012, 06:10 PM   #40
TYoder
Re: 69 short bed
Here is the short block, just waiting for the heads and the rest of the parts.
My build:
Old 06-24-2012, 07:30 PM   #41
67cheby
67cheby
67cheby's Avatar
Re: 69 short bed
Looking good , frame looks slick !
67cheby is offline   Reply With Quote
Old 06-24-2012, 09:54 PM   #42
Tinkermc
Re: 69 short bed
lookin good
Old 06-25-2012, 08:19 PM   #43
TYoder
Re: 69 short bed
I got some stuff in today, I guess the heads are going to be a few weeks. Let the madness begin.
My build:
Old 06-25-2012, 08:24 PM   #44
TYoder
Re: 69 short bed
These rockers are beefy.
My build:
Old 06-25-2012, 09:29 PM   #45
TYoder
Re: 69 short bed
I inspected the rear differential. Dana 44 with 3.73 gears, going to put it all together once the motor is completed.
My build:
Old 07-05-2012, 08:18 PM   #46
TYoder
Re: 69 short bed
We just got back on a fishing trip in Colorado, we caught a few monster trout.
My build:
Old 07-18-2012, 08:29 PM   #47
TYoder
Re: 69 short bed
What your looking at are dart pro1 aluminum heads with guides, arp studs, and scorpion 1.5 roller rockers. I'm liking the weight savings.
My build:
Old 07-19-2012, 08:13 PM   #48
TYoder
Re: 69 short bed
My build:
Old 07-20-2012, 07:51 PM   #49
Tinkermc
Re: 69 short bed
when can we hear it run?
Old 07-20-2012, 10:29 PM   #50
TYoder
Re: 69 short bed
Not yet, but working on it. Finishing up the motor, then working on the suspension.
My build:
