Old 05-15-2012, 10:20 PM   #1
fatgump
fatgump's Avatar
Re: SANFORD build thread
You get down to business. I look forward to watching your build.
fatgump is offline   Reply With Quote
Old 05-16-2012, 04:07 PM   #2
awbrown
Looks like you need the small balancer and a small pulley.... scot douglas had to do the same thing when he used a rack .. should be some pics here somewhere...
awbrown is offline   Reply With Quote
Old 05-16-2012, 04:10 PM   #3
1963c-10
1963c-10's Avatar
Awesome looking truck that you have and had.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-16-2012, 04:16 PM   #4
jhrusk
Thanks guys,awbrown I saw in that build that he used the smaller balancer but i figure since I am building headers and exhaust any way I will just raise the engine a little and fit it where it fits best.Thanks for looking.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 05-16-2012, 07:40 PM   #5
dbomb53
dbomb53's Avatar
Nice Job...Is your rack power or manual? I'll be watching this one!
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 05-17-2012, 07:03 AM   #6
jhrusk
dbomb53 it is a mustangII or t-bird power rack from advance auto.It was around a$100 bucks.Your truck is cool as well,Thanks for looking.
Old 05-29-2012, 08:57 PM   #7
hardwaa
hardwaa's Avatar
Nice work! Keep it up!
Also are you making the headers ?...Fender-wells????
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 05-30-2012, 01:37 PM   #8
jhrusk
Updates coming soon,Hardwaa I thought I would build my headers but I have a set that I will make work,They will be under the truck and full exhaust with turndowns just in front of the rear bumper.Thanks.
Old 05-30-2012, 07:06 PM   #9
jhrusk
Got a few updates,pretty much have the rack finished except for the steering shaft,pics show the outer tie-rod ends.I will do final adjustments when I do the front end alignment.also got the motor and trans set where I want it and made a trans mount.Name:  mr holder racecar 033.jpg
Name:  mr holder racecar 041.jpg
Name:  mr holder racecar 034.jpg
Name:  mr holder racecar 035.jpg
Name:  mr holder racecar 036.jpg
Old 06-01-2012, 12:00 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
I love this truck!
I do have a question.
It appears your rack is offset to the drivers side.
Won't this affect bumpsteer?
(I'm no expert,.... I'm just trying to understand)
Maybe it's just an optical illusion,...
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 06-01-2012, 01:40 PM   #11
jhrusk
Thanks guys,lolife99 it is to the driver side,I did not center the r&p housing,the rack It has a 2 1/2 turn lock to lock,I centered it between left and right and tried to center the outer tie rod swivel which is under the boot,however I did manage to get it to the driver side about a 1/2 to far,I know It should be exactly centered but I am going to check the bumpsteer when I do the alignment,if things do not work out Speedway motors has a set of offset mounting bushings that I will use to move it.Time will tell but honestly for a cruiser I dont think I will notice any difference except maybe turning radius.Hope this makes sense.Thanks for looking guys.
Old 06-01-2012, 01:29 PM   #12
scot 6 feet eleven
scot 6 feet eleven's Avatar
way cool!!!
1960 chevy 4.6 police interceptor chassis under this bad boy with 24 inch lexani's
scot 6 feet eleven is offline   Reply With Quote
Old 08-17-2012, 09:24 AM   #13
61 son of a Gun
61 son of a Gun's Avatar
Dig your work !
Hey, how exactly is a rainbow made?
How exactly does the sun set?
How exactly does the posi-trac
rear end on a Plymouth work?
It just does.
61 son of a Gun is offline   Reply With Quote
Old 09-03-2012, 04:14 PM   #14
jhrusk
got the engine ready to go in,currently cleaning and painting trans and other driveline components,will update Name:  sanford 017.jpg
Old 09-03-2012, 11:44 PM   #15
Dinos63
chevy only
Dinos63's Avatar
nice & clean
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-01-2012, 10:25 PM   #16
dbomb53
dbomb53's Avatar
Nice fab work, wheels and tires are killer. perfect stance.
Old 06-08-2012, 01:41 AM   #17
Dinos63
chevy only
Dinos63's Avatar
bump
Old 06-08-2012, 02:02 AM   #18
shrunken66stroker
shrunken66stroker's Avatar
Nice build. Sanford is looking good!
shrunken66stroker is offline   Reply With Quote
Old 06-08-2012, 04:22 PM   #19
jhrusk
update,I have just about everything finished in the rear,I was able to set my pinion angle and then I installed my lower bag mounts.I had to move the upper bag mounts in order to get the truck to sit where I wanted it to.I also braced everything up pretty good because I will be doing a little bit of towing with this thing,I got the shocks mounted as well.I am pretty much finished with the fabrication on the rear suspension just a little bit of final welding when I strip it down to paint it.I also re-purposed the factory bump stops so if it does bottom out it hopefully will not damage anything.Name:  mr holder racecar 032.jpg
Old 06-08-2012, 04:27 PM   #20
jhrusk
I also have most everything for the exhaust,I got a spare set of headers on the cheap that I will cut up and use to modify the ones I will use.well that is it for now. Thanks for lookingName:  mr holder racecar 038.jpg
Name:  mr holder racecar 039.jpg
Name:  mr holder racecar 031.jpg
Old 06-08-2012, 04:39 PM   #21
Dinos63
chevy only
Dinos63's Avatar
one of my favorite builds going on, such nice work on the rear
Old 06-15-2012, 07:10 PM   #22
OLDIRON69
subscribed
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-16-2012, 09:20 PM   #23
jhrusk
Just a small update,I have been working on some loose ends and one of those was getting the steering shaft made which in itself was not that hard however modifying the motor mount was a major PIA.I spent most of today doing that and re-enforcing the mounting tab on the trans mount.I also shortened my drive shaft so I will send it out to have balanced.I still have to make the upper shock mounts and then on to the exhaust.Name:  sanford 002.jpg
Old 06-16-2012, 09:30 PM   #24
jhrusk
this is what the shaft looks like and the motor mount mods complete,in some of my previous posts it was pointed out that my rack wasnt centered in the frame,I knew it was to the drivers side a little but after checking it with the crossmember in the frame rail it was off more than I thought so I cut it out and re-positioned it,so this was a screw up on my part but now is the time to fix it.That is how it goes sometimes and thanks for pointing that out.Thanks guys for looking. Name:  sanford 008.jpg
Old 07-22-2012, 07:59 PM   #25
jhrusk
not a lot to update,but I did finish modifying the headers and making the exhaust,I forgot to take a pic before I removed it from the truckName:  exh1.jpg
