Old 07-08-2012, 08:09 PM   #26
beamn7
Re: Heater core shut off valve installed
My 85 Silverado doesn't have a heater control valve either. Just a blend door in the hvac unit....
Alot of motorhomes and stepvans still use the manual / cable operated heater control valve....
CJLINKSTER, your truck was not equipped with A/C from the factory. As mentioned, you have a Sanden compressor and the evaporator is not outside the firewall in the split case as a factory unit would be. May have been added at the dealer level. Was not uncommon to have that done....
beamn7 is offline   Reply With Quote
Old 07-08-2012, 10:23 PM   #27
WarBeard
WarBeard's Avatar
I just went Out to look at my 89 V2500 Suburban and i don't see one either. I installed the same Autozone valve on that one too 5 or 6 years ago.
GM cars Always seem to have more bells and whistles than the trucks. I had two Cadillac's A 77 and a 81. When you opened the hood on one of them bad boys. It was 100 miles of vacuum hoses and valves LOL. What a nightmare!
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-09-2012, 04:53 PM   #28
tucsonjwt
I just joined the manual heater valve shutoff brigade. I got the same valve from O'Reilly for $11.44 with AZ tax - actually it was "free" because I used store credit cards I got from previous purchases of on sale oil, etc. The brand they had was Murray, but it looks the same. It does seem to make the A/C run cooler in the 100 degree ambient temperature with 454 heat blowing off the engine. I will keep an eye on the temp gauge to see if it creeps up on me.
tucsonjwt is offline   Reply With Quote
Old 07-09-2012, 09:47 PM   #29
WarBeard
WarBeard's Avatar
Welcome to the club!...Now I'm driving this truck every day since the heater is not on during the summer!
Old 07-10-2012, 10:48 AM   #30
Tucson38
How about using a ball valve from a plumbing supply place? Home Depot has one with with male barbed fittings (shark bite). These types of valves have heat ratings of either 200, 250, or 300 degrees.
Tucson38 is offline   Reply With Quote
Old 07-10-2012, 12:56 PM   #31
TDS-MN
How does this actually work? doesn't it create a 'dead-end' for the coolant flow? Granted that's probably low pressure (based on water pump flow) but still? Wouldn't a return or bypass be a better way to accomplish this end result? Just asking, as I would think that would not cost much more to loop the flow. . .
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 07-10-2012, 04:54 PM   #32
WarBeard
WarBeard's Avatar
I would just be more money to get the same result. I think the valve alone is like 10 bucks. and then you need to get the 2 barbed fittings.
Old 07-10-2012, 05:01 PM   #33
WarBeard
WarBeard's Avatar
It does create a dead end. But it doesn't matter, it wont hurt anything, been doing it for years. Making a loop IMO would dump hot water from the engine directly into the "Cool" side of the radiator and make your temps go up. Plus you will need to install a 5/8 to 3/4 fitting since the line going back into the radiator is bigger.
Plus! When you want your heater back all I have to do is open my valve. If you made a loop you have to reroute your hoses again and add coolant.
Like I said, once a month or so when your under the hood just open the valve and let the water flow for a few minutes.
Old 07-10-2012, 10:54 PM   #34
ghettoluxury
ghettoluxury's Avatar
As stated before Honda uses this from the factory for their heat control. It is a ball valve that is operated by a cable and only turns off the inlet flow. I have owned many Honda cars and never had a problem with heater cores.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
