Old 09-17-2012, 08:22 PM   #26
gotchamel
Re: Most reasonable place that sells the radiator filler panels?
Originally Posted by Racie View Post
Just as an update on this subject undercoverinnovations are now offering the panels modded for a/c setups. The website is being re-done but if you call to place your order they will give you the right part number....
Good info.
gotchamel is offline   Reply With Quote
Old 09-20-2012, 10:17 AM   #27
AusTx68
AusTx68's Avatar
I received a response from Derel at undercoverinnovations:
Hi Joseph
Here’s what they look like. The “slot” for the top of the drier is 8 3/4” long and is 13 1/2” away from the hood latch bolt on that side. Rubber edging is included for the top edge and for the drier opening. Since GM wasn’t so kind as to put all driers in exactly the same spot some filing may be required to avoid rubbing the a/c tubing. The rubber edging will cover that up. I haven’t found any trucks in our area with Vintage, Southern, Old Air etc. so I can only assume that they would have used the same mounting points because we don’t like making you drill holes in your vehicles either. Thanks for the inquiry! We hope to have the new site up and running any day now.
Derel Latta
Undercover Innovations
661-325-4506 ext 2
www.undercoverinnovations.com
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 09-20-2012, 11:16 AM   #28
big_al_71
big_al_71's Avatar
I have considered these panels for a while but I think that I will have the same issue with the a/c drier being mounted too high.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-20-2012, 12:10 PM   #29
AusTx68
AusTx68's Avatar
Al, your dryer sits below the latch. That should work since the panel runs parallel to the bottom of the latch. I for sure will have a problem. My dryer sits higher and is 6 inches from the edge of the latch. It doesn't align with the hole in the modified panel. I would have to buy a regular panel and mod it for my application.
Old 09-20-2012, 12:33 PM   #30
big_al_71
big_al_71's Avatar
Looking at your picture I can see the difference between both of ours.
thanks for the help..
Old 09-20-2012, 04:23 PM   #31
Dunenutt
Newbee
Dunenutt's Avatar
I have the Undercover covers, and the hood hits on the ends by the hood bumpers. It is not a huge deal for me, but some of you may be interested to know.
Hard to see, but this pic shows the scuff marks. they should have made the back more verticle.
Dunenutt is offline   Reply With Quote
Old 05-27-2015, 06:51 PM   #32
70blackfish
WOW>>>>why no pictures?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
