Old 10-02-2012, 11:03 PM   #26
ivorton74
ivorton74's Avatar
Re: Nissan RB26DETT in a square body
http://youtu.be/iMYrnDcUkXs
this is a vid of a 2jz c10 makin 700 hp
ivorton74 is offline   Reply With Quote
Old 10-02-2012, 11:03 PM   #27
kwin
kwin's Avatar
Seems like I saw one of these stuffed in to an early International p/u even had custom valve covers with the international script milled into it.
It was cool.
Horsepower is cool
Going fast is cool
Go for it!
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 10-02-2012, 11:05 PM   #28
king-918
king-918's Avatar
Originally Posted by tylervalo View Post
Then they become sequential turbos instead of twin.
no twin is referring to two turbos not the size. For that matter you should say parallel or sequential setups
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 10-02-2012, 11:19 PM   #29
tylervalo
It threw me off how you used it, we always referred to them as sequential when they were different size, twin when the same. Regional dialect I guess.
tylervalo is offline   Reply With Quote
Old 10-03-2012, 02:57 AM   #30
andrewmp6
I use to have a rb25det in a 240sx and if i had to do it over i would have done a ls1 swap,The engine is heavy pricey to buy only parts you can pick up at a parts store is a coil packs the vg30 used the same ones anything else is order and wait.If you really want to do it try talking to mckinneymotorsports.com i think they use to make a adapter to run a gm auto trans.
andrewmp6 is offline   Reply With Quote
Old 10-03-2012, 05:57 PM   #31
Pro/StreetPete
Pro/StreetPete's Avatar
Guess I'm just old fashion...keep it ..
"You're only as good as the people you keep around you"
Pro/StreetPete is offline   Reply With Quote
Old 10-03-2012, 06:52 PM   #32
Pyrotechnic
Pyrotechnic's Avatar
Now why would you wanna go with a 2.6L with no local parts availability, when GM has an I6 that displaces 4.2L....
http://en.wikipedia.org/wiki/GM_Atlas_engine
http://www.carcraft.com/techarticles...ec_inline_six/
And yes, that was a 9 second run in a station wagon
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 10-03-2012, 07:13 PM   #33
king-918
king-918's Avatar
Let's be honest 4.2 is a fail next to the rb series. Also modified parts for any motor outside the 350 is order and wait. Dollars to donuts bet on the RB, think about how much better these engines flow to make 500hp on 2.6/2.5L
<----Christopher
Oklahoma
Old 10-03-2012, 09:47 PM   #34
Pyrotechnic
How is a 9 second pass a failure?
Read the car craft article about the Firebird. That guy makes 470HP and 450TQ on just 8 pounds of boost on a stock long block.
These engines we're installed every soccer mom's Trailblazer for quite a few years. They are piles of these engines around with low miles, and they can be had cheap.
The 4.2L with it's larger displacement will make more torque and be much more streetable, especially in a 4000+ pound truck.
Second, the small block chevy 350 is not the only GM engine with aftermarket support. You're forgetting the LS engines and the big blocks. Very easy to get parts for these. Also, if you've got the coin you can even get into NASCAR parts and engines. Even the discontinued Buick, Olds, and Pontiac stuff is easy to do and they haven't made these motors for a long time now.
I won't go so far as to say the RB series is a failure, it's definitely not. Remember in Tokyo Drift, they did the swap because it made sense and it's what they had. They probably couldn't have laid their hands on a Ford V8 if their lives depended on it, at least not in time to race with DK anyway.
And here's a Tokyo Drift kind of story with a twist...
http://www.supramania.com/forums/sho...s-4.2l-I6-Swap
Old 10-03-2012, 10:50 PM   #35
rwhit57
rwhit57's Avatar
Japanese motor in a Chevrolet truck, If I had a rubber hose I'd..................
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 10-03-2012, 11:50 PM   #36
king-918
king-918's Avatar
A rb is roughly half the displacement. It will be streetable depends on the set-up. I would push a stock rb past 500hp but would fear doing that to a 4.2L. But I do like a 4.2 because it a underdog.
I understand the rb is way past different so it should be done. I want to put a Toyota 5.7 in my 76 vette but funds and support are too limited right now
<----Christopher
Oklahoma
Old 10-04-2012, 12:16 AM   #37
meter swinger
meter swinger's Avatar
I think a 6.0 makes more sense. But I like wierd stuff so why not? You can always pull it out and stuff it in a F@£D.
meter swinger is offline   Reply With Quote
Old 10-04-2012, 12:19 AM   #38
clinebarger
At what RPM does a 2.6L engine make 500hp?? More importantly where is the torque band? What kind of HP/TQ does this small I6 make from idle to 3000rpm?
clinebarger is offline   Reply With Quote
Old 10-04-2012, 02:16 AM   #39
king-918
king-918's Avatar
Originally Posted by clinebarger View Post
At what RPM does a 2.6L engine make 500HP?? More importantly where is the torque band? What kind of HP/TQ does this small I6 make from idle to 3000rpm?
