#26 |
Re: 56 step/C5/C6 Z06 BBC
that looks great!
#27 |
Looks real good.
Kim |
#28 |
What a great build, that is called a cam blank, right? Cool 29lb engine, could have used it quite a few times as I usually build a B block for everything. Cool project, will be watching the progress.
#29 |
56 - autocross
Chevette:
I cant believe that I have not seen you build until now. Great stuff!!!!You have a lot of imagination. ![]() |
#30 |
Thanks hotrod1. It's been fun so far. Just wish it was progressing a bit faster. I haven't had much time to spend on it.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#31 |
Thanks Kim.
Thanks Seanery. Thank You Mud.man.rj Hope to get back in the garage this weekend. Too many distractions lately. Kim: you know how that works. ![]()
#32 |
![]() Join Date: Jul 2011
Chevette:
Is there any chance of getting some mockup pics of the rearend , when the bed was not on? How much do you think it weighed? What is the distance from the center of axle to the slender part of the torque tube?
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#33 |
Shadow: These are the only pictures I have without the box sides on. I with be removing the box next week and can take some more for you. The distance from the center of the rear axle to the beginning of the slender part of the torque tube is 31.5".
#34 |
Thanks!!!!!!
#35 |
56 - autocross
Chevette:
How do you make a frame table like you have and get it perfectly straight and "level?" I can build anything on my garage floor as it is not close to level or straight. |
#36 |
Hotrod1: In those pictures the frame table was not yet complete. I added more cross members and six screw jacks to level it out. I will take a few pictures and post them for you. It works real well and the table is 100% plumb and level.
#37 |
56 - autocross
I am just not too sure how to build it so it comes out flat.
#38 |
Laid it out on the floor and shimmed the pieces until all was true (used a 5 axis laser and a 6 ft. level). Clamped it, tacked it, rechecked it, then welded it. A friend, whose a journeyman fabricator was in charge. After the screw jacks were added and all was level, I welded in more cross members and verticals. Then welded the truck frame pieces to the frame table. When all is finished welded I will cut the truck frame away from the frame table, then I will try to find a place to store it until my next project. I'm very short on space, maybe I should just sell it.
#39 |
56 - autocross
thanks.
#40 |
Chevette, That is going to be a bad a$$ truck. Great job. What size is the tubing on your frame table?
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#41 |
Thanks Shannon. I'm using 2"X4" and I'm going to add an x-member with plates that add additional strength to the mid section. A structural engineer (friend) spec'd it out for me.
#42 |
Nice update on the avatar. Who did the rendering? Looks pretty cool.
#43 | |
BTW, are you the fellow that was looking for the C4 suspension? If so, there's a guy on the mainland selling the front and rear in great shape for $1200. It's on CL. Sorry if I'm confusing you with someone else from the island. ![]()
#44 | |
#45 | |
#46 |
I got a bit carried away today. I started to cut off the gutters and decided to get rid of the crown molding at the same time. As it turns out, it's way more work than I initially thought it would be.
#47 | |
#48 |
the more i look the more i like. Even the engine sitting back in the cab will help the balance. With the engine set back and the transaxle, this should be a well balanced truck!
#49 |
Godd lord those tires are huge! What wheels and tire sizes are they? Looks awesome. This truck will be killer when done.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#50 |
Thanks OKGMC4: I only wish I was driving it like you're doing with yours (great looking truck BTW). The wheels are 19"X12" and those tires are just 305/30/19 mock-ups. I'll be installing 335/30/19's rears and 285/35/18's up front as soon as the truck near finished.
