Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-04-2012, 11:55 AM   #26
Todd68Chevy
Todd68Chevy's Avatar
Re: 1961 ? GMC 4000 Parts
Originally Posted by Low61projekt View Post
Hey. Whats the condition on the stainless of those vent windows?? Pics of those possibly.. I may be interested in the driver side as mine is rotted away. If you can do a deal on the set I may just do that. Thanks.
I can get pictures tonight. Thanks
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 10-04-2012, 02:08 PM   #27
Low61projekt
Ok great! Thanks much!
Low61projekt is offline   Reply With Quote
Old 10-04-2012, 09:10 PM   #28
Todd68Chevy
These are not stainless, they are painted metal and do not look like they are in good condition either. The glass is poor and there are spots that are rusty. I am not sure if they would be worth taking them out. Do you know how hard they are to get out of the door? The shipping is usually higher than normal also because of the size if the window run channel is attached like the 67-72 trucks are. If you are interested in one or both for $25.00 each plus shipping then I will get them out of the doors and try to get better pictures. Here are pictures of the left one. Let me know. Thanks
Old 10-04-2012, 09:15 PM   #29
Todd68Chevy
First 3 pictures are of the right side one and the last 2 are of the left one. Thanks
Old 10-04-2012, 09:54 PM   #30
Low61projekt
Okay. Wasnt sure what condition these were in since the other pics were farther away but im gunna have to pass on this then.. Thanks for your time and input anyway. Much appeciated.
Old 10-04-2012, 10:50 PM   #31
Todd68Chevy
No problem, Glad you asked. Never know if you do not ask.
Old 10-07-2012, 05:23 AM   #32
63_Rouss_Fire_Co_GMC
Is the driver door fixable? Mine was hit by a tree at the mirror and pushed the tip of door in and bottom at handle. I would be interested in the door if not too much. Winchester, Va, 22602. Thanks, Jeremy
63_Rouss_Fire_Co_GMC is offline   Reply With Quote
Old 10-07-2012, 10:01 PM   #33
Todd68Chevy
The door is very rusty and is rusted out along the bottom. I do not think it would even be worth the shipping cost. Sorry
Old 10-11-2012, 01:56 AM   #34
rcbildr
rcbildr's Avatar
How is the wire harness going to the coil?
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-11-2012, 06:51 AM   #35
Todd68Chevy
I can check it out tonight after work and will let you know. Thanks
Old 10-11-2012, 09:19 PM   #36
Todd68Chevy
Are you meaning the harness that runs from the coil back into the cab? or the wire from the coil to the dist.? The wire from the coil to the inside looks good on the outside but at the connector on the inside of the cab 2 of the wires have been wired around the connector.
Old 10-11-2012, 10:12 PM   #37
rcbildr
rcbildr's Avatar
Actually, the first pic helps me out with what I need to know. My wiring has been hacked up a little and I was hoping your truck would have a harness that was in better shape. Thanks for taking the pics.
My Projects:
1978 Camaro Z28
Old 10-12-2012, 05:20 PM   #38
Todd68Chevy
If you want more pictures to help fix yours just let me know. Thanks for asking.
Old 10-22-2012, 09:57 PM   #39
rcbildr
rcbildr's Avatar
Are you parting out the engine? If so what size is it. I need a push rod for the 305 V6 in my 60 GMC. Thanks!
My Projects:
1978 Camaro Z28
Old 10-23-2012, 09:13 PM   #40
Todd68Chevy
I am keeping the engine as a display engine so I might be able to sell the internal part but never really thought about it. I will not sell any visable/ external items. How can I tell what size it is?
Old 10-24-2012, 08:18 AM   #41
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Right in front of the right head, should be a small flat area that should have the engine number on it. If it is the original engine, I think it will probably be the 305A.
This is from the 6066 GMC site.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 11-06-2012, 09:58 PM   #42
McCoyAZ
McCoyAZ's Avatar
If the hood latching PIN is longer than 2.5 inches and looks like this one then what would it cost along with shipping to 86409 pleae?
Thanks in advance
McCoyAZ is offline   Reply With Quote
Old 11-06-2012, 10:38 PM   #43
Todd68Chevy
Thanks in advance
Do you only want the pin? Here is the one out of this truck. Total length is 3 5/8" or from the head down it is 2 5/8" The pin does have some pitting. If it will work, $7.50 shipping USPS First Class Mail. Thanks
Old 11-06-2012, 10:41 PM   #44
Todd68Chevy
Thanks in advance
I can get pictures of the bracket that the pin goes into if you want. Maybe the bracket is bent different. Let me know. Thanks
Old 11-06-2012, 10:43 PM   #45
Todd68Chevy
I am sorry, I forgot to get back to you on this. It says 305C. Is that the correct one for what you need?
Old 11-07-2012, 05:24 AM   #46
rcbildr
rcbildr's Avatar
It's ok, I totally forgot about this too...stumbled by looking for mirrors. Anyways, let me double check my engine, I'm pretty sure it's a 305.
My Projects:
1978 Camaro Z28
Old 11-07-2012, 05:29 AM   #47
rcbildr
rcbildr's Avatar
Are the heater controls available?
My Projects:
1978 Camaro Z28
Old 11-07-2012, 07:30 AM   #48
McCoyAZ
McCoyAZ's Avatar
I just need the pin I will take it. Thanks
PM sent.
Old 11-07-2012, 07:50 AM   #49
Todd68Chevy
Let me know and we can go from there.
They are still in the truck and I am not sure how good they are so let me get it removed and inspected. I have a meeting tonight so it will probably be tomorrow night before I can. Thanks
PM sent.
I was meaning $7.50 for the pin including the shipping. I will PM my payment information. Thanks
Old 11-07-2012, 11:52 AM   #50
McCoyAZ
McCoyAZ's Avatar
Money sent via PayPal
thanks
