11-14-2012, 01:47 PM | #26 | |
Re: Big back window conversion part 1
To the OP, absolutely NO offense intended. I will not speak ill of the hugely talented individuals like you and Bam that LIKE to take on these huge challenges! Posted via Mobile Device |
11-14-2012, 03:10 PM | #27 | |
Plus it has to be worth something to not have to contend with straightening out the normally beat up back panels of the cab off the donor truck. That will probably help ease the cost of that back panel quite a bit. |
11-14-2012, 07:21 PM | #28 |
Bingo! I envy you guys out west. Big window trucks on east coast mean big money.
11-14-2012, 09:51 PM | #29 |
Just watching
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
11-15-2012, 09:24 AM | #30 |
I am gonna grind off old mounting tabs this weekend and do a trial mock up of complete window with pics.
11-15-2012, 10:01 AM | #31 | |
Thump, are you MIG welding this together or do you have spot weld equipment? |
11-15-2012, 02:44 PM | #32 |
Looks great and now you know what the real inside of the cab looks like. Best part is now you dont have to deal with putting new cab corners on. I would agree that good cabs are hard to come by here in the north east. I shed a tear when I cut up a pretty much rust free cab when making big bertha but it was for a good cause and I got over it quickly. I have a sugestion for you. if you are going with 3 point seat belts....now would be a good time to put a reinforcing plate and weld in a nut for your upper mount. I had a heck of a time getting mine in from the bottom of the inner cab.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
11-15-2012, 06:54 PM | #33 |
I am going to get a spot weld gun and my buddy is gonna teach me to use it. Thanks for reminding me about seat belts.
11-15-2012, 07:13 PM | #34 | |
Hollister Road Co.
http://www.usaweld.com/Quick-Spot-II-p/60501.htm Its much better than the Hobart/Miller/harborfreight one. |
11-16-2012, 09:53 AM | #35 |
Good work on the project and posting the progress for everyone else. Brings back memories when I did the same thing. I lucked out by finding a back window and roof already cut out and used that. I did put a whole new back panel on though.
I go by the principle that if it was easy, everyone would have one. I changed mine because I scored on a set of cameo bedsides and really like that look. |
11-16-2012, 05:57 PM | #36 |
That looks like a decent gun for a home user. When you start dropping in price the duty cycle decreases and the welder can get fairly warm if you do a series of continuous spots. It's not a bad idea to familiarize yourself with resistance welding before actually starting: http://www.millerwelds.com/pdf/Resistance.pdf
I have an old spot welder here I'd love to try. It's a professionally made model similar to this one: http://www.vintageprojects.com/metal...WeldingGun.pdf |
11-24-2012, 02:16 PM | #37 |
Any updates? New pics?
11-24-2012, 03:27 PM | #38 |
I am gonna post up some pics later tonight. I still have to replace inner cab corners but i have all the window trim braces and inner window ready to be drilled & welded in. I had to cut out the entire striker latch assembly front facing sheetmetal on the replacement inner panel. This made mounting inner window easy. Easy stuff.
11-25-2012, 06:21 PM | #39 |
ok so far I have gotten the minor fab work out of the way. This next step is fitting inner cab window with pillars and roof.
I cut out the entire front face of the inner window frame to include striker latch mount assembly (this part is the same as the actual original cab pillar. Then I bent the window braces to their correct position for welding to cab pillar. The next post will show how the braces set sit and where they are to be welded up. Last pic shows brace and cab without pillar. Last edited by thump16; 11-25-2012 at 06:38 PM. |
11-25-2012, 06:26 PM | #40 |
These pictures show where the inner window and brackets sit. nothing is welded in yet just positioned. Still have to repair my inner cab corners. These are the exact positions that the brackets are welded in. There is also a weld going up the side brace and pillar. Every piece becomes one unit once welded in.
11-25-2012, 06:34 PM | #41 |
fitment from roof to pillars. the whole unit fit snug but I zip tied it since I left it over night as a secure measure.
11-25-2012, 06:46 PM | #42 |
I noticed that the inner upper cab wall doesn't seat fully forward against the pillar for mounting (neither di the original). I will go in similar to the original inner panel. That is all for now. I have enlightened you on the mystery of the inner big window panel. The replacement parts and an original BBW will vary but the design and support structure are basically the same. Here is an original I took from a members (Tbrown5079) build. Notice how it is welded in and along the pillar.
01-06-2013, 11:32 PM | #43 |
Any new progress?
01-07-2013, 12:32 PM | #44 |
Wow, Thats a hell of a project. Keep it up!
01-07-2013, 02:57 PM | #45 |
Way to go! I did a big window conversion on my pickup - here's my thread if you wanna check it out. I bought a rusty BBW cab for 200$ and just cut the section of the cab out. I followed a Custom Classic Trucks article from 2006 (Which the article did not show many steps involved) It's a time consuming process but will be worth it when your done.
http://67-72chevytrucks.com/vboard/s...d.php?t=492002 |
01-08-2013, 12:22 PM | #46 |
No progress yet. Been working on my 84 lq4 swap. I did manage to score big back glass for the project. I will finish up around feb. Shane, the 55-59 trucks are hard to come by round here. They are coveted highly. The big window trucks are hidden away.
[size=1] |
01-08-2013, 12:45 PM | #47 |
Thump16 - there's plenty of them floating around here in the Oklahoma/Kansas area.. I currently have four original big Back window trucks. I have a nice BBW gmc cab too. When I find em forsale cheap I buy em... You'll appreciate this truck more after putting the Blood, sweat and tears into it... there reason I did my BBW conversion is because my 55 truck is the first pickup my Grandpa bought me when i was 12...keep up the good work.
01-08-2013, 02:58 PM | #48 |
I am retiring this yr. 21 yrs in AF. My 56 is the truck me & my baby girl are gonna cruise to home depot with & ice cream missions.
Sledge Posted via Mobile Device |
01-08-2013, 03:39 PM | #49 |
If you are serious about the ice cream missions you owe it to her to take her to Hanks Ice cream. Stores in Houston and Atlanta only. They have the best butter pecan and banana pudding. No this is not advertising for them, It really is that good.
01-08-2013, 03:55 PM | #50 |
I will remember that. We have brusters & they have a winter schedule.lol. it will be 79 degrees here on friday. The 56 means alot to me. It represents me taking the time to restore it right & there isnt any rush on completing the entire truck right now. Just the cab work. Now if some of the board members wanna come over and help me, i can provide the food and beverages. Lol. Seriously though, i have to get the 84 c10 done by feb to clear up my garage. We welded up my stepnotches for the 56 on sunday. I hope to have the frame painted and cab on it by late april.
