10-19-2012, 06:17 PM | #26 |
No No
one side note I tested plugs a few years ago I have a old vixen plug tester uses air and electricity. you increase the air pressure and watch the spark. very simple tool but auto lite plugs just standard copper kept a good clean spark longer then any other plug. now I also tested e3 plugs. the spark pattern was amazing just like it looks on the commercials but it could not hang with the autolite. I tested them in my Subaru mpfi 1.8 no change in fuel economy or seat of the pants feel. but on the other side I used one in my lawn mower and it actually uses less gas to cut the same amount of grass almost half a tank less.. have no clue how or why but that's an insane improvement. I tried them in my shovel head and it just fowled them out. I suggest find a plug that your engine likes and stick with it
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
10-19-2012, 08:55 PM | #27 |
Re: Crazy 454 Spark Plug SHOOTOUT!
I have tried many different brands. I now buy only Champion platinum on sale and get them for free. I have 36 of these plugs in the shed - all free.
I think this spark plug mumbo jumbo is all hype. I have never seen a scientific study on the performance of all types of plugs in different driving conditions. I have owned 2 trucks with 454s (73 and current 83 C20s). 454 engine and heavy 3/4 ton pickup mean bad gas mileage no matter what plug you use. Performance is fine with the Champion platinum plugs - just get some for free and try them out. |
10-19-2012, 09:28 PM | #28 |
Run ac delco and add a high output coil and a msd 6 or 6a. It will burn anything. Alot less fouling out.
10-20-2012, 12:07 AM | #29 |
The cut ground strap and a plug indexing kit is about as much as you can do. I have a brute force hei coil and a msd 6al with the best plug wires you can possibly buy (taylor thundervolt) and autolite coppers.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-04-2012, 08:12 PM | #30 |
Plug indexing kit? Never heard of such a thing!
12-04-2012, 08:48 PM | #31 |
maybe he is refering to the plug washer with different thicknesses so you can index the plug
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
12-04-2012, 09:06 PM | #32 |
12-04-2012, 09:25 PM | #33 |
i have thought about trying the ground strap thing with my dirt bike but im afraid it might melt a hole in the piston. its a 2 stroke so it will fire every rotation. and having the piss reved out of it might not help.
12-04-2012, 09:49 PM | #34 | |
12-20-2012, 10:27 PM | #35 |
I ground down the straps on my new plugs and it runs better but couldn't tell if it was because of the modification or because they were new plugs, lol!
11-17-2013, 06:43 PM | #36 |
I bought a set of ACDelco Professional Platinum Spark Plugs for $47.92 hoping for better performance, well I can't tell the difference from my cheap $18 plugs! Anyone else waste their money on expensive plugs with no increase in performance?
11-17-2013, 07:30 PM | #37 |
Master Hater
no differance , long as they spark, don't get suckerd by marking scams.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
11-18-2013, 10:57 AM | #38 |
11-18-2013, 10:59 AM | #39 |
11-18-2013, 11:09 AM | #40 |
Suburban Hick
I've always ran the cheapest ones I could get. May not get 100K out of them but you didn't 40 years ago either. AC Delco plugs are made by champion now and I believe autolite is as well.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
11-18-2013, 11:15 AM | #41 |
Not sure how all these rumors get started. Autolite IS NOT manufactured by Champion,and not sure AC plugs are either.Maybe you could post a link to back this up,as I have not heard that,but hard to say anymore as so much is being spun off.
11-18-2013, 12:57 PM | #42 |
Its funny because the newer trucks require platinum plugs for lower maintenance, yet if you don't pull them and put a little copper never-sieze on the threads, you'll never get them out of an aluminum head.
I've tried quite a few of the hyped plugs and found no difference in any of them. Here in the rust belt its just good sense to change or pull them anually so you don't have issues, so the $15-20 set is perfect.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
11-19-2013, 07:21 AM | #43 |
Old Heap Driver
R44T AC Delco and #26 Autolite are both recommended for my applications.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
11-19-2013, 07:33 AM | #44 |
11-19-2013, 07:45 AM | #45 |
Old Heap Driver
I'm not arguing hot cold etc. I'm not getting into a *issing contest over plugs. Again, I've had ZERO issues running 26's in my 3 sbc's and 1 bbc's, all 4 are essentially daily drivers.
11-19-2013, 08:31 AM | #46 | |
I was simply stating an Autolite 26 plug is a Hot plug. |
11-21-2013, 03:23 AM | #47 |
Delco R44T's (I think that's what the book says) in my '85 bone stock 454. I think I got 28,000-30,000 miles out of the last set of plugs, and the truck (TH400/4.10's) could consistently pull 12.25-12.5 MPG @ 60-65 MPH on the highway. MPG's bumped up a little after I bought the new tires and replaced the cap/rotor, but I didn't take it on the interstate much after that so the numbers aren't as solid.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
