78K & 79C Jimmys
Re: Tough time finding 2.5" affordable exhaust kit k10
fronts the same,close to the jimmy one
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Ok, so the rear tail pipes arrived and they are 2.25". Everything else is 2.5" as mentioned above. Mufflers are 2.5" in and out. I've been looking through the web to find any GM tail pipes that might fit and I'm not having any luck. So do I want to use the 2.25"? Keep digging for a 2.5"? Find a 3" that fits? (might not be a 3" that fits either). Or take it to a shop and have it fabricated once everything else is in place. Returning the 2.25" tail pipes and taking it to a shop for the tail pipes might be the easist, but I hate to give in and not tackle it myself.
so the down tubes were both 2-1/2 or did the midpipe transition from 2-1/4 to 2-1/2.....did you measure?
flowmaster sells a 2-1/2 dual rear exit kit, its like $100 shipped from advanceauto with coupon
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
How did this exhaust system work out?
Were the walker part numbers correct for 2.5 inch down pipes? Fit was good?
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Ok, this guy hasn't been on since last year.
Has anybody else used the Walker down pipe's? How did they fit? Were they infact 2.5"?
78K & 79C Jimmys
mine were 2.25 into the muffler 2..25 out
Is there just a single exhaust system that's better than factory? Say larger tubing, with mandrel bends? Perhaps no cat? I kind of like having all that extra room that a single line down the the end offers. Plus if the pipe is actually bigger, wouldn't you get the same amount of flow as you would with duals? Such as an X-pipe or H-pipe or something.
Tags |
k10 exhaust dual 2.5" |
