09-27-2012, 10:33 AM | #26 |
Member
Re: 6x9's in the door - Yes Or No??
If your doors aren't cut I would advise not to cut them. I made some boxes for 6 x 9 to fit under my seat and was able to get some thinner grills so my kick panel speakers would clear the E-brake. I know it's not going to win any sound contest but it really does sound pretty good.
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
09-27-2012, 10:54 AM | #27 | |
Do you by chance have any more installation pictures of this setup? |
09-27-2012, 11:30 AM | #28 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-27-2012, 12:37 PM | #29 | |
English Chevy Owner
http://www.crutchfield.com/p_237XT69...th.html?tp=660
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-27-2012, 12:39 PM | #30 | |
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
09-28-2012, 11:32 AM | #31 | |
Happy to be here
The speakers found in many of the current cars/trucks are not mounted that low, and are usually part of an integrated speaker system. Throwing a set of 6x9's in a hole near your feet is a horrible location.
09-28-2012, 01:04 PM | #32 |
An option:
Bucket is molded fiberglass sandwiched between two foam bowls. Fenders must be off, will cut thru small section of cowl vent, that must be resealed. sealed with seam sealer. There will be carpet kick panel added later. The only way that I could find to clear parking break.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
09-28-2012, 01:04 PM | #33 |
09-28-2012, 06:22 PM | #34 |
LS1Nova71: those doors look so good it makes me want to cut mine! And I don't even have a radio!. Seriously, they look good.
Posted via Mobile Device |
09-28-2012, 06:28 PM | #35 |
I could see those being resold!! You make a combo kick panel with that built in. I'd by some.
09-29-2012, 12:57 AM | #36 | |
BTW: I should have said the buckets are sealed to the kick panel with seam sealer.
09-29-2012, 06:01 AM | #37 |
Left my truck out in the rain one day..(Florida flash flood) and thought "I better go get her or she's gonna get mad at me. So I went out in the lightning to save my project...opened the door and heard something funny. Shook the door back and forth and it seemed heavy and made a sloshing sound. YEP half full of water. Drain holes were plugged with junk,debris,and cigarette butts (I don't smoke). Cleaned out the doors and the drains let it all dry and the speakers still work.
My truck is no show winner but it will pull a stump out and tow a train. She is also kinda loud so the more tunes the better. 4 12"'s in the back and 6x9's in the doors ,4x6's in the cowl vents and 3" behind up high in the corners...All holes are already there so it's cheaper than welding since I also have all the speakers already. SO..no holes no speakers. Got holes-fill them with tunes. Just make sure your gauges work?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-29-2012, 10:41 AM | #38 |
I put 6x9s behind seat and built this little box, So I wouldn't have to cut my doors or my dash.
I'm not as good as I once was, But I'm as good once as I ever was. |
09-29-2012, 11:45 AM | #39 |
If you relocate the gas tank, it opens up a world of space for really important stuff, like speakers and amps!!
6x9s would fit nicely in the rear corners.
