Closed Thread
Old 05-22-2012, 09:48 PM   #26
naphtali5725
naphtali5725's Avatar
Re: My first build - 67 GMC small window stepper
got a DA sander, getting things together for more work
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline
Old 05-23-2012, 08:36 AM   #27
naphtali5725
Who makes the best quality repair panels for the 67-72 trucks? Fenders, cab corners, etc. etc. ??
Kind regards
My build thread...
Disabled Veteran
Old 05-23-2012, 10:12 PM   #28
naphtali5725
I got all the parts together for my engine rebuild.
All parts will be replaced.
All performance machine and head work, including assembly will be done by Oldsmobile specialist Mark Smith (smitty) at http://www.mjproformance.com/
Check him out on www.realoldspower.com smitty275
Oldsmobile 455
Silv-o-Lite 1631+.030 Pistons 10.25:1 compression
Melling M-22FHV Oil Pump
Melling 22-FHVS Oil Pump Pick-up
Melling IS-22F Intermediate Oil Pump Drive Shaft
Melling 3-494SD Timing chain and gears set
Melling MPE-124BR Expansion plug kit
SBI VL49 Hydraulic Lifters
Pioneer R-396-4 Rocker Arms
Clevite SH-1354S Cam Bearings set
Clevite MS-804 P10 .010 Main Bearings Set
Clevite CB-542 P-10(8) .010 Rod Bearings set
Hastings 2M 661 030 Piston Ring Set
Enginetech S2886 Valve Seals
Rear Main seal
Fel-Pro EIS 2010 PT Engine Gasket Set
Fel-Pro MS 96015 Intake Gasket Set
Camshaft will be provided by Smitty
kind regards
My build thread...
Disabled Veteran
Old 05-30-2012, 03:33 PM   #29
Tinkermc
looks like a good truck to start with, thanks 4 the pics
Tinkermc is offline
Old 05-30-2012, 05:02 PM   #30
naphtali5725
Thanks Tinkermc! I am in the process of having my engine built, and I am looking into finding a good manual trans that will handle 510+ ft. lbs of torque! Hopefully I'll be able to find a Tremec TKO, spec-25, or a good muncie.
Kind regards
My build thread...
Disabled Veteran
Old 05-30-2012, 08:25 PM   #31
tsali39
tsali39's Avatar
Originally Posted by naphtali5725 View Post
Thanks! How far is Spencer from Asheville?
About two and a half hours! We love Asheville!
tsali39 is offline
Old 05-30-2012, 09:00 PM   #32
naphtali5725
Yeah man, I love it too! I'm about 25 minutes south of it, great place !
kind regards
My build thread...
Disabled Veteran
Old 05-30-2012, 09:16 PM   #33
NewType72
NewType72's Avatar
man what a perfect place to start a full off resto if you didn't drive it before it's much easier to let it sit until finished haha will be following this
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline
Old 05-31-2012, 09:48 AM   #34
tsali39
tsali39's Avatar
Did some more dis-assembly tonite, made some progress inside, dash out, heater core, etc.
My airbox looks just like this one!
tsali39 is offline
Old 05-31-2012, 09:52 AM   #35
naphtali5725
Mine had a mouse nest, as well as bumble bees in it, crazy what will take up in a truck that has sat out in a field for a few years...
My build thread...
Disabled Veteran
Old 05-31-2012, 09:56 AM   #36
naphtali5725
Waiting to hear from porter built on some suspension pieces for my truck, I'm pretty sure I'll be changing the rear suspension from leaf spring to track bar style. I'll probably swap in the whole front crossmember from my 86 C10 Silverado, so i'll have disc brake and power steering.
My build thread...
Disabled Veteran
Old 05-31-2012, 10:37 AM   #37
tsali39
tsali39's Avatar
Do you have any photos of the truck as you found it in the field?
tsali39 is offline
Old 05-31-2012, 10:46 AM   #38
naphtali5725
Here it was it was pulled forward out from under the brush a little in these shots...
My build thread...
Disabled Veteran
Old 05-31-2012, 10:48 AM   #39
tsali39
tsali39's Avatar
Nice find. That truck has a great color! Thanks for sharing!
tsali39 is offline
Old 05-31-2012, 10:55 AM   #40
naphtali5725
it's a factory GMC color... palomino tan
My build thread...
Disabled Veteran
Old 05-31-2012, 11:47 AM   #41
72SWBChevy
72SWBChevy's Avatar
Nice truck to start a build with!!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline
Old 06-10-2012, 12:01 AM   #42
naphtali5725
Lots of progress on dis-assembly...
lots of pics
My build thread...
Disabled Veteran
Old 06-10-2012, 12:02 AM   #43
naphtali5725
more
My build thread...
Disabled Veteran
Old 06-10-2012, 12:04 AM   #44
naphtali5725
more....
My build thread...
Disabled Veteran
Old 06-10-2012, 12:06 AM   #45
naphtali5725
more.....
My build thread...
Disabled Veteran
Old 06-10-2012, 12:08 AM   #46
naphtali5725
lots of dis-assembly done...pretty busy
My build thread...
Disabled Veteran
Old 06-10-2012, 12:09 AM   #47
naphtali5725
more teardown
My build thread...
Disabled Veteran
Old 06-10-2012, 12:11 AM   #48
naphtali5725
keeping busy, teardown almost done
My build thread...
Disabled Veteran
Old 06-10-2012, 02:17 AM   #49
NewType72
NewType72's Avatar
Man that is quite the disassembly looks like it was blown apart after
- Dylan
(209)-985-7721
Old 06-10-2012, 09:57 AM   #50
naphtali5725
yeah i was on it after i got my a-frame/hoist built.
now i wish it would go back together as fast
My build thread...
Disabled Veteran
Closed Thread
