05-11-2012, 11:13 AM | #26 |
Re: for the 1100th time what oil do you use?
We used to run straight weights all the time,,,good stuff. My father ran straight 30 weight in his 69 goat since the day he bought it new (still owns the car). He put 190,000 miles on that thing and it still ran like a top right up until he decided to finally build a new engine for it about 5 years ago.
05-11-2012, 11:35 AM | #27 | |
Newbee
05-11-2012, 11:57 AM | #28 |
05-11-2012, 01:23 PM | #29 |
Because of the zinc content (or lack thereof)?
Or for some other reason? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-11-2012, 04:17 PM | #30 | |
Moderator
MANN, NAPA/WIX, Hastings, & Baldwin make quality fluid filters that don't blow out. I buy Baldwin because they're made in the US and are excellent quality. NAPA/WIX & Hastings are my equal second and third choice. 10W40 OIL that's API Certified SH or better for all of my older Gas engines including the mowers. 15W40 OIL that's API Certified CF-4 or better for my 78-2000 Diesels. 5W30 API SN rated Synthetic in my Impala LS4. 5W30 Castrol TXT or Motul 505.01 oil & Mann filters for my BRM TDI. Allied Signal (FRAM) makes VERY good air filters ( I use them ) but their fluid filters have a reputation for blowing out the media inside the can. Never seen one blown out like that and I don't want to. I've seen several threads on the net where they cut open filters to examine how they are made. Here's a forum thread from 2011. It looks like AC-Delco has started to use lower quality internals. http://www.yellowbullet.com/forum/sh...d.php?t=420509
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-11-2012, 04:37 PM | #31 | |
Moderator
ZDDP is at least part of it. We can thank the nut job greenies for this. http://www.ttalk.info/Zddp.htm I may have to re-think my own choice of oil.
05-11-2012, 04:55 PM | #32 | |
You really have to stay on top of this stuff, both oil and filters, as it seems to change quality every few months. It's unfortunate. |
05-11-2012, 05:06 PM | #33 |
Great thread on the oil filters! Thanks for posting that!
Speaking of ZDDP levels, another thing we run into alot is fleets that want to stock only one type of oil in bulk. Usually 15w40 CJ4 diesel oil. Understandable when servicing a large fleet. Well, high ZDDP levels will destroy the catalytic converter. We've actually seen hollow cats on fleets running diesel oil in their gas engines with less than 50k miles. Many of them have made the switch to stock 2 types of oil now and the problem has miraculously gone away.... Here is a good article in regards to running diesel engine oil in gasoline engines in case anybody was considering it.... |
05-11-2012, 05:07 PM | #34 | |
Different oils have different "parts-per-million" count so you really have to read and then read some more. Unfortunately there is some bad info floating around too. I've seen different or conflicting information on the PPM's for certain oils. Whether it's a misprint or it's midleading information to sell oils,,, I don't know. It's mainly important to those running flat tappet cams. The general consensus is that you need at least 800 PPM's to keep a flat tappet cam happy. This can vary though depending on spring pressures. Most of your good oils (according to reports) like Brad Penn, Shaeffer, Amsoil, advertise 1200 PPM's or more. VR1 Valvoline seems to be one of those conflicting oils. Some say it's 8-900 and it's safe for converters, others say it's 1000 ppm's and should be off road use only. I've noticed even the bottles used to say off road use only,,,,I haven't seen that in a while though. Makes you wonder,,,,eh?? What also concerns me just as much as the flat tappet cams are the other metal to metal contact areas like piston walls and pistons, rings, rocker arms etc....If the ppm's have been reduced enough to cause flat cam lobes,,,,I can't help but wonder what kind of wear it's causing throughout the rest of the engine. Makes you think doesn't it? So roller cam or not, there may still be a long term issue here. |
05-11-2012, 05:15 PM | #35 | |
I don't own anything with a cat converter so I'm a ZDDP junkie |
05-11-2012, 09:35 PM | #36 |
I run Rotella 15-40 with Eastwood's ZDDP additive, and a Donaldson filter. I thrash that Crusader like a G.I. on a Vietnamese prostitute. Never had a problem.
