Re: Green Mile
Looks good! I've been wanting to do one of these for so long!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Re: Green Mile
What a giant dissappointment this weekend. The weather was cold and crappy and didn't get to go to pick n pull. I guess i shouldn't be supprised...it is winter after all. Some good for the bad, i picked up some spings in good shape from a buddy so ive begun to take them apart to modify the leaf pack for some extra drop once the belltech shackle and hanger kit arrive. Like all other projects on the truck, that quickly led to dissassebling the rear end. In a few hours this afternoon the 14 bolt came out, and i started to remove some other things in preparation for the new 12 bolt once it arrives also, haha. Here is some pics of the tear down!
![]() This picture doesn't show it very well, but these old leaf's are toast. Up close they are pretty wavy, and you can see gaps between just about all of the leafs in wierd spots ![]() Im not sure why i took this pic, but i guess is shows where the electric pump is hiding, for now, the duals with x-pipe, etc ![]() There she sits with a 15x8 mocked up in the rear at a random height. Other news, im not sure how the drive shaft lenght will be affected by the new ride height. I noticed im going to have to modify the carrier bearing cross member a little for the new angle. That led me to thinking if i have to re-shorten the shaft, I might as well toss in the 700r thats sitting on the floor next to the truck. It was supposed to go in my LeMans, but the truck needs it more right now. Last edited by lsxponcho; 12-02-2012 at 11:37 PM. |
Re: Green Mile
Also after blabing about the new seats and not showing any pics, i took the opportunity to snap a few while i was doing laps removing the rear running gear. Again sorry for the poor lighting, and so on.
Here are the front seats from a few angles ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Green Mile
And now some various angles of the rear split folding bench
Re: Green Mile
nice results so far,im on for this one, i always wanted a 1-ton dually 4-door....
Re: Green Mile
I'm digging this truck.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: Green Mile
Finally a small update from yesterday. I received my bell-tech shackle and hanger kit yesterday. I also broke down and bought some new rotors, bearings, spindle nut and washers, and dust seals and caps. I could not wait any longer on the weather to go to pick n pull. Also i picked up a 16 gal saddle tank, as im gonna get rid of the slip tank in the box. Unfortunately the burb tank was too big for the limited space back there so i scrapped that idea. I still need to pick up calipers and pads, and maybe dust shields, but at least the nose is sitting on the ground now.
![]() I can't remember what i mentioned last about the new 88-98 outer tie rods, but when i installed them, i just measured them up from the stock 76 tie rods for a base line, which now that its on the ground there is too much toe in. It may be that the truck has to roll around and settle, but the camber seems a little off too, as the top of the tire leans out a little. Will comment as i make more progress. Over all I think it needs to come down more, until the top of the 235 is flush with the wheel opening i think. Onto the rear. As i mentioned, i got some new to me leafs for the rear. Some bad news though, after cleaning them up and giving them some paint, i noticed the pass side top leaf is cracked on one side right in the center next to the bolt. Not sure on what im going to do there, but for now i cut off the old front hanger, and mounted the new one, hung the new shackle, clearanced the box mount rail, and tossed in the leaf just to see what it looks like. ![]() ![]() ![]() Hopefully this coming weekend i can finally pick up the donor half ton frame. I was also thinking now about moving the rear hanger forward and running the 1/2 ton leafs, but not sure yet. Also thinking about what to do for rear shocks. I think im ditching the stock style set up, and maybe running an outboard shock like the new F-150's (after staring at my work truck the other day). Time will tell. Anywho, Merry Christmas to all! |
Re: Green Mile
Another holiday update! I picked up my parts 1/2 ton rolling chassis this weekend, made quick work of the rear end and got the 12 bolt out. I also removed the rear hangers, as i decided to do a hybrid of half ton suspension, and new belltech drop 1 ton parts. Today i finished cutting off everything off my truck frame, (old rear hangers, with extra support on the bottom side of the frame, shocks, bump stops, and exhaust. I measured up the 1/2 ton rear hangers, and drilled the truck frame and mounted with grade 8 hardware. I had to clearance the box rail a bit more as the 1/2 ton hanger does not hang as low, and with the 4" drop shackle installed is fairly close to the box floor. Onto the front, I measured up the difference between the 1/2 and 1 ton front hangers, and being that i just spent the money on the belltech stuff, i decided to brake out the grinder and cut up the new hangers. I made up 1/4" - 1" spacers, and welded the hangers back up. I also re-drilled the front hangers 1" up, for a total of 5 " drop hanger from stock. All said and done the half ton springs fit like they should, and i did not have to move or weld any new perches on the rear diff. The springs from the donor were 3 leaf pack with 1 bottom overload. Once again, its dark and the pics suck a little, but you get the idea. Now that the wieght of the truck is on all 4 wheels the front came down right where i wanted it. Tomorrow i hope to finish up the brake work, swap the u-joint and roll it outside and see how it looks. As for exhaust, for now its chopped in front of the rear diff, so i might just dump it out side exit style in front of the rear wheels. So far in the garage it lookes killer, but the garage is a little cluttered to get a full view.
