#26 |
Re: Major TH350 problems
in what way is it broken? also what is the rod called so i can get a new one? thanks a lot for all the help
#27 |
Thanks for this thread! Having similar problems with my 69. Gonna crack it open tomorrow now that I know what to look for.
Posted via Mobile Device |
#28 |
Problem solved! it turned out that the end of the rod was a little bent so the spring wasnt pushing the tapered part down. vice grips and a little wd40 did the trick! Thanks everyone for the help
#29 |
Tightened mine up was shifting good by hand at the tranny. So I put the pan back on filled up the fluids and put the linkage back on. Now it seems real tight at the column and it seems like the gears are closer together. I don't know if maybey I'm missing some linkage or what
#30 |
Is it clo.. or floor ****?
If the trans is shifting good at the trans I would look at the links in the clom.. or links in the floor shifter. Hope this helps. |
#31 |
It's a column shift and it does feel tight at the column. Also the gears seem real close. I've adjusted the linkage as good as I can get it for now. Seems like the linkage is pretty worn out. Has any one ever had theirs over shoot park? Before tightening it seemed to clean up a bit but it just doesnt feel right. I dunno I'm not knowledgeable on trannies at the moment
#32 |
Didn't mean to hijack this thread by the way. Sorry
