Old 09-16-2012, 10:00 PM   #26
Patch
Patch's Avatar
Re: My "New" 1991 2500 Burb
Wondering the same thing myself...lol...
Patch
Patch is offline   Reply With Quote
Old 10-01-2012, 10:16 PM   #27
truckfan
truckfan's Avatar
OK. I'll watch others work. i seem to be good at it!
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 10-01-2012, 11:50 PM   #28
Patch
Patch's Avatar
Well.....I'll get pictures on here tomorrow.....she's a bit taller now....updates to follow...
Patch
Old 10-03-2012, 03:34 PM   #29
Patch
Patch's Avatar
Here she is...zero rates for the rear are on there way...has the usall squat...even with the 6 inch shackles.....and...it's parked on a slope....made moving the axles around quite fun.....Something I hadnt really thought about......transmission and transfer case are yet to be installed.....hmmmm....that could change things up front a bit.....damn. It's on 35's right now....
Patch
Old 10-04-2012, 07:54 AM   #30
DBLSPRT68
DBLSPRT68's Avatar
Looks good!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 10-04-2012, 10:56 AM   #31
68Timber
I know the pieces fit
68Timber's Avatar
Burb's look killer on 35's... Noice!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-04-2012, 11:22 AM   #32
Patch
Patch's Avatar
Definately going to need steps.....hoop type...not running boards. Thanks guys....
Patch
Old 10-16-2012, 11:31 PM   #33
gmachinz
ahhh..I wondered about the 4L80E thing...must be a 91 year only for the 3/4 tons then? I have a 90 with the TH400. I found my TBI454/TH400 2WD Burban while looking for a decent truck to pull a trailer behind. I like the look of yours with 35's! Killer stance!
gmachinz is offline   Reply With Quote
Old 10-25-2012, 12:57 AM   #34
Mr. 250r
Mr. 250r's Avatar
It is a 1 year thing for square bodies
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-26-2012, 05:13 PM   #35
Patch
Patch's Avatar
Whoo-Hoo!!!
Okay....I'll stick with this rear axle now...... Might have to move the perches... haven't checked yet.....I Love Craigslist......
Patch
Old 10-27-2012, 05:08 AM   #36
chevak20
Great looking axle there. I have been thinking about getting one for my Suburban myself. They're a little wider though than older 14 bolts. But then it lines up better with the front axle width, don't you think?
It bothers me that the studs are metric, special nuts to keep track of for the rear only.
What is needed to hook up the parking brake cables?
chevak20 is offline   Reply With Quote
Old 10-27-2012, 12:40 PM   #37
68Timber
68Timber's Avatar
Wow, looks good. What year model did that come out of?
John
74 Honda Z50 build
Old 10-27-2012, 09:11 PM   #38
Patch
Patch's Avatar
Thanks....I believe it came out of a 2006 HD...still need to measure...but no matter what...she's going in....lol
Patch
Old 10-27-2012, 09:15 PM   #39
Patch
Patch's Avatar
The lug nuts aren't an issue....and I haven't checked the connections for the cables....but I'll make em work......
Patch
Old 10-27-2012, 09:49 PM   #40
Mr. 250r
Mr. 250r's Avatar
You will be moving the perches as the axle is about 3in wider total i think or 1.5 on each side, don't bother trying to save the perches and just buy these http://www.ballisticfabrication.com/...ch_p_1485.html they are awesome/cheap and have multiple sizes and end pieces if you want to weld those in
The parking brake is still an issue for me on my suburban i can't find any parking brake cables from newer trucks the right length so for now i won't be using them and the brake lines work if you use your original brake junction block im pretty sure
2003 1500 Silverado
Old 10-27-2012, 09:49 PM   #41
Mr. 250r
Mr. 250r's Avatar
doublepost.
2003 1500 Silverado
Old 10-27-2012, 10:25 PM   #42
gmachinz
Ebrake cables can be custom made....
www.controlcables.com can make them to whatever length you need. You need to give them an overall length and give.them pic of both ends so they can make them. I don't have their number handy but their site has contact info. I've had them make cables for me before....good company to deal with for custom cables.
Old 10-27-2012, 10:36 PM   #43
Patch
Patch's Avatar
I figured I would be moving them in.....Slice down the middle...grind on the sides....and fit the new ones one side at a time on a pair of concrete blocks.....that way it stays the same pinion angle.....did it that way on a D60 axle once...worked like a charm. I wasn't too worried about the cables...I knew one way shape or form they were going to work...Thank's for all the good advice fellas.....
Patch
Old 10-27-2012, 10:48 PM   #44
Patch
Patch's Avatar
The pads inboard of the current spring perches...what are those? Is this the crossover axle before the 10.5 and 11.5 AAM's?
Patch
Old 10-30-2012, 02:44 AM   #45
Patch
Patch's Avatar
Thanks for the link to the spring perches...ordered them up!
Patch
Old 11-04-2012, 10:29 AM   #46
SIC-K5
nice build, what are your plans for the burb? Just driver, offroad.
SIC-K5 is offline   Reply With Quote
Old 11-04-2012, 01:01 PM   #47
Patch
Patch's Avatar
Thanks! Well.....for now....just a driver. I'd like to get some sort of sliders built for it and get corner protection on it to be able to use it more seriously offroad.....the problem is.....after all the work going into something like this....I'm a puss when it comes to potentially damaging it....lol. I also want to use it for hunting/camping and survival if the situation ever happens. I got the original perches cut off last night from the 10.5 AAM.....die grinder.....sledge hammer and about 45 minutes.....whoo-weee.....that was fun. Now I still have those inner pads to remove...(still dont know what those were for) and then get it cleaned up and weld my new perches on. I havent checked on the shock mounts to see if those have to be moved yet...my luck...probably will...but no biggie....I just bought more wire for the welder. About the original perches.....although the new ones from Ballistic Fab are 1 1/2 inches tall....the factory ones were even taller than that...so....we'll see if I still need the zero rates I got from DIY4X. I also got a factory steel skid plate for the gas tank off of a 91 Burb....and it appears to be plenty stout enough....so that part is covered.
Patch
Old 11-04-2012, 01:09 PM   #48
86454k30
86454k30's Avatar
Did you have to drop the fuel tank to put the shackle flip on?
86454k30 is offline   Reply With Quote
Old 11-04-2012, 01:27 PM   #49
Patch
Patch's Avatar
I undid the straps...and disconnected the filler hose. Supported it with a jack and just kinda made my way around it with it in the halfway down position......MUCH easier than tryng to fish the brackets back in there...even with the capsulated nuts. That SOB is still heavy empty!
Patch
Old 11-14-2012, 10:01 PM   #50
gmachinz
Control Cables # is 562-949-0455. I used to use them a lot for my rear disc conversion kits on gbodies in my shop-not so much with trucks with the availability of newer disc rears and cables that can be made to work-still a good option for those who want to retain the factory e-brake features.
