06-16-2012, 12:22 AM | #26 | |
He's got mean nasty FANGS!
Re: Going to look at a Tahoe. High miles-should I worry
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
06-16-2012, 12:51 PM | #27 |
low n' slo
man that sucks, what a ****ty salesman. why would he give you the number to the guy who changed the fuel pump? you would think he would personally contact the dude to let him know...
i dont think this is all coincidence... fuel pump will fix the gas gauge more than likely (did on mine), obviously new battery is no big deal, a/c could be expensive to fix, but i would be worried about the coolant in the oil. that alone would make me boycott the sh*t out of that place until he fixed EVERYTHING..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-16-2012, 04:27 PM | #28 |
There is no way that he didn't know about at least most of this stuff.
I doubt he'll do anything. Sold "AS IS". His offer of throwing in the warranty didn't happen. I would have had to pay full price to get it. It's all a load of BS.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 06-18-2012 at 03:36 AM. |
06-19-2012, 02:01 PM | #29 |
Very sorry to hear about your luck. The good thing is, all of that is fixable.
06-19-2012, 03:18 PM | #30 |
Thanks for the sympathetic note.
Things may not be as bad as I thought, then again they might be as bad as I thought. I have been doing some searching on the net and found someone with the same symptoms as mine. A milky looking fluid coming out of the oil pan just at the end when draining. In his case it turned out to be because it had been driven on just short commutes that didn't allow it to fully warm up causing moisture to build up under the fill cap. His solution was to trade cars with his wife every few days on a longer commute and it seemed to resolve the problem. My Tahoe had been at the dealer’s lot for over a month and had only been taken on short test drives. Before that who knows. I'm going to watch my fluid levels closely and go from there. Besides that I have been told by one shop that it's not recommended to change the head gaskets on such a high mile engine because the compression may raise and cause lower end problems and that it would require a new engine. I don't know what to believe anymore so I'm taking a wait and see approach. I put a new battery (which the dealer knew was bad) in and it's down at a local shop getting the AC diagnosed so hopefully it's something cheap (yeh right). I have verified that the dealer refilled the AC multiple times though. He told me that when he got the Tahoe it was blowing hot so he recharged it just once and it's been fine ever since. That was before I drove it the first time. When I called the shop that supposedly changed the fuel pump (which they say was done at a lot lower price than the dealer told me) and he told me they also recharged the AC and the dealer didn't want any diagnostics done on it, just a refill. That was after I drove it so he knew about that problem. What a scumbag.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
06-19-2012, 04:06 PM | #31 |
Just chalk it up to the fact that some dealers are lieing bastards.
You probably have a leak somewhere, they can do a leakdown test. With the oil, I would run a synthetic blend and change it and the filter at 3000. Also run a WIX filter. See how it looks after that. Also, keep track of your coolant level. If that's going down and dont see it leaking then you might have an issue. I just bought an 01 Tahoe with 166k and am in the process of going thru some issues myself. One being the fuel level sensor. My buddy works at a dealership and told me to replace the pump with a GM one (I think delphi makes them for GM) and not to use any other brand. |
06-19-2012, 04:07 PM | #32 |
Well, so much for wishfull thinking. The shop just called me. The AC has a huge leak at the eveperator which requires the dash being pulled out to fix and will cost $900 to fix. He also drained my oil and found more coolant in the oil and sayus the bottom of the oil pan is coated with the milky white gooh. He says new engine time. He can put an engine from Jasper in for $5600. So I'm screwed royally.
06-19-2012, 04:20 PM | #33 |
That sucks. Shop around on prices. $5600 sounds way high, and I would not do a 'Jasper'. I would get a GM crate or one from a wrecked truck.
06-19-2012, 05:25 PM | #34 | |
06-19-2012, 06:11 PM | #35 |
Thanks for that advice, appreciate that.
06-19-2012, 06:20 PM | #36 | |
low n' slo
man, this sucks! have you checked around to other shops other than the ones who quoted you? all those prices seem super high to me... i would just pulled a motor from a running truck, that should only be about a grand WITH install. 5600 on a truck you already spent 7k on is just not worth it. you could also sell yours or part it out to recoop some money back. shops around here only charge about 150 to fix the dash (although mine was the fuel pump float)..good thing he ruled out the pump though. when mine was reading crappy i changed the pump off of known problems with these trucks, but i went with an autoparts store brand. fixed it, now 2 1/2 years later, its messed up again lol you have to do something about this lemon seller though, i wouldnt let him get away with selling me a truck like that. either split the costs, take it back on a trade in credit, something to keep his name in decent standing!
06-19-2012, 06:23 PM | #37 |
Yeah, anything is fixable... I didn't think it was that magnitude though... :/
Agreed.... I'd be giving that dealer hell for it and ask him if it is worth ruining his reputation? Craigslist revenge, post the truth. |
06-19-2012, 06:43 PM | #38 | |
low n' slo
ya your right, i would be all over craiglist, if he cares any for his buisiness, he will cave at some point.
