Old 12-05-2012, 09:42 AM   #26
VWNate1
VWNate1's Avatar
Post Re: running hot
Yes , ALL engines have block drains , often plugged up , once you remove them it's a simple thing to probe in the hole and scrape out depositsa & evaluate the level of accumulated silt with an unbent coat hanger....
Keep at it until ALL the silt is gone for factort fresh cooling in Death Valley in August...
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 12-05-2012, 12:12 PM   #27
Lemield
Lemield's Avatar
Re: running hot
Thanks for the info Nate.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 12-05-2012, 12:20 PM   #28
yuccales
yuccales's Avatar
Re: running hot
Originally Posted by Dunenutt View Post
Is your trans mount in good condition? If it is broken, it will kick the fan toward the top of the shroud. New motor mounts with old trans mount will do it too.
^This^ Also could your front clip/rad support mounts be in bad shape letting your rad support settle down?
yuccales is offline   Reply With Quote