I can't tell you right off top I will find out tomorrow, but torque was in the fours. the power cure is mid to high. but remember that's his setup you can change your power band in your setup and tune.
<----Christopher
Oklahoma
Old 10-04-2012, 02:33 AM   #40
Mr. 250r
Mr. 250r's Avatar
There's a guy over on the thirdgen camaro forums putting a duramax in a thirdgen so a skyline motor in a square body seems 'okay' as long as its not a ford motor... lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-04-2012, 03:25 AM   #41
andrewmp6
A rb26dett fully dressed weights 573lbs a ls1 is 430lbs fully dressed A gm small block iron block heads and intake is about 575lbs.Any small block from the big 3 gm ford mopar will have speed parts over the counter at a speed shop.Dollar pre hp you can't beat a gm small block,I understand you want to be different why not use a diesel or even the 3800 stage 2 with the blower of a gtp it will change over to rwd.
Old 10-04-2012, 04:45 AM   #42
V3500KING
V3500KING's Avatar
If you want to be different, just drop in a zz 502 with twin turbos. With that setup you could mess with Lamborghini's and Ferrari's in a square body.
V3500KING is offline   Reply With Quote
Old 10-04-2012, 04:57 AM   #43
mongoose
mongoose's Avatar
uh... no not really.. lol
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-04-2012, 09:19 AM   #44
V3500KING
V3500KING's Avatar
You don't think a truck weighing 4000 lbs with a 1000 hp 1600 lbs of torque couldn't mess with a car weighing 3500 lbs and 600 hp?
Old 10-04-2012, 10:57 AM   #45
Pyrotechnic
Exactly. Horsepower sells cars, torque wins races. That 2.6L may make a peak 500 HP, but when you look curves from the dyno graph you will quickly see that what you gained on top was lost on bottom.
I hate to bring up the too often told story of the 800HP Supra that impressed people with it's dyno sheets but couldn't beat a stock mustang at the track, but it's true. These motor are impressive for what they are, but there's only so much streetable power you can get out of a given displacement on pump gas, no matter what name is on the valve cover.
Old 10-04-2012, 10:58 AM   #46
C-10 simplex
There already are Japanese motors in chevy trucks----Duramax?
C-10 simplex is offline   Reply With Quote
Old 10-04-2012, 11:27 AM   #47
Pyrotechnic
[QUOTE=king-918;5627955]A rb is roughly half the displacement. It will be streetable depends on the set-up. I would push a stock rb past 500hp but would fear doing that to a 4.2L. But I do like a 4.2 because it a underdog.
Posted via Mobile Device[/QUOTE
The 4.2L is only 1.6L larger than 2.6L...a whole 1L off is quite a rough margin from half.
I think it's pretty impressive that the Vortec 4200 can be taken to 500HP on stock cast pistons. It's always been an NA motor, never boosted. The RB turbo engines were turbo motors from day one and have as much iron as a small block 350 so I'm not surprised that it holds together at higher numbers.
I realize the Vortec 4200 has only soccer mom lineage behind it rather than super car lineage, but they really are a diamond in the rough with a ton of potential and that's what makes them cheap. Ultimately however, most people go LS 5.3/6.0/6.2 for big boosted power, but that's a whole different can of worms.
Old 10-04-2012, 11:36 AM   #48
king-918
king-918's Avatar
Okay first it's a rb not a 2jz. People with supras like to dyno race. This 2.5 is making usable power I've driven the several times plus it a stick no stall converter on 91. And that mustang had better be a GT500 or better. It does not matter if you make torque at idle you will never be there in a race.
Bottom line rb's are hot for a reason, the outflow most of the engines out there.
You should do an RB if you like it will be kick @ss and make decent power with minor mods i.e. 450+HP
<----Christopher
Oklahoma
Old 10-04-2012, 03:15 PM   #49
thepenguin99
On a dollar per HP basis I don't think you can beat a 6.0/4l80e combo for a 400-500hp build. If you just want to be different...by all means RB it. They are great engines. I would love to have one in my 240z.
thepenguin99 is offline   Reply With Quote
Old 10-04-2012, 07:07 PM   #50
mongoose
mongoose's Avatar
on the street? no.