06-19-2012, 08:11 PM | #39 | |
http://sacramento.craigslist.org/cto/3088349473.html "Buyer Beware: I just got totally ripped off by Ari at Direct Auto Outlet. I bought a 2001 Chevy Tahoe from him and its all gone bad. The AC went out on the way home. I had it recharged the next day and it was blowing hot the next morning (big leak in the evaporator that will cost $900 to fix). The battery died on the third day when I was getting the oil changed ($100). Found coolant in the oil on that oil change. Got it checked out and it needs a new engine ($5600). The gas gauge not working correctly ($375). I've put less than 200 miles on it since I got it so now I'm broke and have no way to pay to have it fixed. I'm out $7400 with nothing to drive. We are devastated and he won't help. He just denies everything. He had this vehicle on his lot for at least a month so he had to know about at least a few of these problems. I feel that he is a dishonest sales person and would warn all that are considering buying a vehicle to stay clear of his dealership." I'd love to protest in front of his dealership but it's 70 miles from here. Doesn't make it impossible, just harder. I'm thinking about adding his email adress and ask people to send him a note stating "I wouldn't buy a car from your dealership". Maybe if he got enough responses he might change his tone.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 06-19-2012 at 08:18 PM. |
06-19-2012, 08:13 PM | #40 |
I think you need to have an "accident" in your tahoe if ya know what i mean.
2001 Tahoe 1978 K30 |
06-19-2012, 08:24 PM | #41 | |
I'm not really sure she would want me to survive though.
06-19-2012, 10:05 PM | #42 |
I talked to my buddy who's a tech at a GM dealership and he said he's never seen one have a gauge issue..its always been the sensor on the pump, he says.
06-20-2012, 02:59 AM | #43 |
I just got a response to my ad. Some guy wants to trade my wheels for some 22"ers. What an A$$.
I also made a complaint to the Better Business Bureau. Let the games begin.
06-20-2012, 08:04 AM | #44 |
I only read down to the post about the cluster fix for 375, and I'm short on time but I just wanted to say I rebuild wrecks a nd late model trucks and suv's. It is common for the clusters to be screwed up but nowhere near 375 to fix. I have had about ten or so rebuilt and there is a guy in tn that does it for 65 bucks. That includes changing the 6 motors on the cluster and all of the bulbs as well. Asfar as labor to take it out it can be done with a few tools and not much mechaical ability, very simple it takes me about ten min. Now the motore you can get one from a wreck[they werte driving it when it wrecked] for less than a grand. I have bought loaded ones for 250 but that was a while ago when those were fairly new and were not selling
06-20-2012, 08:44 AM | #45 | ||
He charges $35 plus shipping... $375 is a ripoff. I'd ditch that mechanic too. |
06-20-2012, 09:30 AM | #46 |
Getting Old; Going Broke
My last job required frequent trips to a business that was very close to a Chevrolet dealership. One day I noticed this truck sitting out front with a huge sign in the bed (he built a billboard basically on a wooden A frame inside the bed) that said DANNY BECK CHEVROLET ARE CROOKS AND RIPPED ME OFF. I actually pulled over and talked to the guy about it. He was probably in his mid 20's and you could tell he was just a poor farm boy type guy. He explained he saved his money and bought a used truck from this dealership (1 ton plain jane white truck, what this dealership is known for always having and selling to workforce type places). After a few weeks it had a problem getting hot and short story is he took it to a mechanic and they found the engine had a ton of some sort of stop leak put in it to try and fix a major problem.
Now I don't know if the dealership knew about it or did it, but they sold it to this poor guy and he was upset. For a few weeks I seen him sitting outside the dealership on the shoulder with the hood up and his big sign displayed. Then one day I noticed the truck was actually up in the parking lot by the service drive and the guy was taking the sign down. Seems they finally agreed to swap him trucks for another used one just to make him go away. Bad press does not go over well for a legitimate business and they will do what it takes to make it go away. If you're already dealing with a crooked person/business though, about all you can do is drive through their front office window with the truck on fire. That was a joke, please do not do that!
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
06-20-2012, 03:59 PM | #47 |
I think i would have been content to drive my 63 as a dd but I would do some ac before i did that ,just getting too darn old to go without AC....
06-20-2012, 10:19 PM | #48 |
Has more rust than truck...
Sorry to hear about your problems. If I were you, I would find a used 99-07 4.8 or 5.3 to drop in so you can drive it. Should cost you less than 700 for a good long block. Then fix the cluster and other issues once I had time and money.
06-20-2012, 11:09 PM | #49 |
Rottenwood Garage Member
Tahoes are cheap and everywhere. I just picked up a NICE 99 with the prefered 5.7, Z71, clean leather, good tires and no leaks with 125,000 on it for $3000. Just keep looking.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
06-21-2012, 01:10 AM | #50 |
Im not sure that it applies to your year, but very soon after we got our '04 Denali, the speedometer started reading weird. Like 85 mph while driving 20. Ours had 60k when we got it (and paid too much) but what I did find out is that the gauge cluster was recalled and the GM dealer replaced it for free. We bought our car from an independent non GM dealer also. It may be worth looking into. They told us that the "stepper motors" that make all of the gauges work were known to be defective. Im sorry to hear yours has been a problem. Ours has been great for the last 80k with regular maint.
Posted via Mobile Device Posted via Mobile Device
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
