Old 04-21-2012, 01:07 PM   #26
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Manifolds on a 80s 350
Thank you. My mind was fonna melt with all these threads haha
Back to topic. Corvette manifolds won't flow any better than most. Now you have the small tube bottom of the grid quality headers. I know I used to have them. Get headers like these.
They are hooker headers. I found them on Craigslist for 40 dolla
Then use these http://www.jegs.com/i/Mr-Gasket/720/...oductId=748863
And use these http://catalog.remflex.com/CHEVROLET...t_p/rf2006.htm
Add your hpipe and you should be set. I daily drive my truck and have only touched the headers a few times. The first was after install and a drive I retightened them afterwords. Then a few times after just to check
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-21-2012, 11:36 PM   #27
mattpiotr
anybody have this problem with headers?
I keep burning the wire on the pipe. i think my first problem is that they are cheap flow tech headers. does any body have a solution? i already headed up the pipe and punched a dimple in the pipe and that still didnt help with cleanence. or is their another set of headers that route different? i want to put new headers on it staying under $200
mattpiotr is offline   Reply With Quote
Old 04-21-2012, 11:44 PM   #28
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: anybody have this problem with headers?
Maybe these will help:
http://67-72chevytrucks.com/vboard/s...d.php?t=520515
http://67-72chevytrucks.com/vboard/s...d.php?t=520374
http://67-72chevytrucks.com/vboard/s...d.php?t=520375
http://67-72chevytrucks.com/vboard/s...d.php?t=519798
http://67-72chevytrucks.com/vboard/s...d.php?t=520072
http://67-72chevytrucks.com/vboard/s...d.php?t=520000
http://67-72chevytrucks.com/vboard/s...d.php?t=519881
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-21-2012, 11:49 PM   #29
mattpiotr
Well i ordered new hooker headers to being with and they are routed the same way so i have no clearance between that pipe and that plug and wire, i didnt know if maybe another brand made headers that were routed differently or something if you get what im saying
Old 04-21-2012, 11:51 PM   #30
Pop's C-10
Pop's C-10's Avatar
take em off & dimple that pipe in that spot..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-21-2012, 11:54 PM   #31
my4by2
my4by2's Avatar
You can try the Accel shorty header plugs to start with - that'll bring the wire end closer to the block & off the header tube. Secondly you can get some heat wrap for the plug wire ends - they sell them for any wires.
Lastly you could either have your headers ceramic coated - or go more budget-friendly & spray them with some rattle can high-temp coating.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-21-2012, 11:56 PM   #32
mattpiotr
Thats something to think about Thank, and i put the accel plugs on it.
Old 04-21-2012, 11:58 PM   #33
my4by2
my4by2's Avatar
There's always the option of putting a little "dimple" in the tube also - not my favorite option...
Old 04-22-2012, 10:29 AM   #34
turbo350
I wish I could find it now to post up but it was either Car Craft or Hot Rod did an article several years ago about a company that sells hogged out manifolds that flow almost or just as good as headers yet dont have the rowdy sound.
Some guy used a similar set of manifolds on a 11 second sleeper Malibu or Chevelle.
turbo350 is offline   Reply With Quote
Old 04-22-2012, 10:51 AM   #35
Firebirdjones
You can use your own manifolds with a few tricks.
When I ran Pure Stock (which per rules requires stock manifolds hence the title Pure Stock) guys were starting to cheat by extrude honing the manifolds (among other things) hence the F.A.S.T. series was born.
Extrude honing is nothing new, but if you want the stock look and decent flow, hand port them and gasket match then send them off to Extrude Hone. All the F.A.S.T. guys have been doing it since the beginning and are now dipping into the 9's at 140 mph (on bias plys no less )
Firebirdjones is offline   Reply With Quote
Old 04-24-2012, 01:05 AM   #36
motornut
78K & 79C Jimmys
motornut's Avatar
my new word for the day
http://www.extrudehone.com/auto/auto-performance.php
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-24-2012, 10:03 AM   #37
Firebirdjones
That be them,,,,:d
Old 04-24-2012, 12:32 PM   #38
motornut
78K & 79C Jimmys
motornut's Avatar
if you don't cut and seperate the exhaust header tubes before tightening to the head or
with stock manifolds, do the middle cylinders first
then the outsides not from the front or back.
a plus, sometimes if you get pulled over,headers they keep looking
manifolds look "stocker" ,last longer up here
headers don't last long in the winter,sitting or driving
but thats a salt issue
John
Old 04-29-2012, 02:22 AM   #39
bowtiemanchevyman
bowtiemanchevyman's Avatar
On my truck I run flowtech and I’ve never had a wire problem. I’ve had mine for ten years now and never burned a pair. I replace when they get old but I’ve been using the same wire looms. You just got to route them right and take the time to do it right. I make my set with a universal set from Accel.
bowtiemanchevyman is offline   Reply With Quote
Old 04-29-2012, 08:03 AM   #40
88Jimmy4x4
88Jimmy4x4's Avatar
you can also use 90deg boots and instead of running them up to valve covers, run them down like the old corvette engines which used clips off the oil pan bolts to hold the wires. Gives a clean look as well.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-29-2012, 11:23 AM   #41
rayfinseats
Speedway has ramhorns on sale for $3o each. I have ramhorns on my 83 K10. Ramhorns flow almost as well as cheap headers on a stock engine and a lot less problems. Check Speedway for ramhorns. They have a big selection.
rayfinseats is offline   Reply With Quote
Old 04-29-2012, 11:46 AM   #42
bilfman
bilfman's Avatar
MSD sells a straight boot that is bendable, this gets them away from the headers and keeps em there. I have always ran headers, from the cheapies to the $$$ ones and never had an issue that could not be remedied.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
