Old 05-02-2013, 02:07 PM   #26
Squareforceone
Squareforceone's Avatar
Re: 78 K10 Build "Hank"
Where did you buy your patch panel for the rear lower bedside from it looks like yours fits. I bought mine from classic parts and it doesn't fit right inside the fender well. The lip for the wheel arch sticks out farther the original lip i have a few pictures to show what i mean.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 05-02-2013, 08:01 PM   #27
Jedipartsguy
Jedipartsguy's Avatar
I got mine from my parts truck. I cut a few more inches than I needed and trimmed it to fit. You just need to trim yours around that lip.
"Hank" 78 k10 6" lift 33's, good wrench 350 sm465 np205
Jedipartsguy is offline   Reply With Quote
Old 05-02-2013, 08:14 PM   #28
Squareforceone
why can't some where just sell me a patch that fits... grr i can't just trim it i would either have to completely grind the edge or cut it off trim it and re weld that bit on.
Old 05-02-2013, 08:21 PM   #29
Jedipartsguy
You can trim it. Just take measurements from the other side if you are worried. Just draw a line and cut it flush with the existing lip. Or cut the flat part short and blend the area where it starts to curve. You are cutting the old stuff out right?
Old 05-03-2013, 02:01 PM   #30
Squareforceone
cutting the old stuff out? if you mean rust then yes the bad has already been cut out. I just don't think i could get the curve right.. I wish i could find a company that makes a better patch
Old 05-03-2013, 05:49 PM   #31
Jedipartsguy
I wish you were local so I could help you out.
