10-15-2012, 03:12 AM | #26 | |
Re: Driver and passenger windows hard to crank up and down
Posted via Mobile Device |
10-15-2012, 03:45 AM | #27 |
Its late and I have to go check my critters but this will give you a big headstart.
The tool is for pulling the window crank and the inside door handle. If you look down under the lever arm to the shaft it is mounted on, you will see the ears of the retaining clip. Using the tool slide it down over the top of the trim ring and engage the clip ears, push back gently. You will probably push the clip off as there is developed feel involved. Chasing down the clips will be an incentive to develope this feel. It will take about three or four doors to do that. :-) Then it is a matter of pulling screws and the panel. Remember to mark or document the handles closed position or you get even more practice chasing clips.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-15-2012, 09:46 AM | #28 | |
10-15-2012, 10:32 AM | #29 |
20' Daredevil (Ret)
How true!
09-07-2018, 11:20 AM | #30 |
Hey guys, I have the same problem. My Blazer windows are really hard to roll up. I have just replaced all the hardware, scissors, felt on both sides, new handles, and they roll up ok about half way up then get tighter and then the last 1/4 of the way up, it takes 2 hands to roll up. I have lubed everything good and can't figure it out. Has anyone else had this kind of problem?
09-07-2018, 03:27 PM | #31 |
Look at the felt channel and see if it starts pinching the window towards the top.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
