#26 |
Re: 72 2wd Blazer....Out of the grave.
Thanks Kurt L and 1972trucks, Crossville is not far at all for me and it saves alot in shipping if i get a parts list of all i can afford at the time and just make a few trips up there.
I was thinking the same phat tony on the droop issue but i did take another look with some masking tape this afternoon and it looks like the fender, door, and the front of the bedside are close then my tape gets above the line from the front of the bedside to the rear, the rear bed floor mounts are shot as in no rubber left in the rear two and the ones at the rear of the wheelwell are pretty bad also. My inner bedsides look fairly solid to my suprise but i did pick up the top a little and found some ugly under the seal. Most of this project will be done in my carport so i need to plan my jobs where im only workin on a couple pieces at a time so i may get started on the frame and susp. first then reinstall the body starting with the cowl and workin my way back. |
#27 | |
#28 |
Thats what most of us in the rust belt had to do! good luck
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
#29 |
Quick question guys... Do the bedsides simply bolt on the bed floor on the blazer.. All i can find is one small stich weld on the rear below the tailgate hinge and the rocker.... is that it or am i missing something? thanks.
#30 |
If I remember right you are correct
#31 |
Ok guys, ive started a list and i have been dooing some searching for my repair panels such as the inner and outer rockers, rocker boxes, floor patches, rear inner wheelwells, front wheelwells and much more! Here is my biggest question, who sells good and who sells junk parts? ive seen some big price differences and really just dont know who to stay away from and who to use. I dont mind paying extra for a better part but what is the better parts? Iplan to use a couple local guys around the Nashville area to buy most of my sheetmetal from but i just want to know what im buying and not get a pile of ill fitting parts, so to you all that have used these parts give me an education on the better manufactures. Thanks, Heath....
