#26 |
Re: Parting 66 Chevy, assorted parts+ sheet metal
#27 |
Chevy Only Tx
No problem bro, if u run across another give me a shout. I also need the upper delete panel as well.
Chevy Only Tx......... |
#28 |
![]() Join Date: Nov 2009
looking for an ignition lead for a 66. looking for black plastic "plug" which goes into ignition switch with as long a lead as you can clip out of the main harness. if you can help me out, let me know.
cost and shipping to PA zip 17543? thanks in advance, Wagz
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
#29 |
Sorry this ones been hacked up for an aftermarket switch
Posted via Mobile Device |
#30 |
1 thing at a time is progress.
Do you have the middle ebrake cable hangers and guides? if so can I see a pic?
Alan
Philippians 2:14-16 |
#31 |
Sorry sir, someone already got them before I got the truck
#32 |
10-4 thanks
Alan
#33 |
Looking for the gas tank brackets mounted on the floor. The previous owner cut them out of my truck. My zip code is 13078.
Thanks, Glenn Posted via Mobile Device |
#34 |
#35 |
Last call, first post updated
#36 |
would you be interested in cutting out the cab corners if they are in good shape? if so how much to ship to Charleston, SC? thanks.
#37 |
I'll double check to make sure, but I think both sides have poor repairs, but I'll let you know tomorrow, thanks for asking!
#38 |
could you post a pic of rear pass side cab sorta like wear you cut out on the drivers side and i will circle what i need . the peice i need is about center of door opening oposit of fuel filler in drivers side
#39 | ||
![]() ![]() Posted via Mobile Device |
#40 |
Thank you for checking.
#41 |
i need the part that i marked its like 14 inches down from crease how much shipped to 13407 you can cut the whole chunk out if you can including the door frame its hard to see the dent . how is the area around the trans cover in need a chunk pass side rear section and drivers side near gas pedal
#42 |
sorry forgot pic can you circle the dent
#43 |
Best I could do, I'm on an iPad. The dent starts behind the body line aNd is in the rounded part. It's mild and very workable. I guessed on the weight and came up to around $15.00 parcel post (should be close) how does $15.00 + actual shipping sound? Just let me know and I'll cut it off and get it boxed up. Unfortunately the floor in this truck was about as bad as it gets, nothing but imagination holding the trans hump in place
#44 | |
#45 |
Yes sir I take PayPal. I should be able to get this done this afternoon, I'll pm you with the details then, thanks!
#46 |
Mack,
any chance you have the thrift air control switch/cable? Hey, we're pretty close right? I am stationed in Pensacola Florida!
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
#47 | ||
![]() And err body else thanks for playing, the frame is still available, but the rest is history ![]() Posted via Mobile Device |
#48 | |
No, that's the resistor that controls fan speed. Thanks though. Still on the hunt for a thrift air switch....
#49 |
#50 |
Thank you sir! It was a pleasure
