Old 08-10-2013, 11:35 PM   #26
theastronaut
theastronaut's Avatar
Re: 6000 rpm tach anyone...
The truck will eventually have a destroked LS2 with solid lifters and shaft rockers so it'll do 8k easily. Got the 120 mph speedo covered too, and then some! I photoshopped a 160 mph speedo and sent it to Jason at Greenback so he could make the artwork and have his screen printing guy make a lens. Still waiting to get it back, this is just the photoshopped pic.
theastronaut is offline   Reply With Quote
Old 08-12-2013, 09:00 AM   #27
earl84
Well, I got it installed. Here's a pic. It took a lot of head scratching and figuring, but it's in. Now to finish the gauge cluster, just about there.
I also replaced the ammeter with a voltmeter, that I read from RoyL here, http://67-72chevytrucks.com/vboard/s...d.php?t=443318 , changed the Tand'm Lock light to a Park Brake light for a future modification from jocko that I read about here, http://67-72chevytrucks.com/vboard/s...d.php?t=419932 , did some restoring on the cluster that I read about from the astronaut here, http://67-72chevytrucks.com/vboard/s....php?p=5806390 . Didn't do a full restore with new decals, trying to keep it a little worn looking for a daily driver. Maybe I will later when/if I do a full restore.
I am trying to attach the file that I got from Persh's web site. I did modify it to make it a 6K RPM tach face that looks similar to factory. If you use it, it will require some trimming. I printed it on some see through labels I got at Staples, Avery Clear Full Sheet Label, product #18665. The first label I could sort of see through, and the numbers that were over the inverted "T" of the factory backing plate showed through. So I painted it the Krylon Jade Green and tried again. I think it looks pretty good for a complete rookie.
Hope everything on the gauge cluster works now.
earl84 is offline   Reply With Quote
Old 08-12-2013, 09:08 AM   #28
earl84
Hmm, document didn't show up. Try again.
Old 08-12-2013, 04:16 PM   #29
earl84
Got it all put back together. Sorry for the crappy pic.
Old 08-12-2013, 05:27 PM   #30
par4tom
Don't apologize...that thing is BEAUTIFUL!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 08-12-2013, 05:30 PM   #31
theastronaut
Neat trick with the Avery label and green background! Looks great!
Old 08-16-2013, 12:19 PM   #32
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been reading up on vinyl waterproof inkjet printing paper.
There's YouTube videos that demonstrate how to make stickers and decals.
It appears it wouldn't be that difficult to reface.
66 C20 Service Truck:
Old 08-16-2013, 06:00 PM   #33
LostMy65
LostMy65's Avatar
Originally Posted by earl84 View Post
Hey, chevysdominate, can you share any more details on how you did this? It looks SO NICE. And I do like your execution of it better than the original article you used as a reference. Would love some more details if you have the time.
Incidentally, that tach is available at Carquest, P/N 81316, $59.99 online.
That Tach you list appears to be 2" Diameter.
I think we need Part Number: 81315 - Price: $72.99
Old 08-17-2013, 10:20 AM   #34
earl84
LostMy 65, the one I used and installed was indeed the 2 inch, P/N 81316. Chevysdominate referenced the original article that he modified and it used a 2 inch tach as well.
Basically, all you use is the guts of the tach, you take it completely apart and use your own blank plate out of your dash and screw the guts to it after slight modification. It fits well. You also end up having to trim down the inner case and the black exterior case to screw on the back.
Also, I wish I would have done a little more research on the decal material on Youtube, dang it. I think it would have been much easier to print on a different material, like that vinyl waterproof inkjet printing paper, but it did work out OK. Still like how mine turned out in the end, but did have to paint the blank plate the Jade Green to get it to look right, as I wrote up.
Old 08-17-2013, 11:15 AM   #35
LostMy65
LostMy65's Avatar
^ I missed that about you guys using the 2" one.
Old 01-17-2014, 01:57 PM   #36
Rich 5150 69
Rich 5150 69's Avatar
Just picked up this tach for my install, its a no name but its believed to be a Sun tach by all markings on it, a fleabay item broken lens and mount which was fine, seller did say it worked, cost me all of $15.00 so if it dosen`t not much of a loss, its actually a two inch gauge stuffed into a 3.5 inch pod as shown after removal from pod, three wire hookup, hot, ground, and pickup.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-01-2015, 09:25 PM   #37
Grandpa54
Grandpa54's Avatar
Originally Posted by theastronaut View Post
thanks for posting this, i wanted a tach that went to 10k and looked stock but didn't know how to do it... So i paid to have one made. I like to do stuff myself though so this is good info for the next project!
Here's mine, jason at greenback decal built it from a block-off plate.
theastronaut, do you mind sharing who did your tach
Grandpa54 is offline   Reply With Quote
Old 06-01-2015, 11:24 PM   #39
Chevysdominate
Chevysdominate's Avatar
Looks good! I cant believe i missed so much of this thread.
Chevysdominate is offline   Reply With Quote
Old 07-11-2015, 08:46 PM   #40
McStuffin
To revisit an old thread... has any company decided to make a decal set to have a 6000rpm tach?
McStuffin is offline   Reply With Quote
