#26 |
Parts!
![]() YAY Parts! I got my rear shock relocator kit from CPP today. Heres a pic. ![]() You like my workbench? ![]() Next I will be getting the Rear Suspension Crossmember frame section, Automatic Transmission Crossmember, and '71 Accelerator Pedal Assembly.
#27 |
Re: 1968 Chevrolet SWB Stepside Restomod
very nice work so far! keep it up
#28 |
![]() Today I installed the CPP rear Lower shock relocation brackets just to get it out of the way so its done before I replace the rear Suspension Crossmember. I was surprised how much the angle of the shock changed just by installing the lower brackets. Sorry no pics because everyone who has done it already knows what it looks like installed, but once the new rear suspension crossmember and upper shock relocation brackets are installed I will post some pics. |
#29 |
I have an opportunity to pick up a Original GM '71 truck Tilt Column for $250 that is right and tight.
Good price? Opinion Yes - No? |
#30 |
VA72C10
![]() Join Date: Mar 2008
VERY nice price if in good shape and a true truck tilt...not a van or motor home tilt.
Looking for a 67-72 swb or blazer project in or around VA.
#31 | |
Thanks VA72C10 |
#32 |
*Update*
The Original GM Truck Tilt isnt going to happen because of unforseen circumstances. Back to Plan A which is to get the Rear Suspension Crossmember, Automatic Transmission Crossmember, Parking Brake Assembly and Accelerator Pedal Assembly taken care of. Last edited by Xeen; 09-08-2012 at 12:38 PM. |
#33 |
![]() Today im heading up to KC to pick up a bunch of parts most notably the rear suspension crossmember frame section. The other parts im getting are Automatic transmission crossmember, Accelerator Pedal Assembly, Ash Tray, Door Handle Gasket Set, Door Lock Knob Set, Defroster Outlets and Pedal Pad Set. Other parts I might pick up include, Used Foot operated Parking Brake Assembly and assorted Cables and Connectors, Wing Window Assemblies, Disk Brake dust Shields, new SS Booster Line and RH Headlight Bezel, it all depends on what the cash layout is going to be for everything. |
#34 |
![]() Today I painted the Accelerator Pedal Assembly and the Parking Brake Pedal Assembly. Here are some pictures. ![]() ![]() ![]() Next I will be painting the Automatic Transmission Crossmember stay tuned. |
#35 |
I had a "little" accident today, I was shaving the head off of a frame rivet when the edge of my 4 1/2" cutoff wheel caught a bracket and shreded and ripped the angle grinder out of my hands and it hit the ground and jumped up and the serrated edge hit the side my leg just above my knee and sliced a 2" long 1/2" deep gash, however I got rediculously lucky and it didnt hit an artery or bone or tendons or anything so after I realized it wasnt life threatening I grabbed a roll of paper towels and headed to the med assist and after a thorough irrigation he stitched me up and I was on my way in about an hour.
The Doctor told me that he was shocked I walked in here that most people would have passed out instantly, and I was all like hell Doc its just a scratch just stitch me up and I will be on my way, everyone was all concerned asking me if I felt ok and I was calmly answering questions LOL. Other than feeling like an idiot I'm doing ok so in about 10 days when the stitches come out I will start on my truck again. Last edited by Xeen; 08-05-2014 at 08:50 AM. |
#36 |
VA72C10
Get better soon! Glad you're okay. Could have been worse! I've gotten "bit by a grinder a few times....the most annoying/painful to me are the wire wheels as they discintigrate and impale into your leg....they hurt a little at the time but itch like crazy as they heal...like a bunch of little paper cuts
![]() Posted via Mobile Device
#37 | |
I need to learn something from this and get some safety clothes, like maybe a heavy leather apron or something sheesh. |
#38 |
Something caught my eye today and it got me thinking.
I have been trying to decide between a naturally aspirated chevy 327 and a 350. I think I will build a Twin Turbo small block instead. So It looks like its time to start saving up some cash, and start looking for a good 4-bolt main high nickel content block to build the hell out of. 10 seconds here I come! |
#39 |
VA72C10
Cool!
#40 |
After talking it over with VA72C10 I'm now rethinking my idea of the Twin Turbo.
There are tons of engine and transmission options out there for me so I need to give it some serious thought considering it's an expensive decision. Also I still need to reconcile the geometry on my Cab and figure out exactly where the mistake is that the PO made on the drivers side when he "fixed" the floor and Inner/Outter rockers. I think the B-Pillar fit and fair slipped towards the front, I'm pretty sure its a simple cut and reweld job but I wont know for sure untill I measure. I wont be doing anything on my truck until the first of November. Nov 1st I will be ordering a bunch of new parts. Tilt steering column, probably a CPP Classic Fit, here is a Link incase you want to check it out. http://www.classicperform.com/Store2...ng-Columns.htm A new Steering Wheel, probably Grant. A rear mount gas tank, probably from LMC. Some brake hose tabs so I can finish up my 1972 Disc brake conversion, here is a link incase you want to check it out. http://www.speedwaymotors.com/Remova...ose,45896.html Im going to try to source a Leather 40/20/40 Seat with electric adjustment and heating elements. Misc. Parking brake parts to finish it up. Replacement 1971 plastic ashtray guides if I can get them. Defroster vents. Various other nicknacks I will update when its all ordered. |
#41 |
![]() Join Date: Aug 2012
#42 | |
#43 |
First, I only started 3 months ago. So I guess I will be done in the summer of 2014. I see some of your parts and now I need to buy somemore. I got in touch with Auto Zone and they have the upper and lower ball joints for 13.97 a pair and I guess I will be getting them this week. I will then be able to start putting my front end back together.
#44 | |
#45 | |
Re: Power Disc brakes
#46 |
#47 | |
Re: The Cab
#48 |
I have to get busy and order a radiator core support. There is a company in St. Peterburgs, Fl that has several so I will be driving down there in a few weeks. 75.00 to 150.00 is not bad.
#49 |
#50 |
I know its been a bit since I have updated.
I had to save up some more cash for the next few steps because they are slightly expensive. There are some good things comming the first week of November, stay tuned. |
| Bookmarks |
| Tags |
| 1968, chevrolet, restomod, stepside, swb |
