#26 |
![]() Join Date: Nov 2010
Re: The 4x4!
Got a carb rebuild kit coming for it and have a fuel pump to put on as well. Been cleanign the fuel take a little bit then checkin through the brakes. I know you guys would probably like some pictures of whats goin on with it haha It hasnt even left the trailer yet since I havent discovered a place to stick it to work on it. Thanks for the words though. Good to see so many people interested in a 4 wheel drive.
#27 | |
![]() Join Date: Aug 2008
Re: The 4x4!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#28 |
Re: The 4x4!
my 61k10 v8 has the ft mount and i had a 62 c10 with org 283 with a ft mount.
1961 chevy K10 my build is------------61K10 build |
#29 |
Re: The 4x4!
Mine looks the same ount and everything that was pictured
#30 |
Re: The 4x4!
#31 |
Re: The 4x4!
will take a pic today--maybe from under the truck. when i take the front end off will take some chassis pics, as my bell housing x member is interesting--as the pto drive shaft goes through it. on pics of the 62--long gone.
#32 | |
Re: The 4x4!
-The early front engine mount used the pipe with a pad in the center, where the later engine mounts bolted to the side of the block. -The earlier bed mounts were rivited to the side of the frame and the later were rivited to the top of the frame rail. -The cross member that is under bell housing (rear eng mount) on the earlier chassis was mounted between two brackets that were rivited to the frame, later 63 had a mount that went from the upper inside of each frame rail with a shorter gusset to stiffen and support the cross member. -The earlier 63-66 transfer case mounting was better fortified with more supports than the later 63-66 k series. -Park brake cables are different -The front cab mounts on the earlier trucks were farther out than the later trucks. -the front core supports mounts are different. -shock mounts and shocks are different. -radiator mounting. -bumpers OK so there are a few other minor things but this is a good start. ![]() I have both early and late 63 k chassis and could get some pictures of differences to help clarify what I was trying to say.
Where the hell did my coffee cup go?!! ![]() |
#33 |
Re: The 4x4!
here is the front mount and x member---you can see the mount from the rear also---
#34 |
Re: The 4x4!
Thanks for the pics 61K10,i know i have the right parts comin for my 62 K-20 now
#35 |
Re: The 4x4!
j.kirn------so what are you doing?
#36 |
Re: The 4x4!
Stated working on my 62 k-20 and it was missing the pipe and horse shoe mount for engine. Found what i needed from a guy and needed some pics to make sure i could put a 283 back in it
#37 |
Re: The 4x4!
Well got the carb rebuilt but the gasket that goes under it when ya bolt it on doesnt fit..go figure. So Ill have to wait a week to get the correct gasket. Taking the Hotsy to it tomorrow which im sure will be quite the mess. Spoke to a guy that has about 14 old trucks sitting down on some of his land. He bought them all from a junk yard that shut down and saved the from the crusher. Pretty nice 60 Apache there that he will sell but hes keeping the hood for his K20 (hood is PERFECT) and selling the whole truck. Hopefully he wont want an arm and a leg for it. Ill try t post some more pictures of the progress
#38 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Re: The 4x4!
Too bad about not getting the hood Dtkarst. I was lucky and found one locally for next to nothing, that was nearly perfect. I then sold the hood that was on my truck and bought build parts with it! Hopefully you will get the rest of that truck for cheap! Good Luck!