Re: Green Mile
I forgot to mention something about total drop. We'll, i dont have a solid answer, but right now all 4 wheel openings are a 28". If i had to guess, i would say its somewhere in the neighborhood of 6/8 drop from what it was before. Also there is about 2" of space above the diff to the frame, so a c-notch may be in the not to distant future.
Re: Green Mile
Like what I see so far, what size tires are you running right now and do they rub? Would like to see some outside pics when you get a chance.
Too bad you weren't closer to Manitoba, I would take that 14 bolt off your hands. I need some backing plates and drums to convert back from discs (Damn inspections)
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" Last edited by Devillusion; 01-01-2013 at 01:49 AM. |
#11 | |
Re: Green Mile
Re: Green Mile
I worked my ass off yesterday trying to get the honey do list done so i could get the truck wraped up. Almost got finished up. I got the new front calipers, pads installed, torqued the ball joints/tie rods, swapped the u-joint (still have to install the shims to fix the pinion angle up). Then the inlaw's called and we all went sledding for the evening, haha. I just have the rear brake line to do, and its mobile again. Im not sure what to do about the rear shock situation, and I have to get the new saddle tank installed, then i can drive it over to the inlaw's to do some exhaust. I snapped a better bird's eye view of the truck, and some pics of the hangers, etc. Outdoor pics soon!
Here's the rears from a few angles ![]() ![]() ![]() Here you can see where i had to add an inch to the front hanger. ![]() ![]() ![]() ![]() |
#13 |
Re: Green Mile
Really like your truck I also have a crew cab I found back in oct. has no rust hard to find around here. Trying to to make up my mind if I want to lower it or
make it a 4x4. |
#14 |
Re: Green Mile
I finally rolled this thing out of the garage for the first time a few nights ago, but there wasn't enough sunlight to snap some pics. Tonight i finally got home in time to get some work done. Too bad it was getting dark to take a decent after pic. I pulled the shim packs out of the upper control arms to gain some camber back. You will see that after the 88-98 spindles, it looks like its taking high speed corners sitting still with the top of the tire leaning out, haha. Overall, it looked way cooler in the close quarters of the garage. I didn't have a full set of 88-98 center caps either, so i stuck some stockers on for now.
Now that its on the driveway, I kinda felt a little let down by the stance. Either its the staggard tire size that makes it look funny, or mostly the uneven drop that the tire size makes up for. The rear is noticeably lower, but thanks to the 31" boots in the rear it has a decent stance. It just looks stupid with the uneven wheel height/fender relation i think. So I can do one of two things; -Go lower in the front, in which case im gonna run out of inner fender room with the 235, -Or go up in the tail, which is kinda counter productive i think. Im thinking i might try and pick up some 15x10 rally's with either a 28x12x15, or a 30x12x15 sportsman sr, which is alot closer to what i have now. Then up front run a 15x8 with 255/60, or 275/60 radial of some sort. Or some sweet 20's, haha. Anyways, here are some pics, let me know what you guys think. ![]() ![]() ![]() Here's the poor shocks almost at the bitter end of compression ![]() ![]() |
#15 |
Re: Green Mile
I like your truck! I don't know if you know this, but from the factory, the wheel opening in the rear is 2" lower in relation to the body line than the front wheel opening. That is the reason the rear looks lower.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
#16 |
Re: Green Mile
Thanks! Yeah, I knew about the wheel opening. I was just thinking if i had same size rubber all the way around, it would have a cali lean which is not what i was going for. Im not sure what to do about it yet.
#17 |
Re: Green Mile
I have a GMC insert so the Chevy emblem will dissapear on that gate
67- 72 Parts collecter |
#18 |
Re: Green Mile
#19 |
Re: Green Mile
wow looking great!
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
#20 |
Re: Green Mile
Love the way it looks!
#21 |
Re: Green Mile
i just saw this truck on kijiji, decided to sell it?
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
#22 |
Re: Green Mile
Once in a while I toy with the idea of selling. Ive just got other toys in the garage that are supposed to have priority over the pickup. That being said, I get all sentimental and take it off before to long and end up doing more work to it, haha. Everything is always for sale.
#23 |
Home Built '87
Re: Green Mile
I saw it on kijiji as well before it disappeared later the same weekend. PM if you want to really sell it (I'd even give you a buy-back option at the same price for a while in case you change your mind again!)
I'm moving to Calgary this month....will get my truck on the road again after that and will go for a drive out to Strath to say hi one day this summer.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#24 | |
Re: Green Mile
