Old 10-10-2012, 10:06 PM   #26
Racer2172
Re: No oil pressure, new build
Make sure the distributor is fully seated driving the pump
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 10-10-2012, 10:33 PM   #27
bowtiemanchevyman
bowtiemanchevyman's Avatar
its a new motor right, when u got it back was it put together or did u put it together? one of the hole on the crank or the block side might be filled with stuff when they rebuilt the block. u might want to pull it apart and check all you oil hole befor u burn up a motor
bowtiemanchevyman is offline   Reply With Quote
Old 10-10-2012, 10:34 PM   #28
fast72beeper
Umm...OK?
fast72beeper is offline   Reply With Quote
Old 10-10-2012, 10:35 PM   #29
fast72beeper
Guess you didnt read my original post....
Old 10-10-2012, 10:42 PM   #30
bowtiemanchevyman
It doesn’t say if u built it or they built. You might need to pull it apart and clean all the galleys in the block. If it start with oil pressure then dropped something moved in the oil galleys and is blocking oil from moving around.
Old 10-11-2012, 12:16 AM   #31
fast72beeper
Galleys are clean...motor is torn apart...
Old 10-11-2012, 12:19 AM   #32
king-918
king-918's Avatar
This may or may not help. I did not finish reading
http://www.chevytalk.org/fusionbb/sh...hp?tid/192284/
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 10-11-2012, 12:20 AM   #33
INSIDIOUS '86
INSIDIOUS '86's Avatar
What's your journal and mains sizes on the crank? Then measure the main bearings
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-11-2012, 09:19 AM   #34
fast72beeper
All of the main and rod journals, main journals in block, rods themselves, etc measure fine. They have been measured empty and with bearings torqued. The issue is not bearing clearance.
Old 10-11-2012, 08:49 PM   #35
kalbert
Have you tested the oiling system? Like with the motor on the stand sans valve covers and intake and stuff then run the oil pump with a drill and an old distributor and see what happens? I'd imagine you'll see the same pressure problem this way, but with visibility into whats going on inside. I'm thinking you'll see oil gushing from somewhere right away. Would also give you easy access to move the pressure gauge around to different ports and take readings in different places.
EDIT: Either you'll see oil gushing from somewhere or you'll confirm that there is something wrong with the pump, pickup, filter adapter, or filter.
kalbert is offline   Reply With Quote
Old 10-12-2012, 06:52 AM   #36
mrhino
what about your oil galley plugs are they all in? and sealed including the "forgotten ones"
mrhino is offline   Reply With Quote
Old 10-12-2012, 07:32 AM   #37
INSIDIOUS '86
Well if it builds pressure fine then at idle when engine is under load and warm there is a leak. Check the rear most cam bearing. Is it slotted or solid? Same with the cam.
Old 10-13-2012, 12:40 AM   #38
85Bowtie
85Bowtie's Avatar
When you spin the engine over, do you see oil coming up through the oil line?
I've had this problem before by being a cheap ass and re-using the stock pickup that I THOUGHT I got all of the debris out of. As it turns out, a few tiny (and I mean tiny) pieces of nylon had got sucked from the pickup into the oil pump, hanging up my pressure relief valve. I didn't catch this at first, since the pieces were so small. It did it a few times, sometimes it would go to 0 then shoot back up. I eventually had to pull the engine and replace all of the bearings and do it right the 2nd time....all because of a $25.00 part.
It would seem to me if it was a clearance issue you wouldn't be experiencing this problem more consistently, not building up pressure than going to zero.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 10-13-2012, 01:50 AM   #39
fast72beeper
Pickup is new.
Old 10-13-2012, 01:52 AM   #40
fast72beeper
Took the whole thing to the machine shop that machined the block.
He is going to look it over and let me know on Monday.
Im really afraid the oil galley(s) is/are cracked. Hope Im wrong, but after talking with a few more guys, it seems like the only logical answer.
Old 10-13-2012, 02:01 AM   #41
mongoose
mongoose's Avatar
is it just losing that much oil through the cracks it can't build pressure at idle? I'd think that would be a pretty big crack lol
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-13-2012, 05:55 PM   #42
85Bowtie
85Bowtie's Avatar
Pickup is new.
My post was directed more to sucking trash into the oil pump. If everything in this motor is new and freshy rebuilt, wouldn't cracks in the oil galley have been discovered when the block was magnafluxed?
Old 10-13-2012, 09:34 PM   #43
fast72beeper
Ive spoke with 4 different machinists so far. They all say that cracks in the oil galley(s) dont usually show themselves with standard magnafluxing. They say wet magnafluxing will show the cracks. Very few shops do wet magging, at least in my area.
Old 10-14-2012, 04:46 AM   #44
bk2life
keep us posted on the outcome..
i had a factory oil cooler take out 2 motors before relizing it was the culprit and tossin it..
bk2life is offline   Reply With Quote
Old 10-15-2012, 10:55 AM   #45
fleetweld47
I had the same issue years ago on a 327 , turns out the the block was cracked due to the cam bearings being installed incorrectly at the machine shop .
fleetweld47 is offline   Reply With Quote
Old 01-06-2013, 12:05 AM   #46
fast72beeper
Well...motor is back together and running. The only thing that was changed is the oil pump. We did put new bearings in the motor, but same size. The old bearings were not beat up, just a little scuffed. Motor now holds 22 in gear and 30 in N. So, who knows...Machinist told me that he has seen it lately that he puts a motor on the dyno, oil pressure is low. Only change the pump and pressure will be OK.
Old 01-06-2013, 12:28 AM   #47
PAWS 72
PAWS 72's Avatar
Being a stupid ... rite now but do you think it could be some of this china stuff that is soppsed to be good, is crap?
Which I'm starting to think all of this stuff we're putting on we have to do it twice to get a good part.
PAWS 72 is offline   Reply With Quote
