#26 |
Cool Truck
Re: New Style 7" LED Headlight from Truck Lite
I bought myself a set of these last month for a decent price and I am extremely happy with them. At first I wasn't sure on the look of the lights, I didn't like how they don't sit flush with the bezels but I really like having that smoked looked. They are really bright and have a nice wide vision.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#27 |
![]() Join Date: Nov 2007
Any night time pics?
#28 |
Cool Truck
These are the only nighttime shots I have, and the inside pic doesn't do the best job of capturing the light output.
#29 |
Been looking at these for my 1975 CB750 motorcycle. It's got a 7" bucket so it should work too ^__^
#30 | |
I have one on my Harley electra-glide (with a pair of the matching passing lamps). They are awesome.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#31 | |
#32 | |
![]() Join Date: Jul 2012
68 Chevy C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=576959 Adam-Aftermath California Chapter |
#33 |
Do they only come in smoked? They look good and I can deal with not sitting 100% flush but would prefer clear. Looked on their website and didn't see where they did.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#34 |
They look smoked but they aren't really. Its just the way the reflector looks. No other way to get 'em.
#35 | |
![]() http://www.clearcorners.com/products/cibie/
#36 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#37 |
20' Daredevil (Ret)
![]() Join Date: May 2003
I'll add my two cents if you don't mind. Do the relay mod even if you still run stock sealed beams. And if you upgrade the headlamps, even with basic 55/60 watt bulbs (more than adequate, btw) -- most definitely do the relay mod. It provides full voltage to the headlamps, which the stock wiring cannot do.
#38 | |
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#39 |
Truck lite came out with a heated lens, T stat controlled for the snow sticking to the lens problem.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
#40 | |
I don't drive a whole lot at night with the truck and the difference without changing the wiring is significant enough that I am happy with it without the mod.
#41 |
20' Daredevil (Ret)
I'm not so sure that's correct, you are only supplying the voltage that the bulbs are designed for. Now if you gave them more voltage than they should have, I'd buy into the shorter bulb life theory.
#42 |
Moderator
![]() Join Date: May 2007
All I have is a relay upgrade and Sylvania sealed beam headlights. A blind man can see with these, so I have no reason to go any further.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#43 |
What relay are you guys using ?
#44 |
I'm using lmc's heavy duty headlight harness and it hasn't failed me in over three years, most of my driving is at night. I think leddzepp is using the one from lmc too.
#45 |
Why would it not be correct? It is brighter from increased voltage through the relay set-up. That increased brightness is because it is running hotter (through the higher supplied volts). It may not last less than the manufacturers designed hours of use if it was rated at full 12v (or 13 or 14) but it will certainly last longer at a reduced voltage (through stock wiring). I don't know if the reduced hours is appreciable but it is real.
#46 | |
20' Daredevil (Ret)
Power for the headlights is controlled by a switch on the dash. This is *not* a great place to tap into the system, for two reasons: The headlamp switch uses tiny, high-resistance contacts to complete circuits, and the wire lengths required to run from the battery to the dashboard and all the way out to the headlamps creates excessive resistive voltage drop, especially with the thin wires used in most factory installations. In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages: 10.5V : 510 lumens 11.0V : 597 lumens 11.5V : 695 lumens 12.0V : 803 lumens 12.5V : 923 lumens 12.8V : 1000 lumens ←Rated output voltage 13.0V : 1054 lumens 13.5V : 1198 lumens 14.0V : 1356 lumens ←Rated life voltage 14.5V : 1528 lumens http://www.danielsternlighting.com/t...ys/relays.html
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 10-05-2014 at 03:26 PM. |
