Closed Thread
Old 10-04-2020, 12:16 AM   #26
conoco
conoco's Avatar
Re: 1967 - 1972 GMC Heavy Duty Headlight Harness
Originally Posted by maverickmk View Post
They don't suck, they just need to have some wires switched around to make them work properly. I have the LMC harness and after I swapped the wires it works fine. I forget the exact swap, but I'll see if I can dig up the info.
That would awesome, thank you. I was gonna purchase anyway and hope for the best lol
conoco is offline
Old 10-04-2020, 03:51 PM   #27
conoco
conoco's Avatar
That would be really helpful thank you.
conoco is offline
Old 10-04-2020, 04:24 PM   #28
maverickmk
I remembered I had received a PM from mygmctruck1 explaining how to correct it.
Here it is below - all credit goes to to mygmctruck1:
On the low beam / high beam plug. The correct wiring is as follows. Looking at the back where the wires go in.
* The Black (gr) wire goes in the left slot
* The Brown / Tan wire low beam goes in the top slot
* The Green wire hi beam. Goes in the right slot
** Both of the 3 wire 3 prong plugs need this change
No change is needed with the 2 wire plug
LMC wired it this way - looking at the back.
The Brown wire is in the left slot
The Black (gr) wire is in the right slot
The Green wire is in the top center slot
maverickmk is offline
Old 10-14-2020, 05:07 PM   #29
Awann99
Hi. I attempted to place an order for the harness but the site said your inbox was full. Is there another way I could get in contact with you guys. Thanks.
Awann99 is offline
Old 10-15-2020, 08:01 AM   #30
maverickmk
Who is this question directed to?
Old 10-15-2020, 10:53 AM   #31
Awann99
This was directed to VH coachworks.
Awann99 is offline
Old 10-15-2020, 11:14 AM   #32
maverickmk
Gotcha' - they haven't been logged in since 23 April 2014, unfortunately.
Closed Thread
harness, headlight, mod, relay, wiring
