12-24-2012, 11:41 PM | #26 |
mini truck racer
Re: NO-E street build
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-25-2012, 10:27 PM | #27 |
mini truck racer
I have been researching how to keep the A/C on the truck and this is what i came up with . Thes two are made by Alan Grove . Gonna have to do some measuring to order the correct one , but this is the ideal . Mounting the compressor where the fuel pump would be . Which is where it is located now . No hose changes except for up from at the condensor . I'll have to move it to make room for the larger aluminum radiator .
12-26-2012, 02:47 PM | #28 |
mini truck racer
Neither of the low mounts will work . The Idle steering arm is in the way of the higher one . I measured off the yellow truck . Also the lower radiator hose coming from the radiator would be up against the clutch of the compressor . The belt was already goning to be close to the hose .
12-27-2012, 10:57 PM | #29 |
mini truck racer
No pics today due to rain , but i dropped it off at the chassis shop for the motor mounts to be welded in and the pinion angle to be set . Preches will be adjusted and plated for strength . They are going to build a shifter stand while they got it also .
12-28-2012, 09:34 PM | #30 |
mini truck racer
In the chassis shop for mounts welded in , pinion angle ,front crossmember relief, shifter stand etc.
Hey , is anybody in here ?
12-29-2012, 12:05 AM | #31 |
60-66 Nut
01-03-2013, 08:04 AM | #32 |
mini truck racer
Got it out of the chassis shop last night . Pretty happy with everything except the shifter stand which i can fix . It was raining and dark last night when i got home so ill get some pics up tonight . Motor going in this weekend for sure .
01-03-2013, 01:08 PM | #33 |
"Where were you in '62?"
Ole' Chevy LUV Trucks..
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-04-2013, 09:21 AM | #34 |
mini truck racer
Well , i got the truck back from the chassis shop . and got it this far last night . The oil pan i bought is a bit longer than the factory truck pan i used on the Yellow truck . It will be ok . Motor and trans are in thought .
01-04-2013, 10:43 PM | #35 |
mini truck racer
Finished up the firewall clean up , header install , carb on , distributer assembled , crossmember modded for larger pan , driveshaft in .
01-09-2013, 10:23 AM | #36 |
mini truck racer
Are these too much ? i kinda thought theywould be cool .
01-21-2013, 11:13 PM | #37 |
mini truck racer
Ran into a snag . Motor mounts were welded in 3/4 " to far forward . This would not allow me to get the water pump and fan installed . Back to the chassis shop for thr mounts to be cut out and moved . Also had a few other things done . Had hooks weled to the frame to strap truck down , panels made for speakers in rear cab corners , battary tray cut out & a set of universal traction bars cut up and welded to the rear shock mounts . Pics to follow .
01-27-2013, 12:31 AM | #38 |
mini truck racer
Got the motor back in . been a busy weekend so far .
01-27-2013, 10:19 AM | #39 |
Nice build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-03-2013, 10:37 AM | #40 |
mini truck racer
Thanks Hart rod , it's getting there .
Got some time to workon this . I dont think im going to have it ready for the season opener , but im trying . This is the material for the interior . I am having the door panels , seat , kick panels redone . I got the cooling system completed yesterday . I bypassed the cable heater block valve , as i have never had one that didnt leak . I added a manual valve for summer when the air is on . Got the Condensor and liquid line filter drier mounted and hooked up . All that is left is the compressor mount and hook ups for A/C . Well enough talk here is the current picks .
02-03-2013, 10:59 AM | #41 |
dazed and confused
That is going to be a cool ride!
members met: redbaron69, billsbowtie,nc67 |
02-11-2013, 10:34 PM | #42 |
mini truck racer
Did a little more on it , but not much . Not going to make the season opener with it . I was planning to have my wife drive it and contend for rookie of the year .
04-02-2013, 10:04 AM | #43 |
mini truck racer
Upolstry off for redo . Door panels , seat and kick panels . Factory tank is being sumped modded and coated . Glass is out for new winsheild gasket and rear window seal . Dash repair in progress for new dash cap . Stereo going in new speaker panels covered and onstalled . Lots of little stuff done . Throttle pedal modified and cable fitted and installed . Choke cable installed ( this will also double as a staging RPM tool with the choke flap removed ) . Reused one of the vapor recovery lines from the tank as vacuum for modulator valve . Moved wires around in harness to make factory relays work for fuel pump and distributor instead of ballast bypass and combo fuel pump/distributor . Truck is getting really close .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 04-02-2013 at 10:11 AM. |
04-11-2013, 10:43 PM | #44 |
mini truck racer
Made heat with this one tonight . Had #6 top dead , but after thst is busted right off . Good running litlle motor .
04-12-2013, 11:40 PM | #45 |
Man, hotrod 80!
Sweet ride and serious progress! Love the visual updates, keep em coming!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
04-13-2013, 06:43 AM | #46 | |
mini truck racer
I have it scheduled for exhaust next wendsday . Finish the driveshaft monday . Glass install tuesday. Upolstry should be finished tuesday also . I got the dash fixed and the rear speakers installed . The carpet and padding will follow the glass install . It has been alot of work .
04-29-2013, 10:34 PM | #47 |
mini truck racer
Got this thing lined out enough to drive it . I will post pics of it completed with the interior , but it has a new owner that wanted it more than me . It truely is a nice truck with a/c and nice stereo . Just to give you an idea what the interior looked like i'll post a pic . Finished pics coming .
05-02-2013, 09:58 AM | #48 |
mini truck racer
05-02-2013, 11:31 AM | #49 |
dazed and confused
Turned out a sweet ride!
