Old 06-15-2016, 08:42 PM   #26
MTCK
MTCK's Avatar
Re: '77 Camper Special
Looks great! Remind me how much lift you have?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-15-2016, 09:00 PM   #27
Bird_Reynolds
Bird_Reynolds's Avatar
Hey Marcus! Hope all is going well for you. I have 4".
'77 Chevy K20 CHUMMINS
'75 Chevy C20 Crew Cab (mostly) converted to 4x4
Bird_Reynolds is offline   Reply With Quote
Old 06-16-2016, 08:19 PM   #28
rusty76
rusty76's Avatar
Awesome truck! I like the wagon wheels.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-18-2017, 12:20 PM   #29
Bird_Reynolds
I haven't posted in a while but a lot has been going on. After spending a year reading up and buying parts, I finally pulled the trigger on doing a cummins 4BT swap. I will post pix this week.
I could have done a Cummins swap in about 5 different ways, In the end I bought an engine out of a Fedex truck. It adapts directly to a Muncie 4 speed. I put in a Ranger OD. She drives pretty good! Super narrow power band so I am glad to have the OD. She has a ton of leg and it cruises really well on the highway. It is loud and i have to do something about that eventually, but it is fun to drive. I have to admit I miss the V8 sound but so far I am liking it
Old 04-18-2017, 03:02 PM   #30
MTCK
MTCK's Avatar
Man you have been busy on both your rigs! What kind of mpg you pulling down?
-Marcus
Project Plow Truck
Old 04-18-2017, 04:02 PM   #31
El Dorado Jim
beautiful truck!!!!!where did you find the 4bt? that is a cool swap...
El Dorado Jim is offline   Reply With Quote
Old 04-18-2017, 04:24 PM   #32
Bird_Reynolds
yes indeed. Honestly I needed a lot of help to do this, my front end loader is seized and there was some stuff I couldn't fab so I had to buy.
Right now mileage is about 20 total. I am going to keep driving it a couple more tanks and give a solid number. I am just going on little hops and shaking out coolant and fuel leaks.
Old 04-18-2017, 04:28 PM   #33
Bird_Reynolds
I got it from a guy on eBay actually! I looked and looked and finally just pulled the trigger. This thing is pretty cool because it mates direct to the muncie. And it came with everything. Me and my buddy just added fuel and it fired right up. There's a lot to be said for that
Old 07-15-2017, 08:40 PM   #34
Bird_Reynolds
Grabbed some pix of the 4bt swap
Old 07-15-2017, 08:42 PM   #35
Bird_Reynolds
Pictures
Old 07-15-2017, 08:53 PM   #36
Bird_Reynolds
There was a lot of little things that I had to do that didn't think about before hand. Turns out the bell house adaptor tilts the whole shebang about 10 degrees counter clockwise when viewed from the front. This isn't a big deal for the engine, but we wound up with a rotated trans when we were done. Messy. Also swapped the fuel delivery to the driver side. Also re-geared the axles to a small ratio to keep highway rpm down. So many other things, which escape me now
Old 07-15-2017, 11:22 PM   #37
MTCK
MTCK's Avatar
Exciting. How does she drive?
-Marcus
Project Plow Truck
Old 07-17-2017, 07:55 PM   #38
Bird_Reynolds
I am pretty happy with it, so far. I just have to shift more often. I will say the diesel sound when she sits there is pretty cool and people notice. I should say dudes notice.
Other than that, I probably wouldn't do the gear splitter again, I could have laid out a NV4500 for about the same $$ and had a cleaner setup with one less link in the chain to fail. Plus no kooky rotation issue.
With the 3.54 gears and OD, I can do 75mph easy. But a lifted relic like mine is not fun at 75. It does jump off the line. Not kidding. It is un-stallable, and I haven't tried to use the granny gear yet.
I will say, I like the VE 4 cylinder. You can dial them up pretty easy and they are cheaper because guys want the P pump. I will dyno mine, but I have turned up fuel and bigger injectors. And it is so simple! One wire to the fuel shutoff, one to the starter, and you are on your way! And it leaves lots of room in the engine compartment. I dig that. I will probably try an intercooler next year.
