10-29-2012, 09:28 AM | #26 |
Re: Headers and Spark plugs
What headers did you go with?
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
10-29-2012, 09:32 AM | #27 |
I went with some Jegs headers, they bolted right up no issues just a few of the spark plugs were a pain in the ass to get in, but they sound great I love them, just wish my truck loved them too haha
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
10-29-2012, 10:15 AM | #28 |
Did they fit without modification to your exhaust?
10-29-2012, 10:32 AM | #29 |
well it had a very very old stock exhaust on it, so I cut it all off, so as it sits right now it would be just be open headers no pipes or nothing yet, but I'm going to be purchasing and exhaust here shortly once I get it running again, because its actually not good to run your motor open headers unless its very heavily modified. the only issue with mounting up with my exhaust the problem I would of ran into is the outlet is 3" and I think the stock was 2.25" or 2.50" compared to 3" its tiny.
10-30-2012, 11:32 PM | #30 |
Well a small but sad update the truck is still not starting but we replaced all
the spark plugs as we noticed 1 was bent and in the process of taking out the old ones we noticed that 2 of the spark plugs weren't even sparking but covered with fuel, so Saturday going to get the coil looked at and hope that's the issue Posted via Mobile Device
10-30-2012, 11:50 PM | #31 |
ouch....Well hope you get it fixed quickly and cheaply
10-30-2012, 11:53 PM | #32 |
Ooo believe me that's everything I'm wishing for, it's killing me knowing that the truck isn't running
10-31-2012, 12:51 PM | #33 |
With two wet plugs maybe you damaged a couple wires while switching them?
Posted via Mobile Device |
10-31-2012, 12:54 PM | #34 |
thats possible as well I mean i'm trying to think of anything and everything to look at
11-05-2012, 09:32 AM | #35 |
Well I had a buddy come over yesterday to look at the truck, thankfully he has a chevy 350 as well for his project so he brought his distributor cap over to maybe see if mine was bad. Swapped them got everything hooked up nothing still wouldnt turn over, so it seems as if my next option and simple solution will be wires. If that doesn't work, what should I look into next?
11-05-2012, 09:41 AM | #36 |
Did you try the coil yet?
11-05-2012, 09:57 AM | #37 |
yeah we swapped mine for my buddies distributor cap and coil, and it was still the same sorry i didn't state that in there.
11-05-2012, 10:17 AM | #38 |
Huh so it will crank good but no fire?
11-05-2012, 10:18 AM | #39 |
Hows your timing did you move the dist at all?
11-05-2012, 10:22 AM | #40 |
yeah we made sure it was lined up as close as possible the truck will sound like it wants to turn over but wont.
11-05-2012, 10:41 AM | #41 |
Take your timing light hook it up like your gonna time the truck and have someone crank the truck and take the wire from the light that usually goes to the number one plug wire and put on each wire and make sure the light flashes. This will tell you you are getting spark to each plug if no flash something is up with the wire.
11-05-2012, 11:01 AM | #42 |
Okay, I'll have to test it this weekend as mainly my weekends is when I work on the truck, say for example all the wires are fine. What should I look at as a solution next?
11-06-2012, 12:31 AM | #43 |
Well if you have the spark and fuel it should start. Let us know!
11-06-2012, 03:39 AM | #44 |
if the wires are routed wrong you should at least have some back fires coming through the carb or some really creepy back fires out the exhaust.
im guna take a guess and think youve fouled the plugs (you said they were wet) -pull the plugs, dry them off and put them back in. if you have spark, have fuel, there has to be fire. plain and simple. your not getting something, so you have to have something not right. too much fuel flooding it? |
11-06-2012, 09:13 AM | #45 |
I mean honestly I'm willing to believe anything but I don't think I'm flooding it because I only pump the pedal 2 times when it won't start and normally until now it would crank right up and I would let it run for a bit so that it doesn't flood it.
Well thankfully enough I completely forgot about him sort of I have a cousin thats actually a mechanic thats in my family so I'm hoping to have him come check it out on wednesday and if still nothing. I'm going to send it off to a engine shop to get professionally rebuilt and fix any issues that might need to be fixed.
11-06-2012, 10:14 AM | #46 |
If it was a good running engine before no need to rebuild it. You just have something going on you will get it post back let us know.
11-06-2012, 10:29 AM | #47 |
well it was rebuilt by the Dad that I bought the truck from so I dont know if they did a true rebuild kit or just replaced the gaskets and things like that, I mean there's parts in the bed of the truck that were bad and replaced. I know it may be a bit in wasting money but I just would feel more comfortable if I actually had it professionally rebuilt and balanced and everything.
11-06-2012, 11:48 AM | #48 |
I'm sure you will get this one going
11-06-2012, 11:55 AM | #49 |
I'm hoping no doubt, no worries though once it's running or I find out I will be putting a description of what happened. so that other people can possible avoid the issue as well.
11-06-2012, 12:09 PM | #50 |
Haha its gonna be something simple done that a hundred times
