#26 | |
Re: Tire Sticking Out
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
#27 |
Passenger side
![]() Driver side ![]() Posted via Mobile Device
#28 |
"You're only as good as the people you keep around you" ![]() |
#29 |
It's possible that it was involved in an accident and the frame was shoved over to one side. Then when it was repaired, the front clip was scooted over the other direction to compensate. You might want to take some measurements between the frame and the fender on each side and compare.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#30 |
You may check to see if the body has been placed over to the passenger side some. The appears to been scooted over alittle due to the gap between the fender and the bumper as highlighted in the inclosed picture...
You may also check some of the bumper adustment also.. There is 1/2 inch to 3/4 inch side to side adjustment. |
#31 |
BTW For everyones infomation... This post in on 4x2's.
4x4's have a wider track in the front than the rear from the factory. |
#32 |
I think I noticed the truck in question has aftermarket wheels, I would still check back spacing. The only time I've ever noticed anything like this was a truck I had, when I checked it out it had one 8" rally wheel with different back spacing. I don't know how many different rally wheels there are but I have seen several. The only other thing than the body parts being moved, could be some kind of aftermarket replacement spindle, but I'm doubting that. It is interesting though.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
#33 |
4x2's do also. I think it's almost 3"
#34 |
78K & 79C Jimmys
jimmys too?
could just be how pics get reduced on here, but does the gap I pointed to look different?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#35 | |
#36 |
I had a bit of the same problem. I measured everywhere. I had the body shop straighten the left front frame horn and he said that the front end was off by 1/8" but that was not the issue. I found that the left side had way too much camber and the right side had way too little. Most alignment shops will not be too critical as they are production shops. Meaning get it in and get it the vehicle out in record time, unless you buy a whole front end rebuild that is usually not necessary. Fine tuning the aliginment may be helpful for you. I've seen several of these trucks with this camber issue including mine.
#37 |
well on my red truck the fender is dented in and the bumper is also slightly pushed in because i got stuck in a ditch. the problem was there before it happened. I tried switching tires and the problem is still there. but one thing i did notice was that on my driver side the ball joints were in ****ty shape, but on the passenger side the ball joints were fine. you think if i replace the ball joints on the driver side it may tuck the tire back in where its suppose to be???
-Samuel "Knowledge Is Power" |
#38 |
guys i know a man all he does are these trucks. he told me that out of factory the front clips could be wrong by 1" and the suspention wrong up to .5. never mind the beds
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
#39 |
![]() Join Date: Mar 2012
#40 |
BAD BOW-Silverado XST
The travel path for our truck is unique!! The front travel path is 1" than the rear. How that 1" is shown, is different from truck to truck. GM engineered them that way. I assume it was for a more stable front end. Replacing the A-arms with aftermarket tubes or modified stock arms is the only way to remove the extra gap. This difference is why wide front tires rub the fender.
#41 |
Still no resolution?
Visually check the length of the left a-arms and compare to the right a-arms. |
#42 |
Tires sticking out crooked, whole trucks leaning to one side or the other, bumpers sticking out too far on one side vs. the other, front tires that stick out farther then the back.....What the hell am I driving?? I'm afraid. What if your truck was built on a Friday after lunch.
#43 | |
On 2wd it was simply a result of the packaging required to get all of the suspension characteristics to work out. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#44 |
Mine was built second shift on a Monday - and seems to be holding up ok...
![]() K
#45 |
Mine was prob built by this guy^ and the doors still shut with so muçh as a sneeze
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#46 |
i have played around withe the doors a bit and i have gotten them better but i still have to slam them
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#47 |
Pls let us know what you figured out what the issue was with the wheel and such very curious to find out! im not having problems with mine like that, but my bed is sticks out on the passenger side more and tucked behind the cab on the driver side. of course the thing was hit behind the wheel fender where the tailight is at on the driver side, but idk if the bed being hit as little as the dent is would bend the whole bed.
#48 | |
#49 |
LOL what is PB blaster? I new to all this! I dont care if it sits out on both sides of the cab, just as long as the spacing is the same on both sides.
#50 |
PB blaster is a spray on product that works its way into nuts and bolts to make it easier to break them loose. You should be able to get it at any auto parts or tool store.
