Old 02-12-2013, 02:59 AM   #26
luvbowties
luvbowties's Avatar
Smile Re: El Palomito-My 1964 C10 SWB BBW Fleetside
Steve, I love the new stance and all the upgrades you've managed, and at seemingly good (net) price outlays. That white with alum & chrome trim, bbw, and tinted glass surely flow together nicely. And the work with the 15-year-old makes for priceless memories, from both your perspectives.
I am curious to know what that 'glob' is on the steering shaft about 2.5 inches up from the rag joint. I see the roll pin: if it fastens outer tube on adapter flange to inside original round shaft, it may be stronger to use like a 1/4X20 high-grade bolt--altho' the coupler need not be nearly as strong as we might first think, as not a lot of force/torque is exerted on that connection.
Keep up the good work and keep on enjoying the outcomes.
Sam
luvbowties is offline   Reply With Quote
Old 02-12-2013, 03:56 AM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Man! you're finding great deals, and doing nice upgrades.
Add me to the list of those anxious to see it with the slotted mags.
66 C20 Service Truck:
Old 02-20-2013, 01:42 AM   #28
pestwagon
I finished up the power brakes this past weekend ...scounged the lines (from a 1975 Blazer in the local junkyard) and paid $300 for new front brake hoses to the front discs and new master cylinder proportioning valve and booster. Here how it looks (not a pretty motor but it runs great)
Now the car stops straight, even with no hands on the wheel. Need very little pedal to stop now too. My wife and kids could drive it now. Before it would violently shift to the left with the drums and the weak front end. It just wasnt safe. The 2 1/2 inch droppped spindles and the standard springs give it a very subtle but still streetable rake. There are no front end noises now either. I decided to mount the proportioning valve on the left crossmember on the frame under the motor. It allowed for the easiest plumbing of the master cylinder with the stock lines from the mid-1970s truck and the cleanest installation. I even used the factory line clamp that bolts to the top of the left frame. Notice the totally rebuilt front end (new springs, balljoints and steering components)
AND NOW SPECIFICALLY FOR RENE A SNEEK PEAK....I had bought 6 lug wheels (slot mags) 15 x 8s 4 for $100. They were real old and oxidized. I first washed a rim with oven cleaner and a scrub brush. Then I thoroughly rinsed it off, then used 120 grit paper and lots of elbow grease to sand out 90% of the machined lines in the wheel, then I used 240 paper dry, then 320 paper dry, then 500 grit wet paper and then cut the wheel with brown rouge on a cutting 8 inch wheel and a 3500 rpm Makita polisher and then polished the wheel with white rouge and a polishing wheel. This was my first attempt and for you polishing purists this is far from perfect, but I did it myself and am happy with the results
pestwagon is offline   Reply With Quote
Old 02-20-2013, 01:44 AM   #29
pestwagon
Next I need to tackle the wood bed and I need to redo my instrument panel /rewire it. Lastly I need to install a radio and a set of rear dropped springs (original springs were weakened with heat by the previous owner). Plus I need new shocks...El Palomito is really becoming a money pit!
Old 02-20-2013, 06:22 AM   #30
Grizz1963
Grizz1963's Avatar
Just saw your truck for the first time and all I said was AAAAAAAHHHH MAN !!
That is just perfect.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-20-2013, 09:40 AM   #31
rob_stang2000
Thumbs up Re: El Palomito-My 1964 C10 SWB BBW Fleetside
nice job =nice truck!
rob_stang2000 is offline   Reply With Quote
Old 02-20-2013, 12:20 PM   #32
aggie91
I'm just glad to be here!
aggie91's Avatar
Polished wheel looks great!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-20-2013, 03:10 PM   #33
C/10 King
C/10 King's Avatar
Wow Steve, I'm really impressed!!! A set of black license plates would set it off and I think I know where you can find some era correct repainted ones.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 02-20-2013, 04:56 PM   #34
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Lol Rene
Sick5 is offline   Reply With Quote
Old 02-21-2013, 12:32 AM   #35
pestwagon
Hey Rene....but can she paint in the "California" part? Just polished whell #2 tonight and I have "discovered " I bought two 15 x 8.5s and 2 15 x 7s. Will a 15 x 10 fit in the back??
