06-12-2012, 02:35 AM | #26 |
GM Addicted
Re: Red rebuild
Looking good man. You still trying too make it for brothers show?
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
06-12-2012, 03:26 AM | #27 |
VA72C10
Re: Red rebuild
Looking good! Sorry about the engine size and the door but looks like a great build!
Looking for a 67-72 swb or blazer project in or around VA. |
06-14-2012, 12:38 PM | #28 |
Re: Red rebuild
Trying to make Brothers. I am registered, but soooo much to do, not sure if I can.
Crank #'s turned out to ba a 5.3, so I am good there. Posted via Mobile Device |
06-14-2012, 01:25 PM | #29 |
Re: Red rebuild
Very nice truck man. that really does suck about the door. Looking forward to seeing more.
06-27-2012, 02:03 PM | #30 |
Re: Red rebuild
Been busy...trying to make the show, but time is running out. Got most of the wiring done, waiting on a few things. My biggest issue right now if my pedal/tac combo not working...
PCM mounted and almost done wiring Had a mobil hydraulic hose company build me 2 trans lines to run to the C10 radiator Picked up a new pigtail for the alternator, have to figure out which one wire to hook it up to. |
07-06-2012, 03:55 PM | #31 |
Re: Red rebuild
Well... had the PCM reflashed to be an older model and still no luck... Can't drive it, but can still work on it.
Got the bed back on and cleaned up that area. Had a wire break off on one of my valves, so I have to find another... Reinstalled the pass fender in attempt to install the new Slosh Tubz, but they look like they will hit and need some trimming. Painted the underside since they are raw fiberglass. All they way up just sitting there. |
07-06-2012, 04:42 PM | #32 |
Re: Red rebuild
the slosh tubs look good man.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
07-20-2012, 11:35 PM | #33 |
Re: Red rebuild
How's the project coming?
07-22-2012, 12:37 AM | #34 |
Re: Red rebuild
Been on hold for a bit. I have been out of town. Just got back and will get back into gear full steam. Picked up a throttle body from CL while I was away and looks like that was the problem with the gas pedal. I can finally rev the engine.
Debating on painting the tubz body color or black like the engine bay. What do you guys think? |
07-22-2012, 04:09 AM | #35 |
Re: Red rebuild
Right on glad you got it figured out sometimes they can be a bear but you have to keep plugging on.
07-22-2012, 09:20 AM | #36 |
Re: Red rebuild
nice
07-22-2012, 02:36 PM | #37 |
GM Addicted
Re: Red rebuild
Levae the tubs black. The only way to me the would look good body color is if the firewall was done in body color also. I say leave them all black. Maybe if you want some time of color on them get some pinstriping done on them in red
07-23-2012, 11:40 AM | #38 |
Re: Red rebuild
i'd say spray the firewall and the tubs a satin black...and powercoat any engine components gloss black...topped off with chrome accessories
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-31-2012, 02:20 AM | #39 |
Re: Red rebuild
Took a break for some family time for a few weeks, but finally got around to my install. I can't lay it out because the bump there to clear the heater lines on the pass side hits the tire about 2" from laid out, so I have some more trimming on the pass side, but they are mostly in. That intake is hideous, have an AirRaid ubuild it kit coming, have to figure out some way to route that radiator line where it looks decent.
09-13-2012, 03:27 AM | #40 |
Re: Red rebuild
Haven't updated in a while. It's been so hot here I haven't wanted to brave the heat.
Had everything running, then all of a sudden started getting a lean bank 1 and bank2. Turned out to be a bad fuel filter, then a fuel leak at the pump. Built my intake, but not sure if I like it. It is an Airaid diy kit all ABS plastic, just cut your angle and use couplers to put it together. Had to change the power steering pump because mine was whining. Sounded like I had a whipple on it running down the street. Bumper and grill is on now, going to rework the DBW pedal. Got my new Dakota Digital VHX guages in the mail on Friday! Can't wait to get these in and not have to use DashCMD on the iphone to read the guages. I think I want a something to cover my radiator need to find someone with a break and some exp. |
09-13-2012, 03:33 AM | #41 |
Re: Red rebuild
It's looking good man! You will love those gauges, they are sweet.
09-13-2012, 04:32 PM | #42 |
GM Addicted
Re: Red rebuild
Looking good man.
09-20-2012, 04:28 PM | #43 |
Re: Red rebuild
Beautiful truck! Keep up the work and pictures
09-23-2012, 11:36 AM | #44 |
Re: Red rebuild
those are sick guages man....
11-02-2012, 12:30 AM | #45 |
Re: Red rebuild
Started the guage install. Broke off the H2O temp sensor adapter in the head, but got it out and have one one on order. Hope to get all the guages wired up by this weekend.
By the time I am done with these guages there won't be much left of the original main firewall harness. Need to find someone local to bend me a nice looking radiator cover. |
11-02-2012, 11:50 AM | #46 |
Re: Red rebuild
sweet!
02-02-2013, 02:57 AM | #47 |
Re: Red rebuild
There are always the little things you have left, but the swap was completed end of Nov. Had it out for a show in Dec. Now hat to get it out more.
I have to say I would do it again on my next project. This motor runs circles around the old tired 305 that was in it. |
02-03-2013, 03:05 PM | #48 |
Re: Red rebuild
Super nice build man. Are you going to run an engine cover? Keep it up!
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
02-03-2013, 03:59 PM | #49 | |
Re: Red rebuild
05-24-2013, 01:26 AM | #50 |
Re: Red rebuild
Been a while since I updated. Newborn takes up most of my time.
Picked up some new shoes. HAve to have my front rotors turned down a bit to fit the caps on and thinking of going with a 225/35/20 tire sice my 275/45/20 is pretty tall. Think if I go smaller I can ride lower and still turn. Decided to go with the 3 piece covers since the Camaro cover just did not look right. Picked the sides up on CL and bought the center. I think I needed the Escalade center instead of the Chevy, but it will do for now. Not sure if I should leave it black or paint all 3 body color... Getting ready to raise my bed floor and fill the gaping hole I cut in it for the notch, also trying to go back to engine driven compressor since I hate the noise of the electrics. Have to find some way to mount it on the right and make it look ok sitting there. The York 210 is one large ugly pump... |
