Old 06-13-2012, 07:07 AM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Dash lights?
Originally Posted by x ReAcT x View Post
PLEASE TELL ME WHERE AND HOW YOU HOOKED UP THE RPM GAUGE LIKE THAT?!?! I have been searching everywhere and i cant find a single way to do it. My fuel gauge is right where your rpm gauge is. Was that how yours was originally or did you buy the truck with that option just like that?
I moved the pins(wires)in the cluster plug
changed engine sensors
it was idiots before
power comes from the pink power wire
neg from ground block @ ebrake
(which is not stock)
when stock the tach has it's own harness,
I've been told it goes threw the firewall
as white,black and a thick brown
only my signal(brown) goes under hood
if you go in that far
1. add a better cluster ground
2.you can totally remove the seat belt buzzer/wires/clip
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-13-2012, 03:00 PM   #27
HotRodScottsdale
HotRodScottsdale's Avatar
Re: Dash lights?
Originally Posted by bowtiemanchevyman View Post
i change my light to LED's and i love them. I got my off EBAY for $17 and i got 16 feet of it. i changed all my light in my dash, High beams, Left, right turn signal. they work great just had to changed my fuse to a lower on cause they dont pull that much amps. i used three feet and i went down to a 2 amp fuse. sorry my pic is not good of how they look when they are on.
I want ur cluster, I like the blue letters in it, how did u do that or where did u get it from
On a quite night you can hear a ford rust
HotRodScottsdale is offline   Reply With Quote
Old 06-13-2012, 10:46 PM   #28
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Dash lights?
i got it from APC like 6 yr ago. You can go to this place http://www.whitegauges.net/pages/White-Face-Gauges.html, they make white gauges that go one really easy. you can even change your heater. they even make different color face from blue to red. they start at 19.99 add color for 30$ more.
bowtiemanchevyman is offline   Reply With Quote
Old 06-15-2012, 03:55 PM   #29
x ReAcT x
Re: Dash lights?
That doesnt seem too bad i should look into getting it switched. Do you know where i could buy a rpm gauge like that?
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 06-15-2012, 05:55 PM   #30
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Dash lights?
some get lucky in the junk yards
some find them on evil bay
some find new friends with old parts........where i got mine
John
Old 06-17-2012, 04:05 PM   #31
x ReAcT x
Re: Dash lights?
Well it looks like i have to start hunting at the salvage yards..
Old 06-17-2012, 04:18 PM   #32
x ReAcT x
Re: Dash lights?
By the way thanks for the picture thats gonna help me out quite a bit
Old 06-18-2012, 06:11 PM   #33
rfmaster
rfmaster's Avatar
Re: Dash lights?
Back to 168/194 to LED conversion. I did some current consumption measurements:
Supply voltage 13.8 Vdc
GE 168 350mA (4.83Watts)
WLED-x5 20 mA (0.276Watts)
I ordered and received 10 WLED-x5 (bright white) because of one key features of these LED's --- they are non polarized! You do not have to worry which way LED or socket are plugged in. In my earlier 2009 attempt to convert from 168 to LED's I used single active LED from Ebay vendor. The end result was pitifully dull lit instrument cluster. In addition these LED's can be dimmed - the supply voltage can be varied from 8 volts (no light) up to 13.8 Vdc for full brightness.
Sorry about the photos, they are crappy and should be re-done (from my crack-Berry)
Top
GE 168
Bottom
WLED-x5
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