Old 02-27-2013, 11:10 PM   #36
pestwagon
Now what Rene??? Here she is!!
Old 02-28-2013, 01:43 AM   #37
C/10 King
C/10 King's Avatar
New fender emblems and me behind the wheel. Looks good my friend!
C/10 Rene
1971 Short Fleet
Old 02-28-2013, 11:55 AM   #38
aggie91
aggie91's Avatar
Man that looks good. I agree, new fender emblems then drive it!
Karl
The LST Challenge:
Old 02-28-2013, 07:25 PM   #39
C/10 King
C/10 King's Avatar
These could enhance your truck too. with different frames of course.
C/10 Rene
1971 Short Fleet
Old 04-04-2013, 11:36 PM   #40
pestwagon
UPDATES!!!
Got tired of the loose rattles and boucy ride. Bed came off and I am redoing the bed wood (more on that later). The rear most frame crossmember was really bent as were the lower trailing arms, most likely from previous farm work. I removed the rear most crossmember and replaced it with another one off a truck in the local junkyard.
The I scraped off old grease and wirebrushed and pressure washed the metal. What a mess. A shoe box full of mud, grease etc. came off the frame!
Then I coated the frame with Chassis Saver Brush on paint ($40/quart). Next I'll move on to the bed. In this process I also replaced the worn out hydraulic shock with new Monroe Air shocks and replaced the panhard bars bushings as well. I ordered cab bushings (still waiting on them) as well.
Old 04-05-2013, 12:26 PM   #41
timmytimm3
Nice clean truck! Good job on the wheels too!
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 04-05-2013, 12:52 PM   #42
1963c-10
1963c-10's Avatar
Truck is coming along great
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-05-2013, 01:12 PM   #43
Rich 5150 69
Rich 5150 69's Avatar
Great looking truck....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-05-2013, 06:57 PM   #44
C/10 King
C/10 King's Avatar
Looking good Steve!!! Take it to Turlock next month on the 5th that way we can all check it out.
C/10 Rene
1971 Short Fleet
Old 04-11-2013, 12:15 AM   #45
pestwagon
Mia (my 8 year old) helped finish up the bed Sunday!
Truck sits lower now (more weight in the bed- half the original wood was missing!) Mia also installed new rear air shocks (as shown 80 psi) but I think Im gonna buy taller rear springs and go from a 3" rear drop to a 2 " rear drop and run less air in the shocks daily... Have new fender emblems and a red sticker on the sail panels to add a splash of red color!
Now I need to redo all the electrical, new cab bushings and dynamat, redo the tailgate, and freshen up the dash!
Old 04-11-2013, 12:27 PM   #46
jesseo
jesseo's Avatar
Attachment 1090554
Attachment 1090555
Attachment 1090559
Very nice work. I am about to redo my bed and keep going back and forth between clear and black for the wood. Also doing in reverse order. Doing gauge and electrical 1st.
jesseo is offline   Reply With Quote
Old 04-11-2013, 02:41 PM   #47
Rich 5150 69
Attachment 1090554
Attachment 1090555
Attachment 1090559
Steve I`m running four inch drop Heavy duty springs in mine no air shocks from CPP just for visual aide..I still use mine as a truck, sometimes the loads are heavy..
Old 04-12-2013, 12:10 AM   #48
pestwagon
Think factory was black. Much easier for a driven truck....show truck look good with the stained (clear) wood. I am gonna put a camper on it and enjoy the summer!
Old 04-12-2013, 12:12 AM   #49
pestwagon
Fresno has a shop (classic chevy) that has a 2 in drop spring. Im going to place my camper on this bed and see what I get first....If it sags too low I think I'll buy some other springs.
