Closed Thread
Old 05-19-2012, 09:36 PM   #26
litew8
litew8's Avatar
Re: NOS Complete lower trim fastner clip set
Thank you for clarifying! Maybe you mean there are "8 nuts" missing.
When you were saying screws, I thought you meant the studs/bolt part of the clips,
but looking closer, it appears there are nuts missing.
project: "my happy mess"
litew8 is offline
Old 05-19-2012, 10:44 PM   #27
Arrington01
Arrington01's Avatar
So you only have adhesive clips for lower molding only? I need enough adhesive clips to do entire lower molding. How much would that be and how many clips will be included?
Arrington01 is offline
Old 05-26-2012, 06:04 PM   #28
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
That is 10 adhesive clips... I do not believe the top molding ever took adhesive clips
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 05-31-2012, 11:41 PM   #29
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 05-31-2012, 11:45 PM   #30
litew8
litew8's Avatar
Mine had them. bump 4u
litew8 is offline
Old 05-31-2012, 11:50 PM   #31
HeavyMetalChevy
Just a Member
pics??? I have these...
TH400(3rd)
Old 06-01-2012, 12:24 AM   #32
litew8
litew8's Avatar
No pics, but if those are small enough to fit the top trim, looks like it.
I can get pics later, they are still on my trim.
litew8 is offline
Old 06-01-2012, 12:26 AM   #33
litew8
litew8's Avatar
I think only the bedside top trim had them.
litew8 is offline
Old 06-01-2012, 01:02 AM   #34
HeavyMetalChevy
Just a Member
Yeah...I thought I still had some top trim around here to compare to.. No go..The top trim pics would be great. Help everyone out
TH400(3rd)
Old 06-01-2012, 07:13 PM   #35
litew8
litew8's Avatar
Unless they made different versions, the ones you show here:
... aren't the same as what I have.
litew8 is offline
Old 06-04-2012, 07:38 PM   #36
litew8
litew8's Avatar
Took some pictures. The majority of mine are adhesive type.
I may be asking for some of them, will post pictures later.
litew8 is offline
Old 06-05-2012, 12:13 AM   #37
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 06-05-2012, 04:00 PM   #38
litew8
litew8's Avatar
Post pic #35 above - I think I've seen those as reproduction.
Substitutes for OEM upper trim? Anyway, I took some pictures of mine and posted
them (LWB) in my build thread. They can be seen here:
http://67-72chevytrucks.com/vboard/s...&postcount=638
litew8 is offline
Closed Thread
