06-25-2012, 04:26 PM | #26 |
Re: How low is too low? (Static Drop)
im 6 1/2 in front with 215/70/15 but i left the bump stop and shaved the rubber down so on really hard bumps there is somthing to stop the travel or the a arm will hit the ground
06-26-2012, 01:55 AM | #27 |
driving is in my blood
I had my old 79's control arms about the same height off the ground as the op with 255/60/15's. I drove that thing everywhere for a couple years. Only took out one pair of control arms the entire time! Rode great though, handled good and looked awesome.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-28-2012, 12:51 PM | #28 |
i wish i was that low, just be a cautious driver and you will be fine.
looks awesome! |
06-28-2012, 01:53 PM | #29 | |||
needs more $$$
I'm with everyone that it looks great at that stance...but I'm also with the guys below. I don't know anyone personally that's had this happen, but I've seen the devastation that happens from online pics when an arm catches a man hole cover/ridge in the road and it would worry me too much to drive it. Not only for the sake of the truck being totalled, but also for my own safety and my passengers...
1970 2wd Blazer |
07-05-2012, 02:57 PM | #30 |
i'd say you needed 1 more inch of clearance to be safe. you could go up a little in tire to gain a little more clearance or you could take the truck to a muffler shop and have them add a 1/4 inch skid plate under each lca. something that would be a tad angled in case it need to slide over a dangerous lip of some sort. it would also strengthen the lca
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-05-2012, 08:54 PM | #31 |
I'm running 5.5 drop in the front of mine, and had the same problem. I bought energy susp. front bumpstops and cut them in half. It made a huge difference. no more tire rubbing inner fenders
07-07-2012, 02:40 AM | #32 |
Nice looking truck, perfect stance! I'm running a similar setup in my 72. I have 2 1/2" drop spindles with 2" drop springs in the front. I would say my truck sits about the same in the front as yours. That being said....I havn't had any issues yet with the suspension or lower control arms hitting the ground, and i live in a town with a lot of brick streets and potholes. I do have issues with the front tires rubbing on the tops of the inner fenders on the outside edge of the tires when i hit a bump or turn too sharply. The only fix for me would be to get a different wheel backspacing and tire size, [still has the 8" truck rallys up front], or install 1" lowering springs instead of 2" in the front. But i like the way mine sits now so i just drive slower and pay more attention to the road, not a bad thing to do anyway! Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
07-07-2012, 10:11 PM | #33 |
Sanford what size area your tires how much drop for the rear? Love the stance and that lb got one myself.
Posted via Mobile Device |
07-10-2012, 09:26 AM | #34 |
you guys, when i look at his pictures the lca's look way to close to the ground. i dont care who thinks they have the same drop and his is like theirs and they never scrape and stuff. look at his clearance....not enough clearance to drive safely. he needs to gain another inch of clearance either by tire or suspension. think about when his suspension is working...his crossmember will be really close during bumps. all i can say is make sure to keep the right air pressure in those tires!