05-11-2012, 10:00 PM | #37 |
1985 Chevrolet K-10, SWB, 350/700r4, 6" Lift, 35" tires |
05-11-2012, 10:55 PM | #38 | |
as far as knowing what goes on in filters i cut EVERY filter that comes off any of my vehicals. 12 years ago i bought a filter cutter ( works like a can opener) i bought some different oil filters just to try. i put an orange fram on one of my mild built sbc with a melling select oil pump. my oil pressure went from 50 lbs to 5 or less lbs the cardboard was colapassed inside and dents on the outside of the can after reading about vr1 oil i am gonna switch to valvoiline vr1 20w50 in my flat tapped motors and add some zddp additive to it. and i am gonna use a valvoiline synthetic in my 09 f150 flex fuel. still gonna use my wix filters i aint changing what filter i have trusted for 20 years. i am looking at after the new year ( when ford motor company is paid in full) picking up a 2013 camaro we will look at oil then and see what valvoiline we are gonna put in it then.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
05-11-2012, 11:42 PM | #39 |
thanks for the sites guys i got some very informative reading done
05-12-2012, 10:39 AM | #40 | |
I actually use which ever sythetic is cheapest at the time of the oil change so it varies. Lately it's been Pennzoil Platnum, sometimes it's Valvoline syntec synthetic, Mobile is rarely comparable in price. I run 10w-30 in all 3 of my LS engines. Went up a bit on viscosity because of the hotter temps in this region. The last oil comparison I read showed that Mobile wasn't as high ranked as it used to be. Changes in additive packages have dropped the Mobile. As a matter of fact Pennzoil Platnum was near the top along with Valvoline Synthetic and Mobile was lagging behind a bit. Seems to be ever changing though. I'll see if I can dig some of that up.... |
05-12-2012, 11:00 AM | #41 |
Oreilly's has next gen Valvoline for about free on sale now, with a cheap filter.
05-12-2012, 11:12 AM | #42 |
I am a straight Rotellia fan... I had an issue several years ago with conventional oil in a GM Quad 4. Change oil, run 30 miles, the engine sounded like an old wore out motor. It had every rattle/knock you could think of. Changed to Rotellia, ran the car HARD 90 miles down the interstate, no noises ever agian. If it is heavy duty enough for a hard working diesel engine, it will work great in a light duty use gas engine.
Wix fuel, trans and air filters. OE oil filters. All except my 06 Dodge diesel fuel filter. Then its Baldwin PF977 fuel filters all the way. The only problems 06 Cummins people seem to have is bad fuel injectors caused by dirty fuel. (the numbers could be wrong here its been awhile, but you will get the idea..) OE filter cleans down to 9 micons, most aftermarkets only clean 11-13, Baldwin cleans down to 6... Lets see $1000 worth of injectors or $2 more for a fuel filter that I change twice a year...no question! BTW for all you Fram Filter people, try this... Go buy a new cummins truck, change the oil filter to Fram, take the truck to the dealer for service...Now watch how quickly the dealer ecsorts you out of service and then VOIDS the COMPLETE warranty on your new ride... How much do you like that Fram now? Fram filter on Dodge Cummins truck EQUALS warranty void that quick! |
05-12-2012, 11:29 AM | #43 | |
Newbee
05-12-2012, 11:31 AM | #44 |
05-12-2012, 11:40 AM | #45 |
http://www.gmtruckcentral.com/articl...lterstudy.html
Okay, here is the latest and greatest oil filter comparison as of Feb 2011. Lots of oil filters tested here and lot of reading and data. Click on your favorite filter and see how it tested,,,it may be an eye opener.... I hope this will help someone in selecting their next filter. Now I have to find the latest oil data....you'll be surprised. |
05-12-2012, 12:12 PM | #46 | |
thanks for yalls input this has been one of the best thread discussions i have been a part of in a while. lots of great info and more to come hopefully.
05-12-2012, 12:44 PM | #47 | |
Newbee
The royal purple filter that I have been using is one of the top filters, but he failed it on media volume, and price. |
05-12-2012, 02:31 PM | #48 | |
Notice the new line (well they are a couple years old now) of Fram Extended Guards ranked as the best in these test while the other Fram lines were very poor. ACdelco has really fallen since they switched to the new E-core design, basically card board glued together now. Every couple of years it seems this stuff changes, quality changes etc... I'm guessing you like Royal Purple? Their filters aren't that bad, fairly decent, and even this test faired well compared to some of the competition, but you'll be surprised at the oil and the kind of ratings it gets. The wear molecules are very high with that oil and it was near the bottom of the list. These oil brands keep changing their additive packages every few months it seems. Last time I checked,,,Royal Purple didn't make the SM cut so they are not API SM certified. I'll have to find the most recent oil study....it's a good read too. Last edited by Firebirdjones; 05-12-2012 at 02:37 PM. |
05-12-2012, 03:36 PM | #49 |
Are there any studies that can directly relate cheap oil and cheap oil filters to engine failure, poor fuel economy, etc.?
I would get a lot more looks from the ladies if I wore Armani suits rather than shorts and tee shirts to the supermarket, but I am not sure that my shopping experience would be any different. |
05-12-2012, 04:03 PM | #50 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
So know that U got my attention what R we going to do or what's the final answer!!!
