#26 | |
Re: Trying to find a fitting............
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
#27 |
Yellow truck club
Re: Building brake lines........need some help
when your finished you will find the fitting you were looking for!
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#28 | |
#29 |
I was thinking about doing that.WE used to clearcoat black oxide plated bolts at one of my past jobs.
#30 |
I finished building my brake line system for the 57. This is the very first time I built brake lines on my own. I read the Snap-On directions in my brake flaring kit and watched youtube videos on how to do it. The lines turned out nice and cosmetically I was pleased. Tonight was moment of truth............ add fluid into the reservior and check for leaks. Here goes nothing........................................... Well, had a few leak points at some fittings. I ended up tightening them up and stopped the leaks completely. Some of the nuts were not quite snug enough. The only leak I have now is a darn banjo bolt fitting for my camaro/firebird rear disc brake caliper on the driver's side. Hhhmmm....... not bad for a first timer I guess. I heard about so many nightmares with brake making and how even professional folks have difficulty with it. I plan to replace the banjo bolt/copper washers and hope it fixes the leak.
#31 | |
Re: Update
#32 | |
Re: Update
