Old 02-20-2014, 12:32 AM   #26
Trsmotrhed
Trsmotrhed's Avatar
Re: over flow tank
Here's what I used.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 02-20-2014, 11:17 AM   #27
Billett
Billett's Avatar
Re: over flow tank
Man, I forgot about this one... I ended up using a bottle of Captain Morgan Private stock haha. Don't have a good pic of it right now though
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-20-2014, 12:02 PM   #28
chevyrestoguy
chevyrestoguy's Avatar
Re: over flow tank
Originally Posted by 64shortbox View Post
Here's what I did. Over flow tank and windshield washer all built into one. Pick N Pull on 1/2 price weekend these were in a varity of Ford products. Full size trucks, Explorers, Mercury Cougars, etc., etc. It looked pretty crusty when I bought it. I used the Lowe's cheap version of CLR filled the over flow part with it full stength, let it sit over night then swabbed with a rag & a screw driver followed by a spray of Armorall and it looks new. not to mention it has a built in washer pump and now I have windshield squirters too. Oh, I also got the squirt nozzels off a full size Ford truck too. I had to do a little tweeking on them to get them to spray between the cowl vents and hit the windshield in the right spot but it worked out great for me. The cut of the over flow fits our inner fenders almost perfectly. I did have to move teh horn relay and the voltage regulator to the other side of the radiator support but I was able to use the exact same mounts & mounting holes so I didn't even have to drill any new holes for that part.
I like this idea a lot. It handles two functions (radiator overflow and washer bottle) and the angle of the tank matches the inner fender angle. Very slick.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-20-2014, 01:45 PM   #29
doobiebro
doobiebro's Avatar
Re: over flow tank
Originally Posted by 1Bad62Pro/Street View Post
Hey Bud,
I see you have a Champion Radiator. How do you like it?
Pro/Street 3 years this may and going strong!!! Very happy..
Originally Posted by gofastnut View Post
Doobie, I see you have a serpentine set-up on there. Is it a retrofit, or a newer engine?
Tricked out engine....R U ready for this!!
283 (67 block) 350 heads 90-91 S-10 blazer v-6 serpentine belt front assy complete....
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 02-20-2014, 01:48 PM   #30
doobiebro
doobiebro's Avatar
Re: over flow tank
Hows it mount? ...man lets see sum pics...
Old 02-20-2014, 09:40 PM   #31
grs
Re: over flow tank
Originally Posted by markeb01 View Post
Yes mine is several inches away from the radiator support because it’s mounted to the electric fan attaching hardware. Also my washer bottle was too close to squeeze it in. If I didn’t have those items in the way it could be mounted directly to the radiator support. It’s very easy to install, having T-bolts that slide up and down in the extruded slot. This provides very flexible mounting adjustment.
Here’s what the mounting looks like in my truck. First is a side shot. The upper and lower attaching nuts can be seen to the left of the tank. I formed hard lines for both the inlet and outlet:
This is looking straight down from the top. The upper attaching nut can be seen near the center of the photo:
This close up almost shows the mounting slot, and the lower nut can be seen somewhat blurry directly below the upper nut:
And I remembered wrong about the mounting bolts. They aren’t T-bolts, they’re standard 1/4x20 bolts so you can use whatever length best fits your application. Here’s a rather crappy shot of the slot showing the upper bolt:
And now that you've pointed it out, it would look a lot better tucked in up against the radiator support. With the inner fenders out of the way I think I'll move the washer bottle over and move it next to the radiator. Thanks for the idea!
Can the tank be turned inside the bracket? And who bent your brake lines. I can never get them turned that sharp without them kinking.
grs is offline   Reply With Quote
Old 02-20-2014, 11:16 PM   #32
TR65
TR65's Avatar
Re: over flow tank
Here is mine. It is a Canton.
http://www.summitracing.com/parts/ctr-80-201/overview/
More expensive than I remember but it is a very nice piece.
I like the sight glass so I can see at a glance if the system is leaking. It is low here - my Champion Radiator core is leaking. Replaced with Griffin. http://67-72chevytrucks.com/vboard/s...d.php?t=615934
The overflow from the radiator cap goes in the bottom of the tank when hot and sucks back into the radiator when cold. The upper hose is the overflow to the ground (shouldn't ever be needed).
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-21-2014, 03:25 PM   #33
doobiebro
doobiebro's Avatar
Re: over flow tank
TR
Looks good TR65... might look into that piece in the future...
Old 02-21-2014, 04:24 PM   #34
1963c-10
1963c-10's Avatar
Re: over flow tank
I turned the factory washer bottle into an overflow and mounted a new washer bottle on the heather bolts. Just had to open up the washer mount 1/8" to work on the heater bolts. Still looks stock and uses all stock hardware. Also mounts the washer closer to the firewall and eliminates a lot of hose for the line to the washer pump.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-21-2014, 08:10 PM   #35
ACK
ACK's Avatar
Re: over flow tank
Inspired by the Persh website, I put this together with PVC, some brass pieces, and fuel line
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
