#26 |
![]() Join Date: Sep 2009
Re: 1966 GMC Truck Project
as far as wireing goes for gauges i used the wiring diagram that is on here somewhere. it's for chevy but it worked. i used dolphin gauges they are not real expensive and look good.
#27 | |
Thanks again. |
#28 |
Ok, worked on the dash this weekend. Got the wood cut out and prepared, then the glass (it was a bit of a test due to the different levels of the gauge faces), and then got everything mounted together. I also could not find any front G M C letter for the grille... so more wood!
#29 |
Here is the final assembly
#30 | |
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#31 | |
Thanks for the comment. The steering wheel was on the truck when I bought it, but I have seen some similar ones on e-bay, you may want to look there. Hope that helps. Like your panel truck, how is the build coming along?! Cheers |
#32 |
i like the wood work!!! cant wait to see the letters for the grille !
#33 |
my build will be slow as molasses in january ..i'll check out ebay for a cool steering wheel
#34 |
#35 |
Nice job on the wood work, gonna be unique and thats good..
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
#36 |
#37 |
Nice wood skills. I would have been tempted to laminate some plywood with an exotic wood burl like redwood burl or maple burl but that is the long lost woodworker in me.....
#38 | |
Yeah, that would be a great way to go with some really nice redwood! This time I kept it simple and reused the old oak wood from the bed, still have plenty of planks left for future projects! thanks for the post. cheers. |
#39 |
I found that the gas fumes were coming into the cab due to a cracked filler hose (thanks markeb01), so I decided to tackle the job today. Here are some pics of what I did.
Tank in truck Cab without tank Tank Cracked hose Touch up paint in cab |
#40 |
Ok, worked on the tank today, got the hose attached, but had trouble getting the tank to fit correctly with the hose. Needed more room to work with, so decided to cut out a section of the cab. Should not be noticeable, as it is covered with the cab lining, but may need to weld the piece back in.
Anyhow, my boy's helped me as usual and we got it back in successfully. |
#41 |
My parts from classic parts arrived, so they will find there way into the truck over the next couple of days.
old and new |
#42 | |
#43 |
#44 |
nice work
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#45 |
Nice Truck, love to see old gmcs in process. I have a 66, here is what my dash looked like after we finished it. Kieth
![]() ![]() how it looked http://kieth.smugmug.com/Trucks/66-G...5370&k=qBsq92W how it looked after: http://kieth.smugmug.com/Trucks/66-G...5370&k=qBsq92W it is a stock dash with stock gauges, just jazzed up a little. Kieth Keep up the good work. ![]() |
#46 | |
I need to ask you about your front grille. I was going to have my chromed but ended up only getting the front bumper done. I like what you did with yours and the color, what is that? Thanks. russell |
#47 | |
![]() Quote:
![]() BTW: nice job on the seat, bed and on the dash-start! |
#48 |
#49 | |
I painted the grille the same medium fawn metalic as the interior, just did not have the paint mixed flat. I painted the gmc letters in the center to match the truck color. The green is the standard dietzler light green but instead of having the color mixed normally we replaced the white with metalic silver and the solid yellow with transparent yellow. We did a white sealer then overlaid 3 coats of base green then 3 coats of polyurethane clear. It took a lot of base coat, but it is relatively inexpensive. Thanks for the compliments but it surely is not perfect, we know every flaw in the truck but I have put 6,000 miles on it since getting it back together and we really have a lot of fun with it. Yours looks great just keep plugging away. Kieth ![]() |
#50 | |
russell |
