Old 05-09-2012, 02:08 PM   #26
gringoloco
A guy with a truck
gringoloco's Avatar
Re: L59 fuel question
Cannot reuse head bolts on these motors. They are one time use, torque to yield, stretch fasteners. Same for the crank snout/balancer...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-14-2012, 09:17 AM   #27
faribran
but you can pull a spark plug and shine a flashlight in the hole to see if the top of the piston is flat or dished. Flat is 5.3, dished is 4.8.
?? opposite ??
faribran is offline   Reply With Quote
Old 05-14-2012, 01:11 PM   #28
ls1nova71
ls1nova71's Avatar
?? opposite ??
Actually you're right it is the opposite. My old age is catching up with me!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-18-2012, 11:39 PM   #29
osaltyone
osaltyone's Avatar
I can't see anything but black when I put the light in the spark plug hole. Spent a few hours putting the engine on the frame and ...
found this today
Is this is the tab you mentioned before?
Originally Posted by gringoloco View Post
Check the head gasket tab to verify displacement. It will be stamped with 4.8, 5.3, 6.0...
I think I am going to call the guy tomorrow and talk to him. Things are not adding up. I will tell him I will be pulling the head to see if it is a 4.8 or 5.3. The computer came back as a 2006 tahoe with a 4.8 that was salvaged, which he says he just pulled off the shelf, and the vin he gave me was for a 2006 Tahoe, but the mileage did not match what he said. He said it was just under 58k and the vin says last reqistered in Ohio at 23k, nothing about a salvage.
osaltyone is offline   Reply With Quote
Old 05-18-2012, 11:42 PM   #30
osaltyone
osaltyone's Avatar
Does this look like a windage tray from a truck that had 23 or 58k miles on it? Pulled the pan, windage and pickup to put a LS1 pan on.
Old 05-18-2012, 11:46 PM   #31
85burb
85burb's Avatar
On the back of the motor there should be 4.8 and 5.3 stamed in to it. There will be an paint mark one the displacement it is
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-19-2012, 11:51 AM   #32
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I haven't seen a motor that the head gaskets were wrong. No tabs or not stamped, yes. What numbers can you find on the crank? Those will tell what you have for sure.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-19-2012, 01:58 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
At this point just call the guy, even if it MIGHT be what you thought you wanted....sounds like he isn't the most legit guy anyway.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-19-2012, 06:06 PM   #34
ls1nova71
ls1nova71's Avatar
Do you have a pic of one stamped 5.3? I checked 4 of mine and they all say 4.8, but I know the truck that at least one of them came out of was a 5.3.
Old 05-19-2012, 10:50 PM   #35
usmcchevy
usmcchevy's Avatar
Nope, Let me rephrase. I have not personally seen one that was stamped wrong.
Build thread
LSx Swap FAQ index
Old 05-20-2012, 09:43 AM   #36
ls1nova71
ls1nova71's Avatar
I was just thinking that since a 4.8 and 5.3 use the same block and bore size that the head gaskets would be the same also.
Old 05-20-2012, 02:01 PM   #37
osaltyone
osaltyone's Avatar
Talked to the guy today and he says it is a 5.3 to pull the head and see. Says he does not have a 4.8 in the yard... Got to figure out how to start this thing b4 I pull the heads. Where can I get one of those starter buttons to hook up to this? I am pretty much ready to fire it up, make sure it runs then I can pull the head.
Harness was rewired, PCM was flashed (will need a crank relearn).
Old 05-21-2012, 02:32 AM   #38
osaltyone
osaltyone's Avatar
According the the crank #'s it is a 5.3, so I am not pulling the heads quite yet. I don't want to spend the cash on the gaskets and bolts if I don't have to.
12552216 are the #'s I see.
Old 05-21-2012, 10:04 AM   #39
mooseknuckles
mooseknuckles's Avatar
....are the blocks not stamped with the displacement on the front cyl, like the 6.0l??
mooseknuckles is offline   Reply With Quote
Old 05-21-2012, 11:28 AM   #40
ls1nova71
ls1nova71's Avatar
They have both 4.8 and 5.3 cast into them because they use the same block, and as mentioned earlier there is usually a white paint mark on which ever one it is.
Old 05-21-2012, 03:09 PM   #41
mooseknuckles
gottcha...
Old 01-31-2013, 06:32 PM   #42
solidaxel
solidaxel's Avatar
So how did the story end !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-02-2013, 02:53 AM   #43
osaltyone
osaltyone's Avatar
Never was able to get the true mileage on the motor. I have about 200miles on it now. There are always the little things you have left, but the swap is complete for now.
I have to say I would do it again on my next project. This motor runs circles around the old tired 305 that was in it. I couldn't have done it without all the help from this forum though. Thanks! I learned a lot on this one.
Old 02-02-2013, 08:03 AM   #44
solidaxel
solidaxel's Avatar
Well, thanks for bringing us up to date!!
Why are you not putting more miles on your ride?
These hotrods were made to drive, with all the work and money we throw at them !
LS 3 4L70E
Old 02-02-2013, 11:27 PM   #45
osaltyone
osaltyone's Avatar
I built it as my project, to see if i could do it on my own.it's not my daily driver. The bench seat won't fit my family.
