#26 |
Old member
Power steering is only one groove that I know of. Never seen two. Maybe on the alternator but haven't seen it on the power steering before. Not on these models anyway.
Everything else seems to be correct. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 |
Re: pulleys not lining up...help
You might be OK just replacing the WP and Crank pullies from the same engine my PS was fine.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#28 |
![]() Three groove water pump pulley four groove crank pulley. 350 '72 Cali emissions truck with power steering and a/c. The empty groove was for the air pump. The steering pump angle and ghetto alt bracket/hardware were not my doing ![]() Side question. Did 72s ever have egr? It came with a '78 model q-jet with egr and egr manifold. 1972 dated 010 block though. Has some emissions check sticker from the 70's in the door jamb. The intake setup might have been to pass easier. Posted via Mobile Device
'72 cheyenne super step, '05 long bed gmc |
#29 |
Posted via Mobile Device[/QUOTE] It is very possable my 70 from Cali had the Evap system but the ones from ILL. didn't. The 72 parts truck had the Evap but no EGR
#30 | |
#31 |
Burnouts are therapeutic
I would just post a WTB in the parts section and replace the wp and crank pulleys.
I bought a set from board member livrat, it had wp pulley, crank pulley and alt. bracket for $60 shipped, yours should be cheaper and eliminate all your issues. The only thing I had to do was put two washers behind the power steering bracket to get it to line up perfect. My pump and bracket was just like yours.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
#32 | ||
![]() Quote:
![]() Posted via Mobile Device Posted via Mobile Device
#33 |
Here is a pic of mine with the 86 pullys and alt bracker with the orgnial PS, you might want to try just getting the pullys off the same car or truck.
#34 |
#35 |
Thanks I am trying to keep it as clean as I can and get it on the street in a month or so depending on the weather. This setup worked for me because I don't see any A/C in the future.
#36 |
I have the same problem... I do know as well the motor is not original. I also want to add aftermarket A/C but not all pulleys are lining up.. Since it is a small block, newer then 1987... can i just remove all the pulleys and buy new as if i had none and start from scratch? Is it possible a previous owner is trying to match short and long pulleys and brackets causing this problem? do they sell 3 groove water pump pulleys?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
#37 | |
Could some one post pic of p/s top bracket. not trying to hijack. |
#38 | |
![]() Join Date: May 2010
#39 |
Thanks firstowner 69.Forgot to add mine has aftermarket a/c, with a ford compressor.Don't know how but its there. Home made a/c comp. brackets.I'll try to get pics tomorrow.
#40 |
I'm having the same problem on my 69K10. I too have four grooves on the crank pulley and two on the WP (with a gap). I have no idea what the PO cobbled together, but in my case the water pump pulleys (yes its a short version) stick out further from the block than the crank.
I was just reading on the net and realized that harmonic dampers come in many diameters and widghts. I'm wondering if the "faces" or mounting surface of the dampers vary in relation to the block face when the balancers are fully seated. If so, that would cause an unwanted "offset" with the rest of the system. Hmmm...... |
#41 | |
#42 |
I bought my truck from a guy whos father bought the truck new. He inherited it when his dad died a few years ago. It was bought in Yuma on the CA border, but theres nothing in the SPID about emissions and I have paperwork showing the engine was replaced at 122,000. I'm thinking that is where things got mixed up.
#43 |
Now that you mention it, I'm looking over some photos I took before teardown and you may be on to something.
First-I see provisions for air tubes in the rams horns (they were plugged off when I bought it). Second- I have this "other" bracket thats attached (albiet butt ugly) to the AC compressor bracket. I'm wondering if its part of the bracketry left over from an air pump? Anyone have photos of an air system installed? I got a new Vintage Air compressor and bracket so for now I'm stuck with V-belts, otherwise I'd just convert to serpantine. I dont like the A/C bracket because it blocks the front "intake-opening" on the Edelbrock manifold. I guess I'll be selling it cheap...argh! I'm going to convert over to the long water pump and just buy new brackets. Last edited by SunSoaked; 08-06-2012 at 07:04 PM. |
#44 |
I didnt realise that power steering pumps come in all differant configurations, and since i have a motor swap i am thinking that the pump mybe wrong and the shaft sticks out to far making for the problems.. Can anyone measure there pump and get back to me on the measurement? Take a look at the arrow in the pic, it is exactly 2 inches apart, to hook up my A/C i need to move the power steering pulley in 1 groove to the 3rd groove from the balancer.... If i can move that 1 groove in, i can buy a 3 groove pulley and run the belt on the number 2 groove from the crank where there is now no groove!! If you have a 2 groove p/s pulley, i's love that measurement as well!!
#45 | |
#46 |
Here's a link to an old for sale thread that shows the pulley I mentioned in my post above that appears to move the groove closer to the block.
http://67-72chevytrucks.com/vboard/s...d.php?t=516067 |
#47 |
dropanddrag71-
You have an old style pump in a newer style housing. Thats what I was trying to do so I could use my newer hydroboost with the old pulleys and brackets. The newer pumps have a press fit pulley and it has two grooves. Problem is, to use it you have to convert to a long water pump ![]() |
