09-21-2012, 05:28 PM | #26 |
Re: Parting 63 Chevy 1/2 Ton 6 Cylinder
Anything that big and heavy will run from $40 to $50 via Fed X.
09-21-2012, 07:05 PM | #27 |
Artist
Sending money tomorrow for steering column and shifter arm. Thanks for the pm!!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
09-21-2012, 07:15 PM | #28 |
Steering column and shift arm sold to Malibukasey. Thanks
09-21-2012, 08:50 PM | #29 |
Did you sell the shifter arm I asked about. I didn't get a chance to respond.
09-21-2012, 09:09 PM | #30 |
Yes, I sold it as I did not hear back from you . I should have another as I am parting several of these trucks. Thanks
09-29-2012, 09:45 AM | #31 |
do you still have the thermostat housing mainly the bottom? if so shipping to 84015 clearfield,UT and how much for the housing?
thx
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
09-29-2012, 12:28 PM | #32 |
I think I had $15 on the housing with $6 on shipping.Thanks
09-29-2012, 02:41 PM | #33 |
i'll take it
send me a pm and let me know how you would like your funds and where to send it thx
10-03-2012, 01:19 PM | #34 |
Any pics of the transmission cover? And do you have the gas pedal part that bolts to the firewall? Thanks.
Posted via Mobile Device |
10-03-2012, 09:58 PM | #35 |
I pulled this trans cover and it has pinholes so I do not consider it usable . I do have another one that is in good condition but has a hole for an emergency brake. Price would be the same. The footpedal linkage would be $20 . Thanks
10-04-2012, 07:11 AM | #36 |
Hollister, CA.
Is the cab still around ?
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-04-2012, 08:50 AM | #37 |
Cab is still around . We are crushing so probably not for long. What do you need. Thanks
10-04-2012, 04:04 PM | #38 |
would the high hump cover with firewall piece fit a 64 if so how much shipping to 90220 thanks
10-04-2012, 04:29 PM | #39 |
Yes , should fit I will double check. Shipping would run about $25 for both pieces. The trans cover is good. I would have to remove and check condition of firewallpiece. I usually drill out the spot welds if solid. Thanks
10-04-2012, 04:31 PM | #40 |
Thermostat housing sold to 61 Superman. Tracking # sent pm. Thanks
10-04-2012, 04:33 PM | #41 |
yeah if ya can check it plz. How long do ya think it would take to get to C.A ? Truck is getting shipped out soon?
10-04-2012, 04:39 PM | #42 |
It takes about 5 days from here (Nebraska) to California. Price for the firewall piece would be $60 , price for trans cover would be $50 plus $25 shipping.
10-04-2012, 04:42 PM | #43 |
ok well as soon as ya check the the condition of the firewall piece let me know. is it already removed?
10-04-2012, 05:05 PM | #44 |
No , our day is almost over here and would be tommorrow morning . I can remove it then. Thanks
10-04-2012, 05:07 PM | #45 |
sweet sounds good , can ya take some photo's of it when ya pull it out plz.
Im currently traveling Canada and USA so understand its prob getting to dark out. Talk soon |
10-05-2012, 05:20 PM | #46 |
How did ya go?
10-05-2012, 06:19 PM | #47 | |
Hollister, CA.
if it makes it easier you can just cut the entire firewall with a sawzall underneath the entire dash .... Posted via Mobile Device
10-05-2012, 08:58 PM | #48 |
I will take a look but changes of rust free will be slim as we have humiditiy on this end of the state. If it looks promising I will let you know. The problem I am having is above the windshield. Due to age and humidity they are rusting from the inside out. Thanks for the inquiry.
10-05-2012, 09:00 PM | #49 |
Anything on the firewall piece ? ?
10-05-2012, 09:05 PM | #50 |
Here is what I have . I drilled the spot welds out on the firewall high hump piece. Down near the foofeet they used a lot of spot welds so kind made it a job to get out. The man on the line that day must have been working overtime . We are are a fire warning area and I could not use my torch to cut around it. I bead blasted the lower area an there are two pitted rust holes. Small but there. It could still be used but just wanted to show the detail .
The trans cover looks fine. Thanks |
