10-23-2012, 09:24 AM | #26 |
68 C 10
Re: Accuair - Worth the cost?
Keith how much you think systems like that would cost a guy ballpark prices are fine Just sayin haha
Kevin
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
10-23-2012, 10:07 AM | #27 | |
67-72 parts collector,…
You might be able to find it cheaper. That was from Accuair's website. Add another compressor and it will be more. Of course the e-level is even higher. But after seeing and driving n2billet's truck, Hazel,... I think it's well worth the cost. Of course,... the design of all of the Porterbuilt suspension, plays a BIG roll in the way it drives and handles.
11-23-2012, 06:55 AM | #28 |
Thanks for such an informative post, and all the relevant links provided with it. It surely will be helpful for a novice as well as a pro.
11-24-2012, 12:32 AM | #29 |
I've run the big red valves for years. Only problem I've had was I kinked a wire and there was a break in it right buy the valve itself. Bought a replacement block and good to go.
Posted via Mobile Device |
12-06-2012, 08:04 AM | #30 |
Hey thanks for such a nice and informative post along with all those links providing quality precise information about how to go about a job.
12-06-2012, 11:16 AM | #31 |
I've never used Ridetech or any other form of air management, but I can testify to the quality of Accuair. Very well-designed, its evident that the whole company is basically devoted to the one system. Also, customer service is very accessible and helpful!
'71 GMC pickup; "Ashley," |
12-07-2012, 10:54 AM | #32 |
I'm just glad to be here!
http://www.ebay.com/itm/Accuair-Swit...-/220701698153
This is just for the Controller and VU4 manifold, Just over $800. No compressor, hose, fittings, bags, etc....
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-07-2012, 12:28 PM | #33 |
Tot Roddin'
After comparing the two systems (RideTech/Accuair) it appears that for the money... Accuair has it nailed. For an e3 setup running a 3 gal tank and one compressor the RideTech kit runs $1500 where as a similar setup with Accuair (w/ 5 gal tank) comes in at $1275.
Accuair (1) SwitchSpeedTM Controller (Electroless Nickel or Black Anodized Finish) (1) Viair Mechanical Pressure Switch (145psi) (1) VU4 4-Corner Valve Unit (1 or 2) Viair 400C Compressor Kit(s) (1) 5-Gallon Anodized Aluminum Air Tank (1) Serviceable Aluminum Air Filter (1) 3/8" D.O.T. Approved Plumbing Kit
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-07-2012, 12:43 PM | #34 | |
Man of Mini-Talents
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
12-07-2012, 02:32 PM | #35 |
Also be aware when comparing that this kit:
http://www.accuairsuspension.com/pro...evel_tpad.html Does not include the VU4 valve block.
12-10-2012, 04:00 PM | #36 | |
Tot Roddin'
I have heard that people have experienced issues with the 3-presets on the e3 setup if you're not running a leveling system. Maybe this is old information but something that I've heard. If I recall correctly the Accuair setup w/o sensors works when using the 3-presets.
12-10-2012, 05:36 PM | #37 |
A lot of this has to do with >who< might be driving your truck. A self leveling with presets system gives me the peace of mind to toss the keys to the wife or whoever else wants to borrow the truck.
-- 1968 fleetside - nolimit wide ride front and rear + ridetech |
