Old 10-13-2012, 04:43 PM   #26
gdavis
gdavis's Avatar
Re: 1968
Today was a good day. I primed and painted the rest of the parts to the front end. My shocks and springs are going to be gloss Sun yellow, the linkage will be Chevrolet Orange and the upper and lower arms will be gloss Black alone with the steering gear box and the frame. Starting Monday I will start with the frame. I have to scrape and wire wheel and presure wash so I can sand blast the frame. My sand blaster doesn't like built up grease and asfault from the last 40 something years. Also a picture of my boys and friend.
gdavis is offline   Reply With Quote
Old 10-13-2012, 04:47 PM   #27
gdavis
gdavis's Avatar
Re: 1968
more
Old 10-13-2012, 10:23 PM   #28
Bomp
Bomp's Avatar
Re: 1968
Nice job!!!!!!
Bomp is offline   Reply With Quote
Old 10-13-2012, 10:45 PM   #29
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by longbed67 View Post
Looks like a good start! Whats your final plans for the truck?
Going to paint it burnt orange metlic on top and black metlic on bottom. 350 4 bolt engine and stock transmission 2 speed for now. brakes are drum for now and disk later. I want to get the hard stuff done first. and drive it around and see what i need or want to do next.
Old 10-14-2012, 01:35 AM   #30
67c10rustbuket
67c10rustbuket's Avatar
Re: 1968
Originally Posted by gdavis View Post
the sand blaster is a 10 gallon and after I fixed it. When they built it one of the valve's were stopped up with a piece of metal. they did not finish drilling it all the way thru.sorry about the bright light shinning thru the door.My air compresser 11.50 CFM at 90. The hand held blaster did all the small parts.
Gdavis frm Florida
Thanks for the info, I had a larger pot blaster that my compressor could not keep up with and now just have a crappy siphon feed hand held that sucks. The speed blaster seems to have a lot of great reviews I may have to get one of those. I am running a 33 gallon craftsman compressor so I cant really expect to run a large pot blaster and I only need to blast small parts anyway. Your project is coming along very nice, keep up the great work!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-14-2012, 10:39 PM   #31
gdavis
gdavis's Avatar
Re: 1968
Today, I just cleaned up the shop. Aranged some more parts. I will be cleaning them up tomorrow.
ash tray, bottom and top hinges,motor mount brackets, door latches,ETC.
hope to have them all sanded and primed tomorrow
als here are a few pic that I took yesterday and my helpers. I think they just want to do something.
Old 10-15-2012, 09:02 PM   #32
gdavis
gdavis's Avatar
Re: 1968
Today I wired whelied about half of my frame. My sand blaster would not cut thru the built up grease and road tar or asfault. Tomorrow I will do the inside of the frame. It takes a different wire wheel that the out side. Another trip to my hardware store called Home depot. Here is my Home made rotisserie I built for my truck frame.
First, I got 2 6x6x10' presure treated post. Drilled one 1 inch hole in each post. Mounted a 2x4x4' on each end of my frame. Drilled 1 inch holes to match the post and two pieces of 3/4 pvc 6' long that I drove into the post. Then I got two bolts 12" long by 5/8 and two nuts and the frame turns free. It can rotate 360 without any trouble. Now I can do all my work standing or sitting in a chair. No crawing under and over the frame. It took me abl out 2 hr and the rest is History.
Old 10-15-2012, 09:14 PM   #33
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by MJs69CST View Post
Your parts are cleaning up nicely.
thanks for the support. I work hard on all the parts. nothing but time.
Old 10-15-2012, 09:15 PM   #34
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Bomp View Post
Nice job!!!!!!
thanks
Old 10-15-2012, 09:54 PM   #35
Bomp
Bomp's Avatar
Re: 1968
That right there is THINKING ahead!
I like it.
Old 10-15-2012, 10:53 PM   #36
longbed67
longbed67's Avatar
Re: 1968
How do you like that speed blaster? I am thinking about getting one for small jobs so I dont have to crack out the big dog!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-16-2012, 10:40 PM   #37
gdavis
gdavis's Avatar
Re: 1968
Today, I did a ton of work on my truck. I sand blasend primed the truck frame and trailoring arms. I see now why I put it off for so long. It was back breaking job. But someone had to do it.
Old 10-16-2012, 10:41 PM   #38
gdavis
gdavis's Avatar
Re: 1968
one m picture of the trailoring arms.
Old 10-16-2012, 10:43 PM   #39
gdavis
gdavis's Avatar
Re: 1968
It works great, But it will only blast fine sand. Medium sand clogs it up.
Old 10-17-2012, 06:38 AM   #40
longbed67
longbed67's Avatar
Re: 1968
Very Nice! That feeling of finally finishing the sandblasting and stepping back and seeing that clean frame is very rewarding!
Adam
(608) 214-8706
Old 10-17-2012, 08:59 PM   #41
gdavis
gdavis's Avatar
Re: 1968
yea , it is. several times a day I go by and say Job # 68341 done
Old 10-17-2012, 09:12 PM   #42
gdavis
gdavis's Avatar
Re: 1968
some more pictures of the work i did toda
Old 10-17-2012, 09:15 PM   #43
gdavis
gdavis's Avatar
Re: 1968
tomorrow i will clean up the transmission.
Old 10-17-2012, 09:39 PM   #44
Bomp
Bomp's Avatar
Re: 1968
Nice and clean parts look so nice. What are you using to clean the tranny?
Old 10-18-2012, 12:52 AM   #45
gdavis
gdavis's Avatar
Re: 1968
I like it.
Thanks and happy building.
Old 10-18-2012, 12:55 AM   #46
gdavis
gdavis's Avatar
Re: 1968
wire wheel and elbo grease. Dawn dish soap. and then I will sand blast. prime and paint
Old 10-18-2012, 12:56 AM   #47
nuke1
nuke1's Avatar
Re: 1968
That is one great idea you had there with the frame turny thing a miggy!!! lol. That cuts down on so much work right there and you can easily do it. Great job so far. Liking how everything is turning out.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-18-2012, 09:04 PM   #48
gdavis
gdavis's Avatar
Re: 1968
I took my truck frame off the rotisserie today. Mounted my front end minus the ball joints. ( ordered) also aranged the rear end under the frame wainting for bushings.
Old 10-18-2012, 09:05 PM   #49
gdavis
gdavis's Avatar
Re: 1968
pictures
Old 10-18-2012, 09:49 PM   #50
Bomp
Bomp's Avatar
Re: 1968
Seeing all this assembly work makes me wish I hadn't gone so nutz on mine.
